Question about HP LaserJet P2015dn Printer
Hp lj 2015 jam led stays on
What could be the problem
  • 3 more comments
  • Anonymous Apr 14, 2009
    Light stays on constant.
  • John Hill Apr 21, 2009
    I have exact same problem
    Also - Occasionally when Powering off and on again I get Paper Jam and Toner Light remaining on constantly
    Plug via USB into PC an get the error message:
    "Your USB device has malfunctioned... ...Contact your system administrator"
  • jcorrell Apr 22, 2009
    According to the HP printer user forums, this is a formatter issue. Either replace the formatter or send the printer back to HP if it is still under warranty. http://forums13.itrc.hp.com/service/foru...
  • p_hofland May 17, 2009
    When I turn on the printer, the paperjam light comes on immediately. There is no paper in the printer (the printer is competely clean). How can i solve this problem. (reset by turning the printer on/off does not help).
  • Danny Sells May 21, 2009
    I tried another formatter and it worked like a charm. Thanks
    Problem Solver:
  • 5 Answers
Judging by my personal experience with these printers...if there really is no paper jam, you are most likely looking at a bad formatter board. Very common issue with these printers.
Posted on May 20, 2009
    Novelist:
  • 102 Answers
Take the Tray 2 out and check if all the paper guides are moving freely if they are than remove the toner cartridge and check if any toner sensor is not align correctly.
If they are aligned correctly than next to the pickup roller there is a small piece of plastic make sure it should be hanging freely if it is than we need to perform cold reset of the printer.
Switch off the printer press and hold down the go button and switch the printer on keep holding down go button till the time three lights lit up on control panel, as soon as three lights lits up release the go button and let the printer initialise of it s own.
If that doesn't fix than Formatter Board of the printer is faulty.
Logic:
If there is no paper jam and printer rep[orts the jam means either any of the sensors is not aligned correctly and reporting the jam or formatter Board(Motherboard) of the printer is faulty and showing incorrect display.
Thanks and Regards
Posted on Jul 03, 2009
How do I solve this problem? My hp LJ 4345 printer experiences intermittent paper jam in fuser(accordion-like) with half of the paper out of the fuser. We've replaced the fuser with a new one but the
This error can be caused by the following:
1. Fuser that is close to end of life. Maximum print quantity is 225,000 pages.
2. poor quality paper, very thin paper never feeds well and will jam.
3. Printing an image that is almost entirely black can cause the paper to buckle before entering the fuser.
Try different paper to see if that resolves the problem.
Sep 02, 2014 | HP LaserJet 4345mfp Printer
HP LJ 4L paper jam light flashes indicating a peper jam after printer makes a grinding noise. What can be the problem?
You may be right about the worn gear as a factor but I used to have a LJ 4 and whenever it indicated a paper jam it was always right. In some cases, the jam was a tiny scrap of paper deep inside. It took a flashlight and examination of every bit of the paper path to find it
Nov 02, 2012 | HP Black Toner for LJ4L & 4P
I have HP LJ 2015D all lights stay on except paper load LED, How to fix it
Logic:
Thanks and Regards
Feb 27, 2009 | HP LaserJet P2015dn Printer
Low toner & paper jam light stays on. no paper jam seen. ink is new & still printer does not work
There is a problem with the HP 2015 printer. The symptoms you describe are a common fault requiring the printer to be returned to the HP repair centre.
Out of a batch of 40 2015 printers, we have had to return 9 so far for the same problem. 2 of the 9 have been back twice... The printers come back with new MAC addresses and this suggests that the main motherboard is being changed.
Feb 03, 2009 | HP LaserJet P2015dn Printer
LJ 2015
pull off the left side cover from the rear and the formatter is there order one from hp partsurfer.com
Jan 08, 2009 | HP LaserJet P2015dn Printer
HP Laserjet 1320n Error Lights not in Manual
hi friends......
shivachadra is here.....just i faced this problem "Attention, Ready, and GO LEDs are on solid"
and i got solution in troubleshooting....just vi refixe the connetion of laser scanner........its the error of comunication between laser scanner and formatter....
May 27, 2008 | HP LaserJet 1320 Printer
Hp lj p2015d printer
this could be your formatter board problem.. might need replacement
Apr 26, 2008 | HP LaserJet P2015dn Printer
HP LJ 1020 Output Page Jams @ Fuser input
either your fuser is bad or output rollers, I put my money on the fuser
Mar 26, 2008 | Office Equipment & Supplies
HP laserjet P2015D , JAM LED in a solid state ??
Dear gentlemen,
Hope this helps you sort out the problem. Please check paper jammed pieces of paper remains from paper in to out paper path. Check if the paper is properly picked-up, else check rubber roller pick-up and the solinoid motors that control to fed on and off the tray to engage pick-up. Check paper path sensors if possible. If you can determine when is the paper Jam happens please advice. Other means you can also refer your manual and machine diagnostic menu which part of the operation the paper will jam.
Best regards,
Rosener Guyano
Jan 10, 2008 | HP LaserJet P2015dn Printer
HP LaserJet P2015dn Printer Logo
1,312 people viewed this question
Ben Johnson
