Question about McCulloch Garden
Pressurewasher is leaking back by where the pressure hose is connected to the pump model no:fhh20c mcculloch
  • roberts57 Apr 14, 2009
    your solution worked fine , thank you
5 Suggested Answers
  • 497 Answers
SOURCE: builds up pressure won't spray
pressure relief valve is faulty. replace.
Posted on Aug 10, 2009
  • 174 Answers
SOURCE: Troy Bilt pressure washer model 020209 will not
A leaking gun will kill all the pressure. You may need to repair or replace the gun
Posted on Sep 17, 2009
  • 32 Answers
SOURCE: I own a McCulloch Model FH130B Hi Pressure Jet
A real good/knowledgeable hose shop in your area should be able to fab a replacement. Otherwise possibly check at a local contractor store like that of home depot for replacement short of investigating the mfg web site for authorized repair/service centers in your area.
Posted on Jan 16, 2010
mc1bean
  • 3053 Answers
SOURCE: water leak where the gun
Simple fix, just disconnect house end from washer, buy a new rubber washer o ring, like what is used for garden hoses. Put back on make sure it is tight. If still leaks, then need to replace connection end fitting on preside washer, can get those at almost any hardware store, use plumbers tape on threads when putting new fitting on machine, then connect house and back to those honey do list :)
Posted on Jun 08, 2011
It starts turns on but water will not come out of nossel???
Many of these devices have strainers on the input (garden hose connection) of the pump. Remove the hose and check and clear debris from strainer. Reconnect hose and turn on supply water. Do NOT start engine / motor. Pop the nozzle from the end of the wand and squeeze water trigger. Hose pressure water (or less) should flow from the wand. Of not, youll have to see if water is leaving the pump by inserting the nozzle (or something that will if it) into the hose connector. If water still does not flow - there is an issue with the pump.
May 18, 2015 | McCulloch Garden
Mccullough FHH18A - Looking for connector adapter/ size ?
Why not just purchase a new hose assembly?
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Jul 03, 2014 | McCulloch FHH18A Electric Pressure Washer
I have a mcculloch washer # fhh18a / fhh20c. pump will not turn on all of sudden.
I recommend contacting your local authorized service center for assistance.
Contact us
User manuals
McCulloch Service
Sep 13, 2011 | McCulloch Garden
My washer does not spray the cleaner solution as high as it did originally. The high pressure spray is fine.
If your pressure washer works like ours, it has a T connection.
A plastic hose comes off the T and goes into the bucket of cleaner
Pressure from the hose creates suction across the T and this draws cleaner into pressure hose
The plastic hose from cleaner connects to a small brass ball valve on the T
The ball valve clogs up or changes over time and cleaner will not draw up into the pressure hose.
We would replace the valve stem
I don't know if they sell the little replacement parts like they used to
Finally we had so much trouble.
We started applying our chemical with a pump-up sprayer.
For us, it was cheaper, and the work went faster.
We put one guy on the pump up sprayer
And then another guy came behind him on the washer.
Oct 25, 2010 | McCulloch FHH18A Electric Pressure Washer
1. Decrease in pressure. Can't clean deck properly. 2. Water leaking from underneath. 3. There is a short clear hose not attached to any thing. 4. I'm not a mechanic. I'm an x-ray tech and my...
If the pump is leaking then it is going to either be the water seals or o-rings on the inside of the pump. If this is the case I would recommend just tossing the unit, what it would cost to rip the machine apart and replace these items would be more than what the machine is worth.
Oct 15, 2010 | McCulloch FHH18A Electric Pressure Washer
I don't get enough water through the pump to keep it running with pressure. Pump cycles on and off.
unfortunately this is rather common problem, there is several solutions, none easy. i assume that you already cleaned inlet filter and connection hose is good diameter. check your mains if it is fully open (open tap in full then back half turn), same with tap connected to your supply hose. try to re-locate washer as close as possible to your mains connector. do bear in mind that these washers require at least 2gallons of water per minute (9 litres per minute)
if this solution do not work, or it is not feasible, find some 20 litres (5gallon) canister which can survive mains pressure, connect it with very short hose to your pressure washer and other end to mains, i know this is not an ideal solution but it will give you about 3min bursts.
if you find my advice helpful, please do not hesitate to comment and leave voe4 for me, thanx!
Jul 31, 2010 | McCulloch Garden
I can't find the directions and need to know how to get the cleaning solution to come out of the machine.
You can download your manual here:
http://weborder.husqvarna.com/order_static/doc/MOUS/MOUS2008/MOUS2008-FHH20C-7096H18A03-966990001.pdf
Instructions for chemical tank 1 and 2 use are on page 6. Wand must be in the low pressure position to dispense chemicals.
Thanks for using FixYa.
Kelly
Kelly
May 10, 2010 | McCulloch FHH18A Electric Pressure Washer
Which hose goes to which connection on a primer
Remove the primer pump line that goes back to tank and try to pump fuel from the carburetor (assuming that the primer pump is in good condition). If the hose connections to the carburetor are correct, you will be able to pump fuel from the carburetor. If it doesn't pump anything, reverse the two connections to the carburetor, and recheck the pumping process. Hope this helps!
Mar 21, 2010 | Garden
Where can i get a new hose for a1600 psi jet washer? Hose has a leak in it and we are not having any luck finding a replacement locally. Washer was purchased at either walmart or Canadian Tire.
I have an older Karcher Pressure Washer and I am unable to find the model number. This is the info that I have: 79C2, Volume 1.9, Pressure 1400, Serial # 800983493B, 120 Bar, 60 degree C,
QC506-877. I need the model # to order a replace gun and/or wand. thank you
Jul 14, 2009 | McCulloch FHH18A Electric Pressure Washer
Garden Logo
129 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
