Question about Belkin (F5D7231-4) Wireless Router
Belking router trouble
I don't know the specific model of my router, but it looks like this: It occurs that the holy router stops working every...say ~8 minutes. I don't know whats happening, but all i know is that i have to restart it periodically in order to use internet.
  • 1 more comment
  • Wolter Hellmund Sep 12, 2007
    Im working with a computer connected to it via Wireless...I guess iam connected to cable, but the issue is that all the lights fo off except the "on" light, and i have to go all the way to it to reboot it.
    I tried to update the firmware, because i don't know how to reload the firmware. Ill tell you if it keeps happening, or if the update fixed it.
  • Wolter Hellmund Sep 14, 2007
    It worked! Thanks so much....I'm going to mark topic solved...I hope that gives you some credit for your profile.
    Genius:
  • 1,139 Answers
Hello Wolter, Are you losing sync with your ISP or are you just not routing. Plus are you connected via DSL or Cable? These are important questions. In any event you might be experiencing line issues. Try this: log into your router write down the configuration information (for DSL: login and password to your ISP) press and hold the reset button on your router until it resets (all lights Blink) then reconnect and reconfig your login and password to your ISP BTW the router will revert to the default entry ID and password. Once the router is reset and the configuration has been restored try to use it.
Posted on Sep 12, 2007
  • Henry McKelvey
    Henry McKelvey Sep 12, 2007
    Ok I had a customer of mine go through this some time ago. It turned out to be the router. The system flash had become corrupted. Tyr to reload your firmware and see if this clears up the problem.
SOURCE:
I forget the password for my belking router
The suggested solution for this, is to reset the router by pressing the small reset button which will either be located on the rear or base of the router. You usually need a small pin or tip of a pen to press the button and depending on your model you might need to hold the reset button in for 5 -10 seconds.
After you have done this ALL SETTINGS WILL HAVE RESET but you will be able to set a new password and to prevent a future loss of the password it's suggested you make the next password something more personal.
If you have trouble, supplying me with the model number of the router you have, i can run you through step by step on how to do this method with your particular model of router.
Jun 05, 2013 | Belkin Computers & Internet
I had to reset my router because I forgot my security key. Now the wireless isn't working. The light is off and I can't connect to it with my laptops. What happened and how can I fix it?
It is possible that since your reset your router that the settings is more likely to be reset as well then you will have to connect using an ethernet cable direcly from the lptop to your router to turn on the wireless capability of your Belkin router.
You will need to get your router's Default gateway to get in the router and turne the wireless capability on it. Most probobly the IP address of your Belking would be 192.168.2.1 type this in IE on the address bar then press enter this should lead you into the router "Belkin" make sure that your are connected using ethernet from the laptop to your Belking router to be able to do this.
Feb 21, 2011 | Belkin (F6D42304) Wireless Router
How to solve my d-link issue?
You can try to reset the router.. While it's on, press the reset button for 15 seconds (do not release), then unplug the power cord, release the reset button, count 15 seconds then plug the power cord back, then press the reset button again for 15 seconds. Then try to reconfigure the router.
May 04, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Have a belking N+ router and cant get past my cable modem, any 1 know a cure.
If you connect the computer directly to the modem , does it work ?
If that is working then the modem must be working you will need to check the settings of the router.
Click Here for more info about how to set up router.
Aug 06, 2009 | Computers & Internet
Password on my belking
ya want to put password on my belkin
Feb 28, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
We've just moved house and have aquired to belking routers a belkin wireless pre n and a belkin ADSL G Plus MIMO I want to use the latter as a bridge how can I?
You need to access the setup page of your Belking router and go to the wireless setup, look fro Use as Access Point, now just a reminder this will defeat the NAT IP sharing feature of the router. Configure the IP address of the router to the same subnet as the network your tying to bridge here's the more detailed procedure:
1. Enable the AP mode by selecting "Enable" in the Use Access Point only page. When you select this option you can now change the IP Settings.
2. Set your IP settings to match your network. Click "Apply Changes"
3. Connect a cable from the LAN port of the router to your existing network.
Sep 18, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I need a list of routers/modems that will work with 360 live
BELKING
DLINK
MOTOROLA
THERE THE ONE I KNOW FOR SURE THAT WORK
Jul 02, 2008 | Video Game Consoles & Games
PSP internet connection problem please help!?!?
Check your router.Sometimes the router don`t allow the psp to connect.If you do have a friend with another router try to get access from him.If your friend router allow your machine to work you need to contact the router company and let them fix your problem
Jun 18, 2008 | Sony PlayStation Portable (PSP) Console
Conecting to wii
Let me understand you cant access the internet through the belkin router?
Do you know the ip address of the router?
What model belkin is it?
Jun 07, 2008 | Belkin (F5D5231-4) Router
My Belkin Software!
Try the Belkin WEB site or Google the driver
May 10, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin (F5D7231-4) Wireless Router Logo
108 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
