Question about Mitac Mio 168 Pocket PC
Mio 168 pocket computer: Not connected Unable to synchronize
I have had no problems with the Mio but I had to re-format the laptop that I used for synchronization. I reloaded the Outlook and ActiveSynch on to the laptop, following the instructions I think although I probably connected the Mio before loading ActiveSynch. However i uninstalled and did it again. The Mio was detected OK but when I attempt to synchronize I get a message that there is no connection; I can not seem to get the laptop and the Mio to recognize that each one exists.
  • dorutzu18 Jan 14, 2009
    i have the same problem with mio c250. i don't know what to do. is somebody?
SOURCE:
  • 473 Answers
SOURCE: MS Outlook syncs calendar, notes but not contacts
Click on the hotsync icon in your system tray and then click "custom". That will bring up the list of things you are configured to sync with (conduits). For each of the ones you have problems with, click that conduit and then make sure it's set to sync the way you want...desktop overrides, handheld overrides, syncronize, etc. Potentially you have some of them selected as "do nothing". What shows up when I click custom from hotsync are the following Outlook Conduits: Calendar, Contacts, Tasks and Memos. If you don't have those showing up, you need to update your Outlook conduits on your PC. If you have them, click to select the problem conduit, then click "change" and select what you want to have happen.
Posted on Sep 11, 2005
  • 473 Answers
SOURCE: Hot sync does not work
"PLEASE SET SYNCHRONIZATION OPTION ENABLE SYNC WHEN OUTLOOK IN UI IN ORDER TO SYNC IN OFFLINE MODE" Just go to your Hotsync Manager icon Click Custom Click each Outlook conduit ex. Calendar Outlook Click Change Click Settings Check the Box that says Enable Synchronization when Outlook is Offline Then do same process for Contacts, Tasks and Memos. Wherever your updated data is..make sure you set Action of conduit to example: Desktop Overwrites HH (if your OUTLOOK has the most updated data.) Hope that resolves your problem.
  • 4 Answers
SOURCE: cannot get my mio 168 to connect to satellite any help please
From inside Tomtom, have you tried "change preferences" then scroll through to "show GPS status" then "configure" select "Other Cable NMEA GPS" select "Done" for GPS baud rate of 4800. Now select "Serial Cable on SP2 and then "Done"
Hope it helps. Philpot
Posted on Nov 18, 2007
SOURCE: HC SD card support for pocket pc
Unfortunately, Pocket PC devices with Windows Mobile 2003 OS do not support High Capacity SD (SDHC standard) cards.
However, some companies have created standard SD cards (Not SDHC) with capacities up to 4GB. These, sometimes, not always, work.
I would recommend you to purchase SD cards up to 2GB in size only which is the maximum size the SD standard has defined. If you would like to try the max capacity you can get, you can try some "SD standard extended, but not SDHC" SD cards up to 4GB. If you would like brand names, I could recommend you a few..
Dimitris.
Posted on Feb 25, 2008
SOURCE: mio 168 connecting to wifi usb adapter on pc problems
Buy SD WiFi card (eg Spectec SDW-821).
Prob only work with WEP/WPA encryption - not WPA2
Posted on Mar 02, 2008
How to unlock my mio m300
If it's locked on the main screen and won't load, follow the below process.
If you want to unlock maps, you need to buy a key or update here:
http://eu.mio.com/shop/index.php?language=en-eu&utm_source=callcentre&utm_medium=email&utm_campaign=MTUKLaMa&no_cache=true¤cy=EUR
To reload the software:
1. Connect your device to the computer 2. Make a backup of your addresses and favorites if you wish 3. In File Explorer, right click on the device (removable drive) >> Format 4. Start the Desktop 5. Go to My Mio >> Reinstall the software 6. Go to My Mio >> Recover Keys 7. You can now reinstall the maps from the Maps tab. If you downloaded a map update, make sure to use the downloaded file. 8. Go to My Mio / Voice Transfer and re-install the voice files
Dec 03, 2010 | Mio Moov M300 GPS for Europe 35" screen...
Synchronizing the outlook mail in all my computers
You need to confirm the type of account your using maybe its been setup on the additional laptop as POP3 ? In order to syncronise you will need to use IMAP then you will see the changes made on all laptops.
Jan 23, 2009 | Microsoft Office Outlook 2007: Windows
Synching AximX30 after upgrading to Outlook2007
I assume you are not running Vista,
have you installed latest ActiveSynch?
http://www.microsoft.com/windowsmobile/en-us/help/synchronize/activesync45.mspx
Jan 10, 2009 | Dell Axim X30 Pocket PC
Back up of data on computer from htc s720
for dat u need 2 install windows synchronize 4.2 and windows outlook,,,,open outlook first and den connect mobile using data cable and den select contact 2 synchronize...dat will b saved 2 outlook...
Oct 26, 2008 | HTC S710 Smartphone
How do I copy address book and calendar from Tungsten E to Outlook?
In order to synchronize with Outlook you need to setup the replication to be with Outlook instead of Palm Desktop. On you cd there should be a third party piece of software (Chapura). Install the required software and follow the instructions.
Sep 12, 2005 | Palm Tungsten E Handheld
OLERR messages, however all of mine fail to sync: Calendar, Contacts, Tasks, Notes. Tried web troubleshooter to no avail. Can anyone please shed some light on this issue??? Thanks
I was having the same problem, and I used Detect and Repair in Outlook. Now all is working fine. You will need the original CD that you installed from. Hope this helps as none of the other things that I saw on any sites did until I tried this.
Sep 11, 2005 | Palm Zire 72 Handheld
No synchronization when Outlook express is default mail program
Email synch is based on current MAPI preferences. The problem you have is that the VersaMail conduit assumes your mail client must be the MAPI default email client. You could adopt another profile in Outlook instead of OExpress which picks up the account you use in OE. This is the first instance of this problem I have ever heard of so I doubt if PalmOne would make a software change on this.
Sep 11, 2005 | Palm Tungsten E Handheld
Sep 11, 2005 | Palm m130 Handheld
How to synchronize outlook
Switcher.... Inorder to sync your handheld with Outlook you must have outlook conduits installed. Follow these steps to have an outlook conduits installed. 1. Place the Desktop Installation & Software Essentials CD on your cd-rom drive. Wait for it to finish its autorun 2. At this point you'll be presented wth a flash window which contains certain options you can choose. 3. Click on "Change your synchronization method" 4. Click on "Use Microsoft Outlook to ...... " 5. Click on "Yes" 6. Click on "Done" 7. Restart your computer inorder to refresh the new settings. You can now use Microsoft Outlook to synch your appointments, contacts etc..
Sep 07, 2005 | Palm Tungsten T5 - Multilingual Handheld
Mitac Mio 168 Pocket PC Logo
Top Mitac Computers & Internet Experts
gerry bissi
Alun Cox
asber
Are you a Mitac Computer and Internet Expert? Answer questions, earn points and help others
