Question about SPL Audio Phantom DK2-1000 Car Amp
Need help if you have a 4 ohm subwoofer how do you tell if the amp is powering it at 4ohms or 2 ohms
  • 655 Answers
Hello bully_bread,
Your amp will be powering the sub at 4 ohms.
The impedance or "load" that the amp sees is determined by the number of voice coil(s), the number of sub(s), and how they are connected. Whatever that final load, it is the impedance or "ohms" that the amp is supplying power at.
A single 4 ohm sub with a single voice coil cannot present a 2 ohm load. However, a sub with dual 4 ohm voice coils wired in parallel will present a 2 ohm load.
Here's a link to Rockford_Fosgate's "wiring wizard" where you will find all combinations of subwoofer wiring and the resulting loads.
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
Hope this helps.
Posted on Apr 13, 2009
I have 2 different subs in one box, a 12" MTX thunder and a 12" Kicker CVR. the kicker is a dual voice coil while the MTX I dont believe is. Can I use one amp for this set up? And how would it be wired?
im guessing both speakers are 4 ohms ..mtx 4ohms and kicker dual 4ohms..now if your amp can go down to 1 ohm wiring the kicker dual coils in parallel (2ohms) and the mtx connected together (4ohms) should leave you with a final impedance between 1 and 2 ohms ...i suggest you use one or get another
Oct 08, 2013 | MTX Car Audio & Video
Is the sony xplod cdx-gt71w able to support a subwoofer without another amp
Sure is.
The sony is bridgable as follows:
  • 100W x 4 @ 4 Ohm
  • 100W x 2 + 250W x 1 @ at 4 Ohm
  • This will allow 2 channels to run 100 watts each @ 4ohms with an additional single channel with 250 watts @ 4 ohms.
    The single sub channel is created by bridging channels 3 & 4
    Dec 22, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
    Need help.. I have two 12 inch dual voice coil kicker comp vrs.. they are 4 ohm subs..how do i wire them to get a final ohm load between 1.5 to 4ohms in a dual enclosed box...Im hooking them up to a jl 500...
    To do this they MUST be wired in parallel, IE: Plus to Plus, Negative to Negative. 2 4 OHMS in parallel is about 2 OHMS in series it would be 8 OHMS... series is positive to negative. Are you using a crossover network?
    Mar 05, 2010 | Kicker CVR12 Car Subwoofer
    I want to know the best subwoofer wiring diagram for three kicker cvr 10 inch subs, 2 of them are dvc 4 ohm and 1 is dvc 2 ohm, the amp that i am using is jl audio 500.1 1.5-4ohms stable. can anyone help...
    if the amp has a 2 outputs then i would wire the two 4ohms together, and the 2ohm by itself. and if its a 4 channel output then wire them all sepretly, if its a 1 channel output then wire the two 4ohms together and leave the 2ohm sub out
    Nov 29, 2009 | Kicker CVR10 Car Subwoofer
    NOT SURE WHAT OHMS SUB I NEED!
    if you get the 4ohm you can wire it to run a 2ohm an the kenwood amp will push 900 watts at 2ohms.they say it can push up to 1800 watts,that would be at 1ohm.that kenwood runs 500 at 4ohms an 900 at 2ohm.if you need help wiring the sub or anything else let me know bertman285@hotmail,com Max Power Output 1800W Power Output 4 Ohm [14.4V] 500W x 1 [20-200Hz, 0.5%THD] 2 Ohm [14.4V] 900W x 1 [100Hz, 1.1%THD] Bridged[4 Ohm] -
    Oct 09, 2009 | Alpine Type-R SWR-1242D Car Subwoofer
    Bridging amp/sub
    wire speakers in series google it to find diagrams
    Jun 30, 2009 | Car Audio & Video
    Wiring 12" icmb-5612 preformance teknique subwoofer
    That sub has dual 4-ohm voice coils. It can be wired either as 2-ohm, 4-ohm, or as 8-ohm.
    2-ohm = voice coils in parallel (both positives and both negatives connected to your speaker amp out wires).
    4-ohm = use only 1 voice coil (either is OK).
    8-ohm = voice coils in series (connect the positive of one voice coil to the negative of the other and connect the remaining positive and negative to your speaker amp out wires).
    Mar 24, 2009 | Performance Teknique ICBM-5612 Car...
    I have a Kicker 08S15L72 15 dual 2-ohm need it wired for 4 ohm
    ok im going to try to explain this you have 2 voice coils , i will refer to as vc1 and vc2, you take vc1 positive and connect to vc2 neg then use vc1 neg and vc2 pos to the amp according to pos and neg signs.
    Feb 22, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
    500/1 settings to run jl13w6 v2 d-4
    Just had a look at both amp and sub on the JL Audio website. The amp runs from 1.5-4ohms. 4ohms at 14.5V. The sub is running dual 4 ohms coils. That's what the D-4 means. So should be an easy set up. The amp has two mono outputs, so one for each coil. It looks like the perfect wattage to run the sub real nice.
    Web page for amp: http://mobile.jlaudio.com/products_amps.php?amp_id=439
    Web page for sub: http://mobile.jlaudio.com/products_subs.php?series_id=18
    Nov 19, 2008 | Jl Audio 1000/1 Car Audio Amplifier
    SPL Audio Phantom DK2-1000 Car Amp Logo
    82 people viewed this question
    Top SPL Audio Car Audio & Video Experts
    xxxxxx xxx
    Are you a SPL Audio Car Audio and Video Expert? Answer questions, earn points and help others
