Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Green flashing light
I had been given the WD-52525 by a friend. had trouble every now and then with the timer light not allowing the tv to turn on.I would either reset and when that did not work unplug and it would work fine. until the indicater for the bulb came on and I replaced that. (would not work) got advice to change capacitors( did that) It had a leaker and a bulging 3300uf. I replaced with same but used a 16 volt. Put it back together and here I am, with a blinking green light.
Your help would be very much apprieciated. Ken
    Novelist:
  • 159 Answers
  • If the two capacitor you replace are 35v nominal value and you installed a 16 v. i would get the other ones imm. This capacitors you replaced are really really important. A down value could be not enough voltage rate for this guys who are feeding at least 30 IC,s around the set. (double check polarity)
  • I know is anoint but the job you did to get those caps out required to basically open a bible of circuits. Check your connectors in between the block (remember the tv was working before you open it)
  • sit comfortable to do this job many conectors could unplug specially up and down or any where.
  • Good luck! great job to defeat this problem.
  • There is dessert: If at the end you get the tv working and the tv looks pale or dimm or not powerfull colors. (no, stop, dont open it again, at least at the bottom) this is a cleanning in the reflexion area so start releasing the screen from the set. Clean mirrors. bye.
Posted on Apr 17, 2009
Green light flashing on TV. Cannot get it turned off. No pictur
Did you get yours resolved? I had the same thing. The repair guys called it the "flashing light of death". It indicated the TV is dead.
Jul 13, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Flashing timer
Replace the DM capacitors. The V26 DM repair kit from www.tvrepairworld.com should fix that issue. The kit also contains the CD with instructions.
Jan 07, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Blinking Green Light of Death on Mits WD 52525
The V26 DM repair kit will usually repair that issue. You can get the kit at www.tvrepairworld.com the kit contains the replacement capacitors and the CD with Instructions.
Nov 25, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi TV green flashing timer light after power outage.
You will need to cahnge the capacitors on the DM board, very common problem. The V21 V19 DM repair kit at the following link contains the replacement capacitors and detailed instructions. Its listed under the repair kits catagory at the following link.
http://servicemanuals.vstore.ca/
Aug 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I have a mitsubishi tv model # WD 52525 DLP and the timer light just keeps flashing and the TV will not go on
i have a mitsubishi ws-55859 rear projection tv. the green timer light just keeps flashing and the tv will not turn on.
Aug 09, 2009 | Televison & Video
Blinking green timer light
i have seen a couples mitsubishi and i all ready talked with a tech suport from mitsubishi but they said change the capacitors in the shop were i work we do the same but the tv still doing the same then we send the dm module to them and they fixed we asked whats the real problem and they said the capacitos the best i think is send the module to them
May 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Constant green blinking timer light
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
Suspect the DM PCB part # 934C116002
Jan 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
83 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
