Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Nothing happens after filling up
After washer fills up it does not spin of drain (btw it is a whirlpool lsn3000pws) i have always had to push down on lid, to get it to work i have looked all over for the pin that goes down with the lid switch but i cannot seem to find it
  • Whirlpool Master
  • 3,361 Answers
The missing pinis more than likely your problem.
Take a pencil or small screwdriver and insert into the lid switch hole and try the washer.
If it works, replace the lid pin.
If not, replace the lid pin AND the lid switch.
Posted on Apr 22, 2009
Whirlpool washer won't wash or spin or dump water
usually a broken lid switch if it fills with water and then nothing,set the timer on spin and pull out the timer,open the lid and stick a screw driver into the hole where the plastic acuator on the lid goes into the hole and push down easily and see if washer will run this is where the lid switch is and it's only a safety switch so when the lid is open the washer won't run,if not push up and down on the switch and listen for a clicking sound,no click switch is bad part number 285671,watch video
http://www.youtube.com/watch?v=Ag1eT5PrMnE
Apr 06, 2013 | Whirlpool Washing Machines
RCA Whirlpool Model LSQ9665J will fill with water but does not agitate, spin, or drain on any cycle. Was working fine yesterday.
put the timer on spin,open the lid,with a screw driver push down on the lid switch,if the washer starts to spin and drain the lid switch is bad,also if nothing happens,lift up and push down on the switch if you don't hear a clicking sound the switch is bad,all it is is a safety so the washer won't run with the lid open.part number 3949247 and the lid switch is around 40 dollars,
Apr 02, 2011 | Whirlpool Washing Machines
Whirlpool washer WTW57ESVW0 won't fill with water. I bought this machine two months ago was working fine and then just stopped filling water. Spin cycle and drain cycle work but it won't start fill...
Solution for WTW57ESVW0 Whirlpool Washer that won't fill or agitate, but will spin and drain water.
Replacing the Auto Load Sensing Switch (W10177795 - Illus. No. 12 on Control and Rear Panel Parts) fixed the problem.
In addition, a defective switch can also cause the machine to start agitating while it is filling.
It is relatively easy to replace and there are online videos that can help with the replacement.
Oct 27, 2010 | Washing Machines
Washing machine fills, but will not agitate, drain or spin
Coupling broken which joins the motor to the gear box. Look and see or listen if the motor is running then if nothing else is working coupling is broke, easy to replace.
Dec 05, 2009 | Whirlpool LSR5132PQ Top Load Washer
I have a kenmore series 70 washer, top loading. It filled up with water and then stopped. I have tried other cycles, but nothing happens. The water won't drain and there are no noises. Nothing happens no...
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.24712300
Also see the Whirlpool Service manual for top load, direct drive washers including test procedures and a troubleshooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If you manually move the timer to the spin cycle and it drains and spins, the motor and transmission are OK.
If it won't do anything after filling, the problem points to the timer or motor.
It is relatively easily repaired but you'll have to decide if the cost is worth the repair.
Personally, I tend to fix rather than replace so I'm probably not the one to ask.
Oct 31, 2009 | Kenmore 24712 Top Load Washer
22432 won't spin or drain
CHECK THE LID SWITCH THE PART THAT PUSHES THE SWITCH DOWN MAY BE WORN ENOUGH TO CAUSE THIS PROBLEM. WITH THE LID OPEN START THE WASHER IN THE SPIN CYCLE AND PUSH THE SWITCH WITH A POPSICKEL STICK AND SEE IF THIS PROBLEM STILL HAPPENS
Aug 30, 2009 | Kenmore 22422 Top Load Washer
Whirpool washer wont work
The lid switch, get something to hold it down to make machine work. Turn machine on and push down on lid.
Jul 26, 2009 | Whirlpool CAM2752KQ Top Load Washer
The washer will fill up with water but won't complete the cycle or drain. This has happened before, and I would spin the knob a few times and switch the load size selection. It always randomly started
it sounds like a bad timer there....! if after you selected a different load it drained......!
if it didnt drain at all on any mode I would say a bad lid swtich.
May 27, 2009 | Maytag Washing Machines
Thin-line will not stop filling with water
is it filling and draining at the same time ? if so take the drain house out of the stand pipe (wall) make sure it is oinly in 5-6 inches if it is in too far it will create a syphone where it will fill and drain at the same time and never advace the cycle. you should always hear water going down the drain if you can't it is down too far. let me know how it goes
Apr 16, 2009 | Whirlpool LTE5243D Top Load Stacked...
Washer makes noise but, wont drain or spin
Check the lid switch (the part that gets pushed down when you close the lid). Try pushing it down with something. If you do not hear it make a CLICK sound, then it needs to be replaced.
Note: ALWAYS unplug appliances before attempting to make any repairs!!
Mar 14, 2009 | Kenmore Washing Machines
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
199 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
