Question about Husqvarna Forest & Garden 125bt Backpack Blower
Husqvarna 130BT leaf blower - locked-up
Blower worked fine. Probably has 10 hours use. Hung up for last 4 months. Went to start - totally locked-up. Took off pull cord - problem not there. Won't turn. Suggestions?
Bob
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
If you stored it with fuel in it, the piston and cylinder may be stuck together. The old fuel turns to a gummy varnish. spray some WD-40 in to the cylinder through the spark plug hole and rock the flywheel back and forth to break it loose. Then flush the fuel system and carburetor. If that isn't the problem, remove the muffler and inspect the piston, rings, and cylinder for vertical scoring, if scoring is present a top end rebuild may be necessary.
Posted on Apr 13, 2009
Worked last weekend will not start
Need more info. Is it getting gas? You can check this by squirting some fuel into the carb or spark plug hole and cranking it. If it tries to go, then it is getting gas. (Be sure to put the plug back in though). We can work from there. . .
Mar 25, 2014 | Husqvarna 130bt 130 Bt Gas Powered...
It won't start
How long has the gas been in the Blower?
If it was 10% Ethanol gas( lie most States sell at the gas pump) and it has been in the Blower for more than a few months, you probably have carburetor issues.
Oct 25, 2013 | Husqvarna 130bt 130 Bt Gas Powered...
Carburetor
either carburetor needs cleaning or check the Flame Arrestor on the muffler...they clog and engine can't Rev high
Sep 08, 2013 | Husqvarna 130BT 29.5CC Gas Leaf Blower...
Picture of timing marks on briggs 6.5
Maintenance diagram od Husqvarna 130BT timing gap settings.
Apr 05, 2013 | Husqvarna 295cc Back Pack Blower HVH 130BT
HUSQVARNA 130BT GAS BLOWER STARTS FINE, BUT LOSES POWER WHEN I TRY TO USE????
Sounds like a fuel starvation problem, Strip and clean carb. Avoid using airlines to clean carbs. remove low and high adjustment screws, reset to factory settings. Walbro carbs are generally scew both of them back in all the way and then turn out 2 full turns each anticlockwise.
Mar 02, 2013 | Husqvarna 130bt 130 Bt Gas Powered...
Huskvarana blower 130BT starts but will not stay running
Fueling issue, check primer bulb and fuel line for air leaks, and possible clean and service card.
Dec 27, 2012 | Husqvarna Garden
My 130bt blower with start an idle fine but wont rev up
adjust the high speed screw on the carb. It is marked with an "H".
Nov 07, 2012 | Husqvarna 295cc Back Pack Blower HVH 130BT
My 130bt blower stops reving after several minuets. Will start but not rev after running fine for 5-7 minuets?
Hi and welcome to FixYa. I am Kelly. The next time it does this... loosen the gas cap a lot momentarily for about 10 seconds then tghten it and attempt a restart. If if starts right away again the gas cap is bad. It is supposed to breathe via a rubber seal in the cap. There are 5 parts in the cap. If it can not breathe the gas tank goes into a vacuum as fuel drains and you will experience fuel starvation.
Also check inside the fuel tank for debris.
See this link http://www.jackssmallengines.com/help.cfm#Home
Click on
Husqvarna Power Equipment
Blowers
130BT (I used the 2001 - 2007) There is also a 2008-2010 choice
and then click on Fuel tank a.s.s.y
I suspect the problem is either going to the the fuel cap or the fuel filter.
Thanks for choosing FixYa,
Kelly
Nov 10, 2010 | Husqvarna 295cc Back Pack Blower HVH 130BT
Husqvarna Forest & Garden 125bt Backpack Blower Logo
1,617 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
