Question about Logitech QuickCam Fusion 961403-0403 Webcam
Unable to transmit video image on MSN live messenger
Have a Vista Home Premium system -- just purchased and installed a Logitech Quickcam Fusion. Originally installed using supplied CD. Uninstalled after consultation and a Logitech web program installed. Camera can work in quick capture but will not work (except for the mike) with MSN windows live messenger. Can you help???
  • Anonymous Nov 14, 2007
    same problem except with yahoo...
  • aidz_padul Aug 10, 2008
    i cant connect to yahoo
    Sergeant:
    Champion:
  • 293 Answers
Have you tried updating MSN Windows Live msngr?
Posted on Sep 21, 2007
My logitech webcam won't work in msn messenger....in messenger when i try to make a video call...it says I need to buy or install a webcam? what's the deal? heeeelp
Hi Marilyn,
Have you installed the Logitech Quickcam program? If you did then open the application and select the instant messenger(i.e. MSN, SKype, Yahoo) that you will be using the camera.
If you have note yet installed the Logitech Quickcam application then I suggest you disconnect the webcam and run the software first.
Oct 28, 2010 | Logitech QuickCam Communicate STX Personal...
My webcam does not work on msn
first you need to know that if you used xp ...and upgraded to vista ...you need to find a compatible driver for your web cam too ...if your web cam used to work just fine on vista ...and its just the msn issue ...just reinstall the latest MSN messenger and it should be enough ...also verify the proxy servers on the messenger preferences..and set 'em to fit the kinda conexion you use...
but I suspect a problem with the program settings ...so the easy way is just to install the latest messenger(MSN) available for vista ...and it will be ok
May 17, 2009 | Logitech QuickCam Pro 5000 Webcam
Logitech QuickCam communication with MSN messenger
See C. Windows Live Messenger in the info below.
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video shoud work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Jun 24, 2008 | Logitech QuickCam Communicate STX Personal...
Haveing trouble installing logitech quick cam onto my comuptor thats running windows vista
This problem was caused by a compatibility issue between Windows Vista and Logitech QuickCam Messenger.
Logitech QuickCam Messenger was created by Logitech, Inc..
Recommendation
To search for similar devices that are compatible with this version of Windows, visit the Windows Vista Hardware Compatibility List website online.
However, it’s not totally out of hope for owner of Logitech QuickCam Messenger who has upgraded to Windows Vista. The following hack will use Windows XP driver (a common trick to use non Vista compliant device) to install the webcam in Vista:
  1. Download QuickCam 8.4.8 with driver for WinXP.
  2. Install WinRAR if not already installed yet.
  3. Open the setup installer qc848enu.exe and unpack its contents to a folder. Alternatively, right click on qc848enu.exe and select “Extract to qc848enu\” option.
  4. Insert or plug in the Logitech QuickCam Messenger to a USB port if not already done so.
  5. An “Driver Software Installation” icon in systray (notification area) should appear, which will pop up detailed message if click. It should fail, and “Add Hardware Wizard” dialog window will appear. Choose to install the driver manually by instructing the Wizard to locate and look for the web cam driver inside the Drivers folder under the unpacked folder of the qc848enu.exe setup program. You can use browser button to select the folder.
  6. Windows Vista should grab the XP driver and install it properly.
  7. Download the latest version (10.5.1) of Vista compliant QuickCam software from Logitech to install the software on Vista.
  8. Run the setup (qc1051enu) normally. You may need to skip the detection of webcam near the end of installation process.
Voila, you can now use the Logitech webcam to capture images or use it in conjunction with video chat in IM programs such as Windows Live (MSN) Messenger, AIM Messenger, Yahoo! Messenger, Skype or run Logitech VideoCall.
i hope thist post can solve your problem
thank's
cropp
Mar 14, 2008 | Logitech Webcam
I can't get my logitech quickcam chat to instal...
Which cameras are compatible with MSN 6.0?
Below is a list of cameras that are compatible with MSN 6.0:
ClickSmart™ 820
ClickSmart™ 420
QuickCam® Cordless
QuickCam® Messenger
QuickCam® for Notebooks Pro
QuickCam® Pro 4000
QuickCam® Zoom
ClickSmart™ 510
QuickCam® Traveler
QuickCam® Web
ClickSmart™ 310
QuickCam® Express
What are the Minimum System Requirements?
The minimum system requirements for MSN 6.0 are the following:
  • 233MHz processor or faster (500MHz recommended)
  • Microsoft Windows 98, Windows 2000, Windows ME, or Windows XP operating system
  • Minimum 64MB of RAM (128MB recommended)
  • Up to 50MB of hard disk space needed to install — after install, up to 15MB may be needed
  • 256-color VGA or higher resolution graphics card (SVGA recommended)
  • Minimum 800x600 screen resolution
  • Microsoft® Internet Explorer version 5.01 or later must be installed on your computer, though it does not need to be your default browser
Note: If you are not sure if your computer meets these system requirements, please check with your computer manufacturer.
Where can I download MSN Messenger 6.0?
Click here to download MSN Messenger. Note: If you experience any problems downloading or installing MSN 6.0, please contact MSN for further support.
Mar 02, 2008 | Logitech QuickCam Chat Personal Web Camera
Webcam not working
Try the following: 1. Install the latest drivers, which will have support for Vista. Your drivers are probably ment for XP and below. 2. You could also try with an installation guide for sound and video. Most IM has this function, i.e. MSN Messenger.
Mar 19, 2007 | Logitech QuickCam Communicate
Logitech QuickCam Fusion 961403-0403 Webcam Logo
181 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
