Flat Panel Televisions
Problem for Flat Panel Televisions
Generic problem for all Flat Panel Televisions
Remote code
By chuckcass on Sep 12, 2007
we just bought a used tv and have direct tv and need a code to put into the direct tv remote. it is a poloroid lcd 32 inch flat screen with hd capability. please send all possible codes ,chuck
Solution #1
posted on Jan 25, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have a Polaroid 32" LCD flatscreen.
11250 worked for me.
--Wayne
Solution #2
posted on Aug 14, 2009
Not Rated)
paris7162
Rank: Apprentice
Rating: 0%, 0 votes
Use the search function, but don't give up. It takes about 20 minutes to find the correct code.
Here are the instructions
  • Set the "Mode Switch" to the desired mode such as TV for a Television.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the code "991" followed by the "device number"
    1. for Televisions
    2. for "AUX 1" devices - VCRs or DVDs
    3. for "AUX 2" devices - Audio
  • You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
  • You can try out each code by pressing one or more function keys such as power, volume or digit keys.
  • When you've found the setup code that works for your device, press the "Select" key.
Was this helpful?
Yes
No
Popular Solutions for Flat Panel Televisions
Questions and Unsolved Problems for Flat Panel Televisions
Answer
What is a good still camera to buy?
Answer
I have a Vizio SV421XVT and the SRS TruVolume does not work. When changing from channel to channel... (More)
Answer
I would like to run my Toshiba 15LV505 w/o a FIOS set-top box. FIOS says a QAM tuner enables... (More)
Answer
We have a 2 year old projection TV, we replaced the lamp about 2 months ago and now without warning... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
