FixYa.com
Tags:
Lexmark X4500 MFP Flatbed Scanner
Setting up
posted by tanoasukile on Sep 12, 2007
I bought the x4500mfp from ebay. I just got the power supply today. I have connected the ethernet to the scanner and my printer. When I turned the power on, the screen remains blank. What do I need to do? DO I need drivers for the unit? I have looked at the manual online but it does not say, I want to be able to use all of its features: email scanned copies to my computer, fax and print. Please help me.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Mar 20, 2008
FixYa! (100)
Mark_Y
Rank:Apprentice Apprentice
Rating: 100%, 1 votes
Big thank to harly4d for the post.
Much appreciated.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Nov 23, 2007
FixYa! (100)
harly4d
Did you try to adjust the contrast button on the front left side of the unit? Also, did you here the power supplies fan come on when you plugged just it into the wall? And did the scanners internal fans come on when you switched the power switch "on" on the back of the unit. The other common problem I've seen is the cable from the operator panel to the MFD (the metal case on the bottom of the unit that houses the motherboard, hard drive, memory, etc.
Comment by harly4d, posted on Nov 24, 2007
Once you get this unit wokring I highly reccomend you go to http://support.lexmark.com/printerfirmware and enter "r109" to dowload the latest firmware. Then go back to that same page and enter "907306" to download the latest software for the unit. Both downloads include directions on how to update. The second download is big and takes a while to update the unit - about 15~20 minutes. If you need any help email me at jeremy (dot) houle (at) xtreemkreations (dot) com These updates fix issues like ADF lamp warm up timing (one of the biggest issues I've seen) and update the new "daylight saving time".
Solution #3
posted on Dec 31, 2007
Not Rated (0)
Rebootoz
Rating: 0%, 0 votes
Interested to know if you got it running. I've also got a X4500 - from cold it takes quite a few minutes to initialise and warm up. I had a problem with a ADF lamp error but i found by locking and unlocking the scanner lock and restarting it a few times it finally got going and worked OK once warm and left running.
Very useful post above from harly4d!
Cheers Ross
Solution #4
posted on Oct 09, 2007
Not Rated (0)
jhereg
Rating: 0%, 0 votes
Yes it sounds like you need the driver for this unit.
http://downloads.lexmark.com/cgi-perl/do...
This page should get you what you need.
Can you Help with these Scanners problems?
Scanners
PILOTE POUR SCANNER CANON
Bonjour Je souhaite recevoir le... Answer This...
printer installation
we don't have the cd anymore to... Answer This...
Factory reset of X4500
Hi Jeremy, I see that you have... Answer This...
Cannot print from remote...
I have a wireless printer... Answer This...
Administrator Password Reset to...
I bought an X4500 from a... Answer This...
Repair Service
Find Scanner Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
