Usb connection Memory stick has problem with usb connection and will not power up. Several computers indicate same problem. Can the usb connection be repaired?
Does the problem happen with just that memory stick, or does the same thing happen if you were to connect something else to the computer?Does the problem happen with just that memory stick, or does the same thing happen if you were to connect something else to the computer?
You can't post conmments that contain an email address.
1. Confirm the USB port on the computer you are connecting your printer to is being recognized by your computer. The easiest way to do this would be to plug a known good USB Memory stick into the USB port you want to use. If you can read the contents of the USB Memory stick then the port should work. Remove the Memory stick, start the printer installation program (Make sure you don't the printer connected), want until the setup program tells you to connect the printer before you attach the Printer's USB cable.
If the printer isn't recognized try a different USB port, when picking a new USB port to try select a higher priority port, for example in increasing priority from, an external USB hub, a powered external hub, a monitor based hub, USB ports on the front of the computer, up to the USB ports at the computer rear. For USB ports on the same circuit select an USB 2.0 before an USB 3.0 port
Get an USB memory stick, plug it into the USB port on your computer. This USB memory stick will display as a disk drive, open this USB drive, then open the folder on your computer where the photos are stores, select the photos you want to print and copy them to the USB drive. Click on the Safely Remove Hardware icon on the task bar and select the USB memory stick then remove the USB memory stick when advised. You can then take this USB memory stick to Costco Photo Center to print these photos on several calanders.
Insert the memory card into a USB card reader and connect it into the USB port of your computer and also connect your memory stick into another USB port on your computer.You computer will detect both memory devices and you can click on them to open and view the files, then copy the photos on the memory card and paste them on the memory stick. If you have only one USB port then copy the photos from the memory card into your computer then connect the memory stick to your computer and copy the photos from the computer to the memory stick.
Find a computer with a disk-drive, and a USB port.
Connect a USB memory-stick to that computer.
Copy the files from the CD to the memory-stick.
Connect the memory-stick to your computer.
Install the software from the memory-stick.
for this ,use a MEMORY CARD READER .
Insert the memory stick into the Memory Card Reader and connect the reader via the USB jack/port to the computer.Go to "my computer",select the M CARD READER which may be indicated as "Removable disk "F".
Meanwhile select the pictures to b uploaded and right click the mouse to select ,"Move to"--removable disk "F"
when all pictures are uploaded ,remove memory stick and insert in camera to see the pics .
I'd try in different USB ports and even maybe on another computer first. If still not working, contact the manufacturer. If you truly mean 'Memory Stick', as in Sony's, you can find support options for repair or replacement. Alternately, you could attempt to go through a data recover specialist.
I'm assuming the docs are important. What I would try to do is buy an external reader which cnnects via USB and hope that it is the port on the computer that is not working.
Sony MRW62E/S1/181: an external memory card reader/writer that can address 17 different memory card formats. It sports a Hi-Speed USB 2.0 interface and draws its power directly from the USB connection. The MRW62E/S1/181 can be connected to both Macintosh and Windows computers. Cost is around $30.
You must have a memory stick to put music into your psp such as mp3 files, the psp itself does not have any internal memory for you to store any music files whatsoever.
if you got a memory stick already, connect your psp to your computer via usb cable, select usb under the setting section of your psp, and the memory stick drive will appear in your "my computer", so you can drag your music into the Music folder of your memory stick and play them from your psp.
as long as you have connected the usb lead and tried in different ports, make sure you are selecting USB Connection in the settings menu on the psp, it should then connect, but some older pc's may not have enough voltage sent to the usb ports to read the psp, if this is so you will need to buy a powered usb hub.
