Question about Toshiba Satellite A75-S1253 Notebook
Laptop not running on battery
I have a Satellite A75-S1253 which works great as long as I leave the AC adapter in. The moment I unplug the adapter, the laptop dies. The laptop recognizes the battery and displays that it is 62% charged, but will not charge any further no matter how long it is plugged in. I also have tried another battery with the same results. Any thoughts?
    Problem Solver:
  • 6 Answers
Try another power supply, they can have voltage problems and still have ample voltage to run the laptop but not fully charge the battery.
Posted on Apr 29, 2009
My A75-S1253 Toshiba Laptop screen is not properly visible. Its in like grayscale/watermark vision. Is there a setting problem or do I have to replace the entire screen?
Hi
Thank you for your query
From what you are describing it may be your screen OR the inverter, if the screen is very dim and you can balrey read it, then it is highly likely to be the inverter
Please book the laptop into a reputable PC shop for replacement
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again - shauqatm@yahoo.co.uk
Feb 22, 2010 | Toshiba Satellite A75-S1253 Notebook
Battery light goes out about 10 seconds after pluged in. does not charge
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
Feb 16, 2010 | Toshiba Satellite A75-S1253 Notebook
Toshiba Satallite a75-s2112 laptop when plugged into a/c power, the ac power stops working, then goes to battery. If I unplug the power adapter and plug it right back in , it will start working and then go...
This is a problem with your charger, I had the problem with my toshiba Sattelite, it was either a break in the wire or a short in the brick. You need to purchase a new charger.
Dec 23, 2009 | Toshiba Satellite A75-S211 Notebook
I need to replace my CD drive in a Toshiba A75 S1253 labtop. Anyone know what I can get? Thanks, JD
This one should work. I haven't order from this company before, so I don't know how good is the service and return policy.
Nov 07, 2009 | Toshiba Satellite A75-S1253 Notebook
Screen black & with no power
hi there,
you can follow this instruction and try to your laptop to resolved the problem.
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with Toshiba Satellite M35X and Toshiba Satellite A70/A75 notebooks. If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it’s still under warranty, it would be fixed at no charge to you.
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. Toshiba Satellite M35X and Toshiba Satellite A70/A75 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system board with a magnifying glass. In most cases you get the power problem because of a bad connection between the DC jack and the system board, you’ll see a crack between the DC jack connector and the system board.
Here is an example of Toshiba Satellite M35X power jack. The crack occurs between the DC jack pin and the system board.
satellite-m35x-crack.jpg satellite-m35x-contact.jpg In some cases the connection is good, but the DC jack is bad itself. You can find a new DC jack for Toshiba Satellite M35X and Toshiba Satellite A70/A75 laptops here. Search for DC jack M35X or DC jack A75.
How to resolder laptop power jack yourself.
UPDATE:
Sometimes, after you replace the jack, you can see that the system board doesn’t get power at all. The battery will not charge and the power LED will not light when you plug in the AC adapter. So, here’s a possible explanation.
When a connection between the positive pin and the motherboard breaks (cracks), the power jack gets loose. You can feel it when you plug in the adapter plug. A loose power jack can damage the trace inside the hole in the system board. Take a look at the picture.
power-jack.gif As you see, the positive pin goes through the hole in the system board and you solder it on the top side. Right? What if the trace between the top side and the bottom side is broken somewhere inside the hole? I’ve seen it before a few times. In this case everything looks nice and clean on the top side. When you plug in the AC adapter, you get normal voltage readings between “+” and “-“ pins on the top side, but the power DOESN’T go to the motherboard at all, because there is no connection between the top and bottom sides. Test with a multimeter if there is a connection between the top and the bottom.
If the trace inside the hole is broken you still can fix it. You can run a wire to connect the top and the bottom sides. Be careful not to short something on the board.
Update:
Here’s another solution to fix the power jack problem, it shows how to relocate the power jack outside the laptop base. Check it out here: Toshiba Satellite A75 failed power jack workaround.
When you repair a loose power jack, it’s a good idea to check the jack on both sides of the motherboard. When you remove the top cover from a Toshiba Satellite A70/A75 laptop you can see only points where the jack is soldered to the motherboard as it shown on the second picture in this post, but you cannot see the jack itself as it shown on the first picture.
Removing the motherboard from Satellite A70/A75 laptop is a good idea because the jack itself might has a broken “+” pin, as it shown on the picture below. If the “+” broke off the base, you’ll have to replace the jack.
Feb 15, 2009 | Toshiba Satellite A75-S229 Notebook
Satellite A100 won't swich on- will be similar to A75
remove the battery , then insert it again, then leave it for charging for some times then check
Oct 26, 2008 | Toshiba Satellite A75-S209 Notebook
Toshiba Satellite A75-S1253 Notebook Logo
241 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
