Question about Ricoh Aficio 2018D All-In-One Laser Printer
The printer will not work it only says set key counter what do we do? The printer is a Ricoh, Aficio 401.
  • Anonymous Apr 21, 2009
    Ma photocopieuse demande code que je n'ai pas
    je voudrais la réinitialiser ???
    Merci d'avance
  • 31 Answers
You need to go into user tools, system settings, admin tools and turn key counter off
Posted on Jun 18, 2009
  • Ricoh Expert
  • 393 Answers
User tools, syster settings, key op, and turn off key counter
4 Suggested Answers
canontech
  • 1219 Answers
SOURCE: Ricoh Aficio 2020 All-In-One - printer offline
Under printer check book unmark Use printer offline
Posted on Jan 13, 2010
Joed911
  • 4338 Answers
SOURCE: i need ricoh aficio mp 1600le driver, how do i get into.
Here is the driver page:
http://www.ricoh.com.sg/downloads/drivers1.aspx?path=http://support.ricoh.com/bb/html/dr_ut_e/ra/model/mp16/mp16en.htm
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 11, 2008
  • 15 Answers
SOURCE: Set Key Counter error
press the user tools button, press the copier button on the screen then go into the administrator tools button in there you should see some option for turning the key counter off.
Posted on Mar 01, 2009
Error Code SC 401
1. Check the transfer unit is set correctly.
2. Check the transfer roller is set correctly.
3. Check the high voltage supply board is set correctly.
4. Check the harness of the high voltage supply board.
5. Call a Ricoh Service tech.
Aug 14, 2014 | Ricoh Aficio Mp 3352 B&w Copier
How to reset cleaning web replace service call aficio mp5000
Enter in the service menu : intr.key(yellow) - 1 - 0 - 7 press and hold Stop/Clear(red)key ,enter in SP mode ,counter mode ,reset the present part life counter.
Jan 22, 2013 | Ricoh Aficio 2015 Copier
RICOH AP610n Factory Reset
press the counter key and then press and hold the # key and tap on system settings on the screen . it will ask if you want to reset the machine to factory mode, select yes and wait for the machine to reboot.
thanks and all the best.\
for further clarification, call +233243494871
Mar 12, 2012 | Ricoh Aficio AP610N Laser Printer
How to find out where to read meter on my ricoh aficio 1035 copier machine
Ricoh Aficio 1035 have two meter those are the electronic counter and the magnetic counter type but they are program to synchronize. to look for the magnetic counter just open the front door and you will find it at the middle and to open the electronic counter just press the user tools/counter key located on the upper left side of your operation counter then press the counter on the LCD display. Hope this helps, thanks for using Fixya
May 03, 2011 | Ricoh Aficio 1035 Copier
ERROR of My Aficio MP1500 Photocopier
Are you sure about the model number? I believe you may mean MP2500? Regardless, sounds like an NVRam Problem. This unit is what controls the electronic counter, as well as most of system settings. This will require a service technician from a dealer with connections to RICOH.
Feb 25, 2009 | Ricoh Aficio 450 Copier
Ricoh Aficio 1035 from Networked Unit to Stand Alone
There is a service code to disable the key counter. I'll have to look it up. If you are not connected to a network, you can still use the copier without being hooked up to one. That is just a warning message. You can clear it out by pressing user tools counter. Select interface and set all ip addresses to 0.0.0.0.
Jan 29, 2009 | Ricoh Aficio 1035 Copier
Dec 27, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Change the time of the fax on a Ricoh Aficio Super 220
Set date and time;
  • Press User Tools/counter button
  • Press 3 for Fax
The Facsimile User tool main menu appears.
  • Press the number 6 for Key Op. Settings and press the hash key within 3 seconds.
  • Press 18, Date and time or next until it shows.
Select month, date, year or time with arrow buttons,
enter the month with Prev. or Next and enter the correct time and date.
Press OK > PrevMenu > User tools/counter button.
Good luck and please rate me, thanks.
Dec 10, 2008 | Ricoh Aficio 220 Laser Printer
Ricoh copier aficio 401 error sc 419
hi im jules_09.
sc 401 means transfer roller leak error.a transfer current leaksignal is detected.posible causes is 1.transfer power pack is defective 2.poor connection between the transfer terminal and the trnsfer power pack
sc 419 mean quenching lamperor.1 quenching lamp defective 2.poor conection between power pack and quenching lamp.
check all component but pay attetion to the current leak at the transfer because there both connected at the power pack
Nov 01, 2007 | Office Equipment & Supplies
Ricoh Aficio 2018D All-In-One Laser Printer Logo
704 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
