Question about Canon PC1061 Copier
It makes light shadow of document on different parts of page they said clean printer heads how & where is it.
  • jerry118 Apr 16, 2009
    it is a copy machine it makes like shadows of part of the document at different places on the page. like faint duplication. and the page is darker.
  • hinderschied May 11, 2010
    do you have shadows when printing or when copying?
    If it's both it's probably the toner cartridge and your printer does not have print heads.
    Thanks
    Bob
    Sniper:
  • 67 Answers
More than likely it is the toner cartridge, inside the cartridge is a cleaning blade that works like a windshield wiper. If the image is repeating every 4 to 5 inches it is not doing the job. Replace your toner cartridge. It is a digital copier with a USB port and can be used as a printer also.
Posted on Apr 16, 2009
Who said clean printer heads? There are no print heads. This is a laser machine, not an inkjet.
The most likely problem is a defective toner cartridge. Try another one, and if that doesn't solve it, then the fuser sleeve needs replacing (requires a tech)
*please rate solution
Posted on Apr 15, 2009
Head cleaning
Please don't try to clean the "head" A laser printer is a very delicate apparatus and can be dammaged very easy. The manual gives several reasons, why shadow's can apear. One is the paper could be to moist. You could see the manual (still online) to check what "shadow" is closest you what your machine produces.
Maintanance starts at page 72 and is followed by trouble shooting, where you can see print errors.
Nov 05, 2013 | Samsung CLP320 AllInOne Laser Printer
Canon PIXMA MP510 : When I print something in colour, I get alternating dark and light 3mm lines printed horizontally down the page. I've tried cleaning, deep cleaning and realigning the print...
Hello
what you need is to clean, you need to clean the prnt head and ink cell, you open the top part let the ink carrier move to the center then UNPLUG the power cord ,now you can easily clean ink cell.
Jun 29, 2011 | Canon PIXMA MP510 All-In-One InkJet...
I have canon lbp 2900 printer when i print first line shadow is also printed in the middle of page and middle line shadow is also is printed in the last of page. and some of line shadow is also printed.
Repetitive ghosting defects like this are caused by either a bad drum in the cartridge or a damaged or worn fuser assembly. Try a different cartridge first, but make sure you print at least 50 pages to make sure that any toner residue is cleaned of the fuser in the printing process. If the defect is still there then you will need to either repair or replace the fuser.
May 06, 2011 | Canon LASER SHOT LBP-2900 Printer
When printing a new page I get a "shadow like"
Clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Performing up to 6 cleaning cycles is not uncommon if the print heads are severly clogged.
Hope this helps.
Shane
Feb 08, 2011 | Brother MFC 7420 All-In-One Laser Printer
Shadow along edge of my SHARP DM-3551 copier's copies
Run a page with the cover or document feeder open. Just a solid black page. If the shadow runs completely edge to edge on the paper, your problem is in the drum unit or less likely the fiser.. If the there is a clean edge delete, then the problem is either dirty scanner mirrors or the laser. It is far less likely in the optical/laser system but still likely. I tend to believe the problem is in the drum unit.
Mar 12, 2010 | Canon imageCLASS D860 All-In-One Laser...
Double images, error 5100 when printing, copying
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
Jan 02, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Canon MX700 multi-function printer error 5100, double-lines
You can Try
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All best: Pineworks
Jan 02, 2010 | Canon PIXMA iP4600 Color InkJet Photo...
Whenever i print a test page everything has a shadow behind it, making it look blurry.
Dear Sir,
If your using new catridge please goto Printer service option and clean the head once. Then youwill get clean print.
Thanks
Sep 19, 2009 | HP PSC 1210 All-In-One InkJet Printer
Copy is printiny a shadow of the document also.
check your printer head try to clean or clean it..
any further question let me know ok..
thanks,
Mar 16, 2009 | Canon PC1061 Copier
Shadow on printed page
You either have a bad toner cartridge or bad fuser. Measure the distance from and exact on image printered to the exact same spot on the page it appears again. If it's fuser it will be 41.0mm between image and defect. Any other spacing on the front of the page is usually cartridge.
Try replacing the cartridge first and if that doesnt fix the issue it's fuser.
Here's a link for the service manual. Look at page 117 to get a complete list on repetative defects and their causes.
http://www.feedroller.com/Store/Service%20Manual/HP%20LaserJet%201022%20(Q5912A),%201022n%20(Q5913A),%201022nw%20(Q5914A)%20P.pdf
Hope that helps you.
Aug 02, 2008 | HP LaserJet 1020 Printer
Canon PC1061 Copier Logo
173 people viewed this question
old marine
old marine
