Breaker keeps tripping
I have an intertherm a/c unit that keeps tripping the breaker. already replaced the capacitor and checked connections. Breaker still keeps tripping
  • ttmoe Apr 06, 2008
    • breaker keeps tripping itook the wires off compressor pushed in contactor and the outdoor fan comes on and breaker does not trip. I think its a grounded compressor but the units only 2 years old and cant believe that its grounded already can someone help.
  • 1,420 Answers
If the breaker itself is more than 15 years old, replace it. If it continues to switch off, check the amp draw of both the inside and outside unit.
Posted on Sep 12, 2007
  • david_griggs
    david_griggs Jan 25, 2014
    Air Conditioner is hooked up with the furnace and it dosnt trip the breaker.
Maybe the the comppressor is open circuit
Posted on Sep 17, 2008
6ya staff
SOURCE:
How do i fix my central air conditioner from tripping the circuit breaker?
tripping circuit breakers indicate shorts in the system or overload from a compressor failure
call in a technician to properly diagnose the problem and get a quote
Jun 01, 2016 | Heating & Cooling
The condenser unit will not kick on...it is a concord unit,10=12 years old,13 seer,3 ton. The air handler works fine. I thought it was the capacitor. The old one was bad,I verified that with multimeter....
It could be a low refrigerant cut-out (switch), grounded or shorted motor windings, open internal winding overload protector (check at the common winding), a broken conductor, or no power at condensing unit from blown fuses or open/tripped breaker.
Aug 22, 2013 | Intertherm Heating & Cooling
P3RA-060K heater side blows breaker after 10-15 minutes
wire too small, breaker too small, loose connection, over amperage
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Dec 27, 2017 | Intertherm P3RA-060K Air Conditioner
Fan not working on outside AC unit
The buzzing noise is probably the fan motor. Is the compressor running? First make sure that there are no tripped breakers. After that kill the power and check the capacitor with a multimeter. If that checks good then check the fan motor windings with the multimeter. Let me know if you have any questions.
May 26, 2010 | Intertherm P3RA-060K Air Conditioner
My heil heat pump has been tripping circuit breakers. It might run 8 hours to two days before it trips. I replaced the breaker. They put a hard start on the compressor. Now they say the next step is the...
Have you noticed what the outdoor temperature is when this unit is tripping the breaker? Does it seem to be at a higher outdoor temperature or at all outdoor temperatures day and night?
Did they check the run capacitor to see if it's good and the proper microfarads?
Did they check to see if the breaker trips when it's starting up or after it has been running awhile.
If it's tripping on start up then it's possible the next step is the compressor replacement.
If it's tripping after running awhile then it could be dirty indoor coil or filters,blower not running at full speed,low voltage, loose wire connection, points burnt on contactor and even a weak run capacitor.
Dec 30, 2009 | Heating & Cooling
Intertherm S3QA042K compressor won't restart
You probably need a hard-start kit. A hard-start kit connects to the run capacitor and provides a starting boost for your compressor. If you install a hard-start kit, monitor your a/c for a while because it is possible that the bearings in the compressor are going bad.
Jul 30, 2009 | Heating & Cooling
AC tripping breaker.
Check its wiring connection. Could be loose connection, corrosion.Or the breaker is already retiring. If the breaker is fairly rated to the aircon unit. Also insect could be the culprit.
May 25, 2009 | Goldstar GW-HD5000 Window Air Conditioner
Breaker tripping on electric furnace.
First, how old is that breaker and are the connections all clean and tight?  A warm breaker is normal.  If it hot or buzzing, that is another story.  If the breaker is more than a few years old, it may pay to invest in a new one.  They do wear.  If you have a connection which has come loose or is corroded, it will trip the breaker, arc at a connection point or even cause a coil to fail.  Dirty connections heat up and actually back off the holding bolts to the point of failure or to tripping the breaker with arcing.  With the breaker off, inspect all connections from the panel to the unit.  You may get some surprises.
If none of this turns up a problem, inspect the actual heater coil, you may find dirt in there which is causing a problem or the unit itself is failing and touching a grounding point.
Dec 22, 2008 | Intertherm P3RA-048K Air Conditioner
Accidental short/spark - what part did i ruin?
YOU HAVE TOUCHED A HIGH VOLTAGE WIRE TO GROUND AS I READ YOR STATMENT. THAT WILL CAUSE A HIGH VOLTAGE BREAKER IN YOUR DISCONNECT OR MAIN PANEL TO TRIP. YOU CAN FIND CONTACTOR IN OUTDOOR AC MASH IT IN WITH AN INSULATED SCREWDRIVER AND SEE IF COMPRESSOR COMES ON . IF NOT YOU HAVE NO HIGH VOLTAGE TO UNIT FIND AND RESET BREAKER. or YOU CAN GO TO MAIN PANEL AND ALL DISCONNECTS AND CHECK FOR A TRIPPED BREAKER. REMEMBER MOST BREAKERS TRIP TO HALF POSITION, BUT CUTLER HAMMERS TRIP TO OFF POSITION. THE THERMOMSTAT CONTROLLED SWITCH IS CONTROLLED BY LOW VOLTAGE THAT TELLS IT WHAT TO DO, BUT THE WORKING POWER IS USUALLY HIGH VOLTAGE IF ANYTHING HUMS ETC YOU HAVE LOW CONTROIL VOLTAGE BUT IF CONTROLS CLOSE AND NOTHING HAPPENS YOU HAVE LOST A LEG OF POWER OR BOTH LEGS. LOCATE TEST AND RESET ALL SOURCES OF POWER ( HIGH VOLTAGE)
Oct 24, 2008 | Heating & Cooling
Heating & Cooling Logo
1,552 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
