Setting up printer on home network
I am trying to setup my printer on my home network so we can print directly from our laptops instead of having to save a document to a flash drive. I have a desktop computer running Windows XP that has my internet, router, and printer hooked up. My printer is an HP Deskjet D4260 and I would like to set it up so we don't have to turn on the desktop to print. Is this possible?
  • 131 Answers
Because your printer is not either wireless or network capable, the only way to get the results you need is to purchase a usb print server, hook it to your router, set it up through it's management console, and if your router is wireless, you can hook up to your router and print to your printer with your desktop turned on or off.
Posted on Apr 13, 2009
    Top Expert:
  • 11,573 Answers
Posted on Jun 27, 2016
How do i make my x543 wireless
You can find a User Manual here: http://support.lexmark.com/index?page=product&locale=en&productCode=LEXMARK_X543&segment=SUPPORT&userlocale=EN#3 I could not find that it has Wireless capability. You can set it up as a Network Printer on a Home Network. Use this procedure: http://www.trainsignal.com/blog/how-to-setup-a-small-home-network-part-2 OR, http://www.ehow.com/how_8038760_setting-up-wired-printer-network.html Once you have it setup as a Wired Network Printer Share the printer that way you can connect Wirelessly to ALL computers on your Home Network. All computer must be in the Home Network and the Computer the Lexmark is connected to via a Hardware printer cable must be turned on to print Wirelessly. Setting up a Home Network procedure: http://compnetworking.about.com/od/homenetworking/ig/Home-Network-Diagrams/
Mar 07, 2013 | Computers & Internet
How to conect a printer
Install a printer on a home network
There are two basic ways to make a printer available to the PCs on your home network:
  • Attach it directly to one computer and share it with all the others on a network.
  • Connect the printer as a stand-alone device on the network itself.
This article explains how to do both in Windows. However, you should always first consult the information that came with your model for specific installation and setup instructions.
Setting up a shared printer
Traditionally, the most common way to make a printer available to a home network has been to connect it to one of the PCs and then tell Windows to share it. This is called a shared printer.
The advantage of sharing a printer is that it works with any USB printer. The downside? The host PC always has to be powered up, otherwise the rest of the network won't be able to access the shared printer.
In previous versions of Windows, setting up a shared printer could sometimes be tricky. But a new home networking feature in Windows 7 called HomeGroup has greatly simplified the process.
When a network is set up as a homegroup, printers and certain files are automatically shared. (To learn more about what homegroups do and how to use them, go to the Windows website and search for "HomeGroup: Recommended links.")
If you've already set up a homegroup and want to access a shared printer from another homegroup PC, just follow these steps:
To manually connect to a homegroup printer
  1. On the computer the printer is physically connected to, click the Start button ?id=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33, click Control Panel, type homegroup in the search box, and then click HomeGroup.
  2. Make sure the Printers check box is selected. (If not, select it, and then click Save changes.)
  3. Go to the computer you want to print from.
  4. Click to open HomeGroup.
  5. Click Install printer.
  6. If you don't already have a driver installed for the printer, click Install driver in the dialog box that appears.
    Note
    • After the printer is installed, you can access it through the Print dialog box in any program, just like a printer that's directly connected to your computer. The computer that the printer is connected to must be turned on to use the printer.
Setting up a network printer
Network printers-devices designed to connect directly to a computer network as a stand-alone device-were once found mostly in large offices. No more.
Printer makers are increasingly offering inexpensive inkjet and laser printers that are designed to serve as network printers on home networks. Network printers have one big advantage over shared printers: they're always available.
There are two common types of network printers: wired and wireless.
  • Wired printers have an Ethernet port, which you connect to your router or hub via an Ethernet cable.
  • Wireless printers typically connect to your home network using Wi-Fi or Bluetooth technology.
Some printers offer both options. The instructions that came with your model should tell you exactly how to install it.
  1. ?id=microsoft.windows.resources.shellexecutetopiciconClick to open Devices and Printers.
  2. Click Add a printer.
  3. In the Add Printer wizard, click Add a network, wireless or Bluetooth printer.
  4. In the list of available printers, select the one you want to use, and then click Next.
  5. If prompted, install the printer driver on your computer by clicking Install driver. ?id=18abb370-ac1e-4b6b-b663-e028a75bf05b If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  6. Complete the additional steps in the wizard, and then click Finish.
    Tips
    • Make sure that you have permission to use these printers before adding them to the computer.
    • You can confirm the printer is working by printing a test page. For details, see Print a test page
Feb 14, 2011 | Acer Aspire One PC Notebook
Just replaced Netgear WebSafe router with Linksys WRT400N. Now, can't "see" printer in network nor can access it to change settings (or print). Have tried with ethernet cable straight to router and through...
Reset printer to factory settings according to manual. Plugged in ethernet cable directly to router. Ran BRAdmin which recognized printer and saw that IP address had been automatically set within new router range. Changed setting to STATIC. Deleted old printer definition from printer list and added updated definition using Printer Setup Utility. Printed test page from BRAdmin. Also printed file from Documents folder wirelessly. Changed printer settings in another laptop & was able to print wirelessly from there as well.
Jan 07, 2010 | Brother HL-2070N Laser Printer
DLINK DP-300U. Desktop shows printer offline, Laptop prints OK.
First thing.. plug printer directly into PC.. does it work? .. if so its is a port setting. If now it is the device config on PC
If Port Setting Issues.. are you going through any other devices on the network or is you firewall blocking the IP.
If device Config issue check to see it is setup up as an IP Port not a normal local port
Jul 15, 2009 | D-Link DP 300U (DP-300U) Print Server
Setting up an OKI printer on an IMAC
Without mac drivers you do have a problem. Put it on ebay and get another printer that supports mac and windows.
May 12, 2009 | Apple MacBook Pro Laptop Computer with...
D-LINK PRINT SERVER DP-301U AFTER DOING A SYSTEM RESTORE ON MY DESKTOP COMPUTER (WINDOWS XP) I CAN NO LONGER PRINT TO MY SAMSUNG ML-2010 SERIES PRINTER ... PRINT JOBS ARE IN THE PRINTER QUEUE BUT WON'T...
- Kindly visit this web site for instructions:
http://support.dlink.com/faq/view.asp?prod_id=459&question=DP-100%20/%20%20DP-101P+%20/%20DP-300%20/%20DP-301P+%20/%20%20DP-303%20/%20DP-313%20/%20DP-301U%20/%20DP-311P%20/%20DP-311U%20/%20DP-311U_revB
Mar 12, 2009 | D-Link DP-301U (790069251979) Print Server
HP Color Laserjet won't print from desktop - or wirelesslly from laptop - but WILL print directly from laptop.  : ( Need knowledgable networking and driver and  port personn to walk me through this.
I am going to assume that the printer is plugged directly into the desktop and if so then you need to go to printer and setting and setup you color laserjet as a shared printer. Now see if you can see the printer on your network, thru the wireless connection on the laptop.
once done that will probbably work, but you are probbably going to need your desktop on to print
Dec 20, 2008 | Computers & Internet
Cannot configure the wireless USB Print Server
first delte all the programs that u have installed about the print server and the printer.then connect the print server on ur laptop and run the installation .search for the wireless netwrk and connecting to it using the wpa key.After tats done connect the print server to the printer and run the printer installation ,,hope that shud resolve it,,best of luck
May 06, 2008 | Port Incorporated Wireless 11Mbps...
Setting up my HOME network! HELP!!!
Sounds like something is not right with the sharing... Assuming that computer 1 (the computer with the printer) is sharing and everything is set correctly, I would change the workgroup name. Instead of using "MSHOME" use say some basic word like "example" or some other name.
Ironically for my workgroup here I call it "StarWars"
needless to say my printers and everything shares just perfect. When you use "MShome" there's restrictions on what XP professional and XP home machines see on the network. I changed the workgroup name and that solved that problem.
Be sure to put all computers on the same workgroup name that you pick. You can even choose your first name if you want.
Dec 29, 2007 | Computers & Internet
Computers & Internet Logo
108 people viewed this question
David Payne
David Payne
