Question about Qca Spas Dream Series Dream Master Hot Tub with Flex Cover
New set up
Plug into 110 outlet trip breaker I reset breaker but now Spa will not come on at all cord will not reset itself any suggestions???
  • Jimmy James May 11, 2010
    Is there another reset on the tubs motor?
    New Friend:
  • 77 Answers
Do you have power at outlet? If yes, check for 120v at control pack (follow cord to terminal board ). If no power at terminals and gfci on cord won't reset then power cord is defective. Replace
Posted on Apr 22, 2009
Answer not provided. Please read my question.
is it 110 or 220? if it is a 110 first check your breaker/ fuse panel for tripped breaker or blown fuse if 220 it would be a double breaker. if you find tripped breaker remember some panels require you to turn the breaker fully off then back on to reset. if 110 and no blown breakers, check your laundry room for a GFI (ground fault interrupt) outlet. make sure that it is not tripped either. to reset that just push the reset button on the outlet. best of luck to you
Nov 19, 2015 | Dryers
Why the circuit breaker keep trowing off ?
Could be a short in the cord somewhere. This will keep tripping the breaker. If you can check the socket and plug for loose wires or check for damage along the cord.
Jul 25, 2014 | Rule 1800 H53SP-24 Swimming Pool Cover...
Trips breaker
I would suggest looking at the heating element for current leakage
Apr 04, 2014 | LG WM2655HVA 3.6 Cu. Ft. Graphite Steel...
When i plug in motor humbs and then kicks bracker
More than likely you have it plugged into a standard wall socket and the breaker that the spa is on has other things like lamps or blenders on the same breaker. If you have a hot tub plugged into a standard outlet you need to be sure it's the ONLY thing on that breaker or else it will trip. Your outlet is 110 and that spa need 120 so it's pushing it to begin with.
Feb 28, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
White springs spa wiring diagram and troubleshooter
120Volt or 240Volt?
Hardwire or plug-in-outlet?
Where is the GFCI? On the outlet or on the breaker?
Here is a starter:
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/How-to-wire-GFCI.html
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Are you connecting a new spa?
Or is old spa having problems?
Exactly which problems?
Or if the element getting wet and causing GFCI to trip?
Is circuit breaker tripped?
Add a comment for live response 11-7-12
Nov 06, 2012 | Pool & Spa
Ran over power cord and now won't start with new cord.
did the breaker on the plug your using trip?do you have a gfi outlet that tripped?
Jul 01, 2012 | Garden
No power to microwave
Hello
Check the Power Cord
Verify that the power cord is properly connected the outlet; the plug might have been removed to make way for another appliance. Do not connect the microwave to an outlet via an extension cord or plug adapter; the oven must be directly connected to an outlet.
Switch the Outlet on
Turn the outlet on, if possible, using the switch on the wall behind the counter or on the plug itself. Some microwaves have a separate power switch that must be in the correct position before you can begin cooking.
Reset the Oven
Unplug the oven, wait a few seconds and reconnect the power. A power surge could have temporarily rendered the oven inoperable. The oven should start up as normal when you connect the plug to the outlet.
Check the Fuses and Breakers
See that the fuse or breaker protecting the oven's circuit is still active. Replace the fuse if it has blown, or reset the breaker to restore power to the oven. Stop using the microwave if it repeatedly blows fuses or trips breakers.
Oct 04, 2011 | Microwave Ovens
I pluged the microwave in it was working and when I pushed it back and when I looked at it it waqs not working any moren mdl # is 87449 kenmore counter top microwave
Check the outlet it is plugged into. Remove the microwave plug. If you don't have a voltage meter handly to test the voltage at the outlet or the continuity of the microwave plug, I would suggest you plug in a lamp from your living room into the outlet. If it doesn't work, either the outlet is a tripped (GFIC) Ground Fault Interuption Circuit outlet or the circuit breaker tripped in your electrical panel box or the microwave cord is damaged and caused a short and blew the fuse. To check these I would try plugging the light in and press the red reset button located on the wall outlet or flip tripped circuit breaker in panel. If it's a damaged cord or fuse, you can visit this web site for Sears parts www.searspartsdirect.com If you found any of these suggestions helpful, please rate my solutions. Thanks D. Lange
Apr 23, 2009 | Microwave Ovens
Qca Spas Dream Series Dream Master Hot Tub with Flex Cover Logo
199 people viewed this question
Top Qca Spas Pool & Spa Experts
Ian Kime
Ian Kime
byrdhaus188
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
