Does pc2700s memory fit into the medion mim 2120
I have a medion 2120 and I am wondering if the memory type pc2700s is compatable with this model.
  • Frank
    Frank May 11, 2010
    that all depend on what processor you have on the mother board, and what is the machine speed.
My Medion MIM 2300 Notebook PC MD 96648 is
Your best bet is to hope it goes up in flames then you can claim off your insurance, the problem can't be fixed.
I have the same machine but with mine it got hot and the graphics processor has burnt out, it seems to be common with this model.
I can't even connect to an external monitor as everything to do with the VGA is fried and Medion support are useless.
I'll never buy a Medion again even though my previous two going back 8 years still work if somewhat slow.
Dec 30, 2009 | Computers & Internet
My power lights keep going from red and green then they go off altogether. i have to fiddle around for a bit before the power comes back on mim 2120 medion laptop
Could be three things causing this. First, the DC jack soldered on the motherboard could be loose. Over time the solder will crack loose. Most likely this is the problem. Second, the AC adapter could be going bad. Finally, the battery could be going bad. Each of these items should be checked.
Nov 17, 2009 | Computers & Internet
Medion mim 2120 laptop
Hi
First i reccomend checking the power cable and seeing if there are no short circuits or breaks in the circuit. - to do this unscrew the end of the power cable - this part wares out often and costs about 50 cents to replace.
Hope i could help
CBZ
Comment if you need more assistance
Apr 27, 2009 | Medion md40298 Notebook
Wireless connection problem with Medion MIM 2120
hi..go and try to find the (Control Panel) then double click the icon of name is (Network Connections) then find the wireless LAN connection..if you have wireless connection u need configuration..if not no have wireless connection you need re-install the LAN card driver..Thanks and good luck..^_^
Feb 01, 2009 | Medion md40298 Notebook
I have a medion mim 2310 notebook laptop and the problem is that when i plug in the charger it short circuits and switches off,anyone got any idea what the possible cause may be as i dont fancy replacing...
dejay .
if you have a light for charging then have you checked if the ddr memory cards are ok just take one of some one to try you may get it solted if the memory is no good,wrong or damadge then replacing the memory card will solve your problem !
Nov 09, 2008 | Computers & Internet
Fitting new screen medion mim 2120 laptop
I could not find a breakdown for you laptop. But from a picture I saw on the web, I could tell you that it is probably the same as most laptop. First, there are screws under the round inserts. You need to pry those up and stick the aside ,in order to put them back when you finish.
Then remove the screws, usually 4 on each corner of the screen. Some laptops have 2 screws on top of the screen near the latch.
Then you need to pry the front bezel off the screen. You can use a small straight screw driver. Carefully (as not to scratch the case) insert the screw driver and pry the bezel away from the back casing of the LCD.
Once you have the bezel off you will see the screws that hold the actual LCD screen in, remove them and lift the LCD out. You will have to un-hook the cable from the System board to get the screen completely out. Then install the new screen.
Please remember to rate all users who assist you for free :)
Oct 01, 2008 | Computers & Internet
Memory upgrade for packrd bell Easy One Silver 2120 DVD
The best site to get the info on what memory you need is here at Crucial.com, run the tool and it will tell you what memory you have and the max and type you can fit
Sep 22, 2008 | Packard Bell Easy One Silver 2120 Notebook
NO SOUND DEVICE FOUND AFTER RELOAD WINDOWS XP
hi reloaded windows xp on medion mim2220 laptop unable to find sound device to work sound for my laptop cant play any music can you help please
Feb 25, 2008 | Medion (40010998)
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
