Question about Panasonic Lumix DMC-LZ2 Digital Camera
Lens will not retract
I've been using my camera quite happily since I got it for my birthday in April, but over the weekend it just refused to retract the lens when I swiched it off. It just tells me to turn the camera off then on again, which I've done many times & it makes no difference. The lens is therefore permanently open and useless! Any ideas? Thank you!
  • 5 more comments
  • sexybot Oct 04, 2007
    Thank you!
  • Amy_Mc Feb 05, 2008
    I have a Panasonic DMC LZ2 and the lens will not retract. The screen message tells me to turn the camera off and on again but ni joy. I took the camera apart and I see that the cog which controls the lens tuning but it seems to be stuck. Any solutions?
  • guacamole345 Oct 24, 2008
    ugh, I feel your pain. I was taking pictures when I accidentally dropped the camera. It wasn't a bad drop, just on carpet, but the lens won't retract and I get the same message ever since.
    I tried some of the methods on here to try and fix it (power save mode and turning back on, zooming in and zooming out, etc).
    It sounds like something is stuck. It tried to retract the lens, but it's just stuck. ): any suggestions? did you ever fix yours? if so, how?
  • Anonymous Nov 01, 2008
    message say turn camera off and on and then the lens will not retract.
  • mcsearch Jan 15, 2009
    Had taken a couple of pictures and then my lens would not retract. Keep getting the message to take off lens cap, which is not on. Please help!
  • hstudzinska Jan 22, 2009
    I dropped it on the carpeted floor and the lens doesn't retract . The message tells me to turn it off and on, but this doesn;t help.
    What shall I do?
  • Charlswarb54 Apr 16, 2009
    I have the same problem, i accidently dropped it, and when i turn it into picture taking mode, the lense tries to focus, then it says " remove lense cap and press >" i dont know what to do :( is it a common problem and can it be fixed?
  • 641 Answers
It sound like a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse. Good luck!
Posted on Sep 11, 2007
SOURCE:
Tip
After reading SteveGorak's experience, I placed the vacuum end of my...
Hello
This is a tip explaining how we can try to resolve a lens error.
Firstly you will need to understand what exactly the lens error is, and how it came to happen.
The most common cause for a Lens error:
  • Misaligned Lens rings
  • Sand and grid wedged in between the lens and the barrel.
  • Dropping the camera
  • Ran down battery
Here is the Fix:
  • Batteries
Firstly you can try removing the batteries and replacing it with a new set of fully charge ones(2500mah).
  • Memory card
If the batteries ran down while you were taking photos with the lens extended, you might also get this error. Remove the the memory card and replace the batteries with a fresh recharged set. Try to power on the unit with the fresh set of batteries while the memory card is removed.
  • USB cable
Connect your camera to your computer using your USB DATA cable which came with the camera. Once the camera gets power in this mode, the screen should stay off, hence, supplying the lens with more power to push or pull out/in.
  • Barrel Guide Pins
Place the camera on a sturdy table with the lens pointing to the ceiling. With a fresh set of batteries installed(Do this without a memory card) hold down the shutter button while you power on the unit.
  • Compressed air and Vacuum
Now, you can either use a compressed air canister to blow around the lens area. This will result in the sand or dust particles to be blown out of the area between the lens and the barrel. Or, you can use a vacuum and and carefully place the nozzle around the lens to **** out the particles.
The following Fixes will be done at own risk and can even further damage you camera.
  • Tap your camera with the palm of your hand a couple of times to displace the lens into the original position, or to dislodge particles in the lens barrel.
  • Try gently pushing/pulling/wiggling the lens while powering up the unit.
I hope this can help you to resolve this problem, and send you well on your way to experience that Legendary Kodak moment.
Kind regards
Andrea
on Sep 06, 2011 | Cameras
The problem is that the camera cannot open the front eye, when you turn on the camera it does not come out. and at the end it say lens error, restart camera, but still do the same thing. help cause i want...
Its a common error with cameras with retractable lenses. It could be a grain of sand stuck in the slide parts of the lens. Another cause is accidentally pressing the ON button when the camera is in its case.
The solution is usually "helping" the camera lens to come out. This is a tricky job because it requires putting pressure (by pulling) on sensitive lens parts. If you're not comfortable with that, ask someone else to have a look at it.
I've had one IXUS 860 which could not be recovered from the lens error. The second IXUS 860 had the same error - the lens however moved finally after turning the cap for a bit. In the first case it was sand. In the second had tried to push the lens out while in its case - the ON button was pressed.
Jul 04, 2011 | Canon PowerShot SD880 IS / Digital IXUS...
Got vivicam 5024 as a gift and it had no manuel. would like to have one
I know Manuel. You should call him; he is quite the avid photographer. Although I don't know if he owns the vivicam 5024. Try him anyways.
May 17, 2009 | Vivitar ViviCam 3915 Digital Camera
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 11, 2009 | Canon PowerShot S500 IXUS 500 Digital...
My camera lens will not go back inside it is stuck,the camera will not work at all I tried to talk to someone at sanyo in april and did not get back ahold of me then I forgot about the camera now I would...
Try this: Power the camera on then gently push on the lens while hitting the power button again so that it will try to retract the lens. but be gentle as you could damage the camera worse.
if your interested in having it fixed for around 120 or more than dont try anything and just take it to a repair company.
if that doesnt reset the camera then you can try taking the batteries out for a couple day and then put some lithium batteries in it if it takes aa's that is. They have a little higher voltage than some batteries and while sometimes give it a little more push to get things going. Leaving the batteries out would let the camera forget its memory. If you had the camera stored without batteries then don't worry about trying to reset it as that would have already happened.
Let me know how that works or if you need anymore help,
Caleb
Jul 02, 2008 | Sanyo Cameras
Zoom lens/flashlight don't retract.
replace zoom lens strip and please do let me know where it is available I too have the same problem
Jan 12, 2008 | Kyocera Finecam S5 Digital Camera
Dropped camera lightly, lens wont retract
my acm dropped and i messed up the lsenes it wont go in please help me how can i fix it my self?
Nov 03, 2007 | Canon PowerShot A540 Digital Camera
Panasonic Lumix DMC-LZ2 Digital Camera Logo
343 people viewed this question
Top Panasonic Cameras Experts
Ekse
skyblue007
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
