Question about Brinkmann 810-7080-K All-in-One Grill / Smoker
Brinkmann proseries heavy-duty gas grill
Did not come with assembly instructions, brinkmann proseries heavy-duty gas grill
    Problem Solver:
  • 14 Answers
Brinkmann has a website that has links for some of their units, however I have found that listing to be far too small for any real help.
I would recommend contacting Brinkmann directly and asking for help through their Customer Service Department. They can be reached at:
* The Brinkmann Corporation
Attn: Customer Service
4215 McEwen Road
Dallas, TX 75244
Toll Free:
(800) 468-5252
Local:
(972) 716-4262
OR you may send them an email through this link:
http://brinkmann.net/Customer%20Service/ContactUs.aspx
Posted on May 30, 2010
Natural gas converted grill will not get hot
Did you put a regulator on the grill when you converted it? Check with your local gas supplier. I St Louis, MO the pressure is low enough to not require the use of a regulator.
Apr 09, 2014 | Brinkmann ProSeries 810-6330-W Grill
I have a Brinkmann with a side burner. It does not start up using the control knob, but I can match light it so the gas supply is good. What's the problem ?
hello chaak... check to see if when you turn the control knob you are producing a spark. If there is a spark move it a wee bit closer to the burner and it should work. If there is no spark you will have to replace the sparker. Joe
Jun 24, 2011 | Brinkmann ProSeries 810-6330-W Grill
Grill wont light
Hi there, can you let me know if it will light manually with matches,lighter or manual lighter. I'm trying to work out where the problem may be (gas or ignition). If you lift the gas tank is there liquid inside it.
May 30, 2011 | Brinkmann ProSeries 810-6330-W Grill
Brinkmann Pro Series 2545 Assembly - The side burner valve nozzle does not fit firnly into the burner venturi. The venturi (pipe) is about 1 inch too short!
When you attached the side burner assembly to the grill frame, did you pull it forward before tightening the 4 bolts that hold it in place? If not this could account for part of the problem. The other would be how you routed the gas line hose from the 'Y' connector, to the side burner connection. If routed differently than what the assembly instructions indicate, you would come up short on the length.
In any event, your model grill has been discontinued by Brinkmann, but the warranty and some parts are still supported by the manufacturer. I'm assuming you just purchased this grill and are in the process of assembling it according to the Owners Manual. So, if you continue to have a problem contact Brinkmann's Customer Support Hotline 800-527-0717.
Hope this helped you. Please let me know. Thanks.
May 14, 2011 | Brinkmann ProSeries 810-6330-W Grill
The gas flow metal pieces fell off how i replace them
Could you be a little more specific about the "gas flow metal parts" that fell off?
Apr 06, 2011 | Brinkmann ProSeries 810-6330-W Grill
2 months old, doesn't work
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Sep 03, 2010 | Brinkmann ProSeries 810-6330-W Grill
I need instruction on how to put together model 8300 proseries Brinkman
Click on this Brinkman link for the manual you need. Scroll down to the 6th Brinkman model listed to find your model and click on it. You can then download this adobe file and print it up on your computer for free.
http://www.brinkmann.net/Customer%20Service/OwnersList.aspx?category=Gas+Grills
Have fun assembling it!
May 15, 2010 | Grilling
I would like to convert my propane BBQ to natural gas. What type of fitting do I need and how do I hook it up?
you will have to contact the brinkmnn company and purchase the conversion kit. The kit will have complete instructions.
Oct 18, 2009 | Brinkmann ProSeries 810-6330-W Grill
Low flame
The newer type tank has an anti tip safety device. It gets all boo boo'd when the grill is moved around. Remove the tank. Open the valves on the grill and close them back. Re install the tank and slowly open the valve.
Jun 27, 2009 | Brinkmann ProSeries 810-6330-W Grill
Brinkmann 810-7080-K All-in-One Grill / Smoker Logo
141 people viewed this question
Top Brinkmann Grilling Experts
Paul Carew
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
