Question about GE JTP15 Electric Single Oven
'79 GE lower baking coil not powered in Bake cycle
The problem started last week with the arcing of the lower baking coil of our July 1979 combination (micro & oven model J - KP97G serial MF980755M)GE oven... I replaced the same lower coil that I previously successfully replaced in 2001. Except this time, only the upper coil functions in the Bake mode although the oven Clean mode works great. I just replaced the oven switch WB22X5123 as recommended in lieu that there was no connection being made between the 2 'Bake' terminals and no visible wire connection problem was visible. I tested the new coil to the normal 17.8 ohms although the power across the lower coil terminals was only about 40 volts...The thermastat unit contacts looked ok and I cleaned the copper contacts. (just a note that we have not had a continuous red light on the bake light for some time and we have adjusted the oven temp dial to 50 degrees warmer than desired with success for years...) We would like to continue using our current oven for at least 5 years when we may replace some of our kitchen appliances. Please help. Thank You.
  • 906 Answers
Good day,
hope this link below will solve your problem.
kitchen appliances
Posted on Jul 31, 2010
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
Jtp45 lower oven hot heating on any cycle
Possibly a tripped thermal fuse. Should be located behind the panel in between the upper and lower ovens. Might have a red reset button on it you can push down. If it clicks and then works again, look for possible cooling fan problems.
May 12, 2014 | GE JTP45 Electric Double Oven
Oven comes on for 5 min then shuts down everything even the keyboard
Same problem here on JKP15WOW1WW. The cycle starts like this:
1) Open circuit Breaker
2) Open oven panel and push ribbon connector to ERC. Replace planel.
3) Close circuit breaker
4) Run to oven, notice clock flashing some time but not 12:00 and start Bake. Bake button beeps and starts bake coil.
5) Within 5 minutes hear a beep and all buttons on panel are unresponsive. Bake continues. if oven light is on it continues to glow. Only button that responds with a beep (and not to clear bake or oven light) is Clear botton.
Rinse..wash..lather...repeat...
Nov 11, 2009 | GE JKP15 Electric Single Oven
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
Broiler element comes on when "bake" is pressed
does the bake element come on at all?
if so, try the oven out. do a bake @ 350 allow it to pre-heat, and see if once the pre-heat is comlete, id the broil shuts off.
on many ovens at the beginning of the cycle during pre-heat both bake and broil elements are powered.
other than that it may be a control board, or a burnt and crossed wire in the harness.
May 28, 2009 | GE JTP15 Electric Single Oven
Ge wall oven will not heat up on bake,boil or clean cycle
GE JKP86BF3BB COMBO MICRO/ELECT OVEN
NO HEAT ON BROIL OR BAKE ELEMENTS
CKD WIRING FROM PANEL OK
CKD TERMINALS AT ELEMENT HAVE 120V ON EACH ELMT
FAN COMES ON
THE ON INDICATOR SHOWS WHEN TMP &START PUSHED
MICROWAVE WORKS FINE
I ORDERED A NEW BAKE ELEMENT TO TRY-NOT HERE YET
STUMPED
Mar 16, 2009 | GE JTP15 Electric Single Oven
No power to heating coils
h\ave you check for any damaged ono the themal fuse..?
Jul 09, 2008 | GE JTP45 Electric Double Oven
Amana Convection oven not controlling temp
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
GE JTP15 Electric Single Oven Logo
118 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
