Question about LG DLE2532W Electric Dryer
Gibson electric dryer doesnt heat up
Heater element shorted against the back when I was removing the drum for maintenance (yes I should have shut the power off) :) I saw a few sparks and the element heated up briefly.
Dryer works now after reassembly but wont heat up at all, I took it back apart, ran it and measured 120VAC per terminal measured to ground at both the terminals that attach to the heater element and the heater coil passes a continuity test.
any ideas??
thanks
  • Wayne Moore
    Wayne Moore Apr 13, 2009
    sorry I posted this in the wrong area :(
  • Wayne Moore
    Wayne Moore Apr 17, 2009
    It turned out to be one of the main wires was loose, after I tightened it up bang, it worked
  • 77 Answers
You may have shorted you thermal fuse. or the overload that is attached to the element housing. Good luck.
Posted on Apr 13, 2009
Element turns on even if door is open. at end of drying cycle drum shuts down but element stays hot
Your problem is usually caused by a bad/broken heating element. What happened is the element broke or burned apart at some point and the broken end has grounded against the dryer body. Instead of the power going through the control system and shutting off the heater, the power is going through the broken part of the heater and then to the dryer body with no shut off point like a direct circuit. Probably needs heater replaced. Could also be one of the controls stuck but usually the 1st problem I stated..
Mar 28, 2015 | Maytag MED5770TQ Electric Commercial Dryer
Why doesn't my electric wall cosy fire give out any heat.
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or
overheating.
The heating elements are located inside the heater ducts. If you think a heating element is faulty, test it with avolt-ohm-multimeter (VOM)set to the RX1 scale. Disconnect the leads from the power terminals and clip one probe of the VOM to each terminal. The meter should read about 12 ohms. If the reading is higher ohms, the heater is faulty and should be replaced. Replace a faulty heater with a new one of the same type and electrical rating. A heater connected to a 115-volt line usually has an 8.4-ohm resistance; a heater connected to a 220-volt line usually has 11 ohms resistance.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!!
Oct 05, 2014 | Dryers
What might be wrong with my Kenmore dryer which doesnt heat? The drum turns but will not heat.
GOD IS STILL GOOD !!!!
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Sep 29, 2014 | Dryers
Electric dryer runs shuts off then starts again on its own
This could be a bunch of different things. #1 detach dryer vent and clean out. Try running dryer with vent not attached for 10 seconds. (Warning, lint and sand will likely come blasting out the back. Reattach and try. #2 Likely is that you have lint buildup inside. Unplug dryer. Remove back cover. Clean air path from exhaust through lint trap. Look inside or remove heater as well. You are likely overheating the dryer and the sensor is shutting it down. #3. Unplug the heating element and then run dryer. Does it shut off still? No Then the sensor on the heating element is bad. Yes then the timer is bad.
Jan 13, 2014 | KitchenAid KEYS750LQ Electric Dryer
Where is the igniter located on dryer
An easy answer: gas (natural gas) dryers have igniters, but your electric dryer has no igniter,
instead it has a heating element (a zigzag arrangement of wires similar to that found in a space heater). Remove the back of the dryer - the heating element will be enclosed in an air duct that feeds heated air into the drum via a vent at the top back of the drum.
If you look into the drum, you can see the vent cover that covers the heated air inlet at the top back of the drum.
Sep 12, 2011 | Whirlpool LER4634J Electric Dryer
My dryer stopped heating and i changed the vuse and blow again can u tell me whats the problem thank u
The blown fuse is most likely caused by a short circuit in the dryer.
The first component I would check is the heater element as this is a highly stressed component in any electrical appliance.
Replace the blown fuse, then disconnect the wires to the heating element( Make sure you insulate the wires so as not to cause a short circuit against the dryer body).
Now turn on the drier & see if the fuse still blows. If it still blows, the problem is then most likely with the drum motor.
If it doesn't blow, you have only to replace the heating element.
Best wishes,
Graemevm
Apr 12, 2011 | Dryers
How to replace ge dryer heating element
you will need to remove the drum for this one.  once it is out, the element is mounted on the back of the unit.  not a hard repair, just lay out the parts as you take it apart to give you some order as you re-assemble it.
Aug 03, 2010 | GE Profile Wizard DPSE592EAWW Electric...
I'm trying to remove heater element from Whirlpool dryer
The element is held in place by 2 8mm bolts and once removed the element will slide out.
Jul 28, 2009 | Whirlpool LEQ8000JQ Electric Dryer
Just quit drying clothes
If it does not dry them all then the element is a good guess or the thermostat.
If it dries them but not all the way check that the moisture sensor is not turned down too far.
The following should help you.
How to Repair Heating Elements A dryer sometimes won't heat or heats too slowly because of a variety of reasons. By following the guidelines below, you can inspect the heating elements on a gas or electric dryer to pinpoint the source of the problem.
Troubleshooting the Gas Heater
In a gas dryer, heat is provided by a gas heater that is controlled by an air shutter. The gas heater is generally the source of no-heat or drying problems. You can often correct such problems by adjusting the air shutter on the gas burner, which is located along the bottom of the dryer.
To adjust the shutter, take out the screws and remove the panel that covers the gas flame. Turn on the dryer so the flame is burning. If the flame has a deep blue color and you hear air whistling around the burner, the air/gas mixture is receiving too much air. If the flame has a yellow tip, the mixture is not receiving enough air. Turn the thumbscrew or loosen the two screws slightly to increase or decrease the flow of air to the burner. Keep turning until the flame is a light blue color, without any yellow, and the whistling stops.
Gas dryers use an electric ignition device rather than a pilot light to light the gas heater: An element becomes hot and glows like the filament in a lightbulb. Electric ignition systems are always sealed; you can't adjust or repair them. If an electric ignition device fails, call a professional service person for replacement.
©2006 Publications International, Ltd.
In a gas dryer, heat is provided by a gas heater, controlled by an air shutter.
Electric dryers have self-contained electric heating elements.
Servicing the Electric Heating Elements
Electric heating elements, found in electric dryers, are self-contained units located in the back of the dryer. A defective heating element is frequently the source of no-heat or drying problems. Remove the back service panel to gain access to the elements.
The heating elements are located inside the heater ducts. If you think a heating element is faulty, test it with a volt-ohm-milliammeter (VOM) set to the RX1 scale. Disconnect the leads from the power terminals and clip one probe of the VOM to each terminal. The meter should read about 12 ohms. If the reading is higher than 20 ohms, the heater is faulty and should be replaced. Replace a faulty heater with a new one of the same type and electrical rating. A heater connected to a 115-volt line usually has an 8.4-ohm resistance; a heater connected to a 220-volt line usually has 11 ohms resistance.
The heater may also malfunction because it's grounded. To test for this, set the VOM to the RX1 scale and remove the leads to the heater. Clip one probe of the VOM to a heater terminal and touch the other probe to the heater housing. The meter needle should jump to a fairly high reading. If the needle flicks back and forth at a low reading, the heater is probably grounded and should be replaced. Here's how to replace the heater:
Step 1: Remove the back of the dryer. If necessary, also remove the cabinet top.
Step 2: Disconnect the leads and remove the screws that hold the duct in position. Then lift the entire heater unit out of the dryer.
Step 3: Remove the screws that hold the heating element in the duct.
Step 4: Slip the new heating element into the heating duct the same way the old one came out. Be careful not to damage the resistance coils. Replace the screws that hold the heating element in the duct, reconnect the leads, and screw the unit back into position.
Servicing the Fan
The most common dryer fan problem is lint clogging the air passages through the heater and through the dryer drum. To clear a clogged air passage, remove the back service panel of the dryer and back out the screws holding the air duct in place. Then reach into the duct and remove all the lint and dirt possible. Reassemble the parts.
Also inspect the fan for a loose screw connection where the motor shaft is set on the dryer's drum. Remove the back service panel, tighten the screw, and replace the panel.
May 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Wire Scraping sound and sparks inside rear dryer drum area.
Probably the rear bearing has failed and caused the drum to rub against the heating element. Hey, is this the guy that said he heard a noise last month? LOL
Feb 01, 2009 | Frigidaire GLEQ2152ES Electric Dryer
LG DLE2532W Electric Dryer Logo
168 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
