Question about Panasonic VB-43223 Corded Phone
Need to change from pulse to tone on Panasonic vb5211d
  • 9 more comments
  • nautacia Apr 13, 2009
    this phone does not have any switch.
    Once a guy did it entering a code in the phone, but i didn't See it
    The Phone is a PANASONIC VB5211D, conected to a central PANASONIC VB5250XF
    This Phone does not have ¨menu¨ ¨arrow¨, etc.
  • nautacia Apr 14, 2009
    The phone on station 11 is diferent to de VB5211D, it's a vb 5411,  but Im afraid it does not have any switch in it
    This phones (vb5411 and vb5211d) doesn't have switches. The only buttons are MIC, REDIAL, MEMORY, ON/OFF and HOLD.
    1) Pick up the phone or press ON/OFF button        OK
    2) Dial the desired number                                          OK
    3) Press * or # to switch pulse to tone dialing.  Hear BUSSY
  • nautacia Apr 15, 2009
    still with pulses in my phone, I need help.
    We cant make calls
    No solution for my problem
  • nautacia Apr 16, 2009
    How to get to MENU in my phone ? no button
  • nautacia Apr 17, 2009
    Partial Solution:
    if I digit ¨ * ¨ before the number, the telephone works on TONES inclusive from extensions.
    ¿Now, how can y leave the phone permanently on Tones ?  Using ¨*¨ before number, it work's but changes back to PULSES immediately I Hang up.
  • nautacia Apr 20, 2009
    As in photo this phone doesn't have MENU
  • 10,515 Answers
Hi nautacia,
It actually depends on the brand, model and version. Often utilized is a simple slide switch to select P/T either at the rear or bottom of the unit. In some others, it is configured in the MENU/Setup while still some would already be using TONE only. Most of the old phones would of course be locked to PULSE only.
Press menu and use the arrow down to goto Global setup and press select. Use the down arrow and goto Dial Mode and press select. Use the down arrow to select your dial mode and press select.
Thanks for using "Fixya".
Do  rate the solution as "Fixya" if 100% satisfied.
Posted on Apr 17, 2009
  • taran_2005
    taran_2005 Apr 20, 2009
    Hi Nautacia,
    It seems that the working of your phone model is different than the working of other models offered by panasonic or any other phone company.
    The best we can do at this moment is we can offer you a link to purchase cost effective service manual, that would guide you to fix your problem and infact any other future problem associated with your model.
    http://www.user-service-manuals.com/Pana...
    You can also check
    http://www.ebay.com
    if you can get some manuals at cost effective price.
    Thanks for using Fixya.
  • 15,935 Answers
I was hoping you would come back :D
Switching Between Pulse and Tone Calling
When you dial your phone, Pulse calling dials by sending out a certain number of pulses for each digit, as with old-fashioned rotary phones. With tone calling, your phone dials by sending a distinctive tone for each digit. 1. Pick up the handset or press ON/OFF. 2. Dial the desired number. 3. Press * or ## to switch from pulse to tone calling, or vice versa
I have uploaded the manual HERE
page 21 indicates the steps outlined above.
Thanks for using fixya - it took a while, but I finally found the needle in the haystack!! :D
  • blueextc3221
    blueextc3221 Apr 17, 2009
    BTW - it says to press ## in the manual.
    not # as stated in your earlier response.
    not sure if that makes a difference.
    AND the manual is not edited very well.
    Try pressing # or * BEFORE dialing the numbers.
    If i remember correctly - # is for touchtone.
    It has been a WHILE :D
  • blueextc3221
    no it must be done every time you make a call - unfortunately.
    Thanks for using FixYa!!
    Scholar:
  • 123 Answers
Go to the menu and choose Tel line and the go to set dial mode and then choose the dial mode like dial or pulse mode
Posted on Apr 16, 2009
    Sergeant:
  • 199 Answers
Dear you use the follow step....thanks.
http://phone.manualsonline.com/ex/thread/view/idThread/1939807
Posted on Apr 15, 2009
  • 148 Answers
For Panasonic VB-series corded phones, try this:
1) Pick up the phone or press ON/OFF button 2) Dial the desired number 3) Press * or # to switch pulse to tone dialing.
I hope this helps your problem. Have a nice day.
Posted on Apr 14, 2009
    Brigadier General:
  • 3,614 Answers
you can see under the phone an adjustment switch, you may see it on the side it either left or right side. you can adjust it from pulse to tone.
let me know
Posted on Apr 13, 2009
  • micromaster
    micromaster Apr 13, 2009
    may i know what exactly the model # that you have.?
  • micromaster
    Brigadier General:
  • 5,158 Answers
On the side of the phone.... look on all sides you will see a slide switch where you can choose between tone and pulse... move it to tone
Robert
  • 11,896 Answers
Here are your phone codes:
All programming is performed from a display telephone connected to extension 101. To enter programming mode move the switch on the back of the phone to Program and press *#1234.
  • 000--- Date and Time Setting
  • 001--- System Speed Dial Entry
  • 002--- System Password
  • 003--- DSS Console Port Assignment
  • 004--- Paired Telephone Assignment for DSS Console
  • 005--- One-Touch transfer Using a DSS Button
  • 006--- Time (D/N/L) Service Changing Mode
  • 007--- Time (D/N/L) Service Start Time
  • 008--- Operator Assignment
  • 009--- Extension Number Assignment
  • 010--- LCD Time Display Selection
  • 011--- System speed dial name setting (-4+)
  • 100--- Hunting Group Set
  • 101--- Station Hunting Type
  • 102--- Voice Mail Port
  • 103--- DTMF Integration
  • 104--- Hold Mode Selection
  • 105--- Conference Tone
  • 106--- External Paging Access Tone
  • 107--- DTMF Receiver Check
  • 108--- Flash Mode for a Station Locked Ext
  • 109--- CO Indicator Assignment
  • 110--- Flash Key Mode
  • 111--- Hold Music Selection
  • 112--- DSS Console Indication Mode
  • 113--- Automatic Redial Repeat (Up to –2 only)
  • 114--- Automatic Redial Interval Time (Up to –2 only)
  • 115--- Ext Ringing Pattern Selection
  • 117--- Call Pickup Tone
  • 118--- Pulse Restriction
  • 119--- Redialing After Pulse to Tone Conversion
  • 125--- Toll Restriction Check for * and #
  • 130--- Voice Mail 1 APT Port for KX-TVS50 (-1+)
  • 131--- Voice Mail 2 APT Port for KX-TVS50 (-1+)
  • 140--- Ring Mode (–1 –2 only)
  • 200--- Hold Recall Time
  • 201--- Transfer Recall Time
  • 202--- Call Forwarding Start Time
  • 203--- Pickup Dial Delay Time
  • 204--- Call Duration Count Start Time
  • 205--- Outside to Outside ( CO to CO ) Line Duration Time Limit
  • 206--- Dialing Start Time
  • 208--- Interdigit Time
  • 211--- No Dial Disconnect
  • 300--- Carrier Code Assignment
  • 301--- Toll Restriction --- System Speed Dial
  • 302-305--- Toll Restriction --- Class 2 --- 5 Denied Codes
  • 306--- Toll Restriction --- Exception Codes
  • 309--- Emergency Dial Number Set
  • 310--- Account Codes
  • 311--- Automatic Pause Insertion Codes
  • 312--- Toll Restriction- Station Lock Boundary Class
  • 400--- Outside CO Line Connection Assignment
  • 401--- Dial Mode
  • 402--- Pulse Speed Selection
  • 403--- Host PBX Access Codes
  • 404--- Outside CO Line Group Assignment
  • 405-407--- Flexible Outward Dialing Assignment D/N/L
  • 408-410--- Flexible Ringing Assignment D/N/L
  • 411-413--- Delayed Ringing Assignment D/N/L
  • 414-416--- Outside CO Line Mode D/N/L
  • 417--- Pause Time
  • 418--- Flash Time
  • 419--- Automatic Designated Outside CO Line Access
  • 420--- Calling Party Control CPC Signal
  • 421--- CPC Detection for Outgoing Calls
  • 422--- Disconnect Time
  • 423--- Outside CO Line Ringing Pattern Selection
  • 500--- DISA Incoming Dialing Mode Selection
  • 501--- DISA Built-in AA
  • 502--- OGM Mode Selection
  • 503--- Fax Connection
  • 504--- DISA Delayed Answer Time
  • 505--- DISA Waiting Time After OGM
  • 506--- DISA Busy Mode
  • 507--- DISA Intercept Mode
  • 508--- DISA Ringing Time Before Intercept
  • 509--- DISA Ringing Time After Intercept
  • 510--- DISA No Dial Mode
  • 511--- DISA Security Type
  • 512--- DISA Security Codes
  • 513--- Cyclic Tone Detection
  • 514--- Fax Tone Detection
  • 515--- Intercept Time for Internal DISA
  • 517--- DISA AA Wait Time (-3 +)
  • 516--- DISA Incoming Assignment
  • 518--- DISA Tone Selection After Security Code
  • 530--- DISA Security Codes Digits Selection (-3+)
  • 600--- Ext Group Assignment
  • 601-603--- TRS-Class of Service Assignment D/N/L
  • 604--- Ext Name Setting
  • 605--- Account Code Entry Mode
  • 606--- Call Transfer to Outside Line
  • 607--- Call FWD to an Outside Line
  • 608--- Executive Busy Override
  • 609--- DND Override
  • 610--- Paralleled Telephone Connection
  • 611--- Telephone Answering Machine Ext
  • 612--- Room Monitor Assignment
  • 617--- Wireless PT port Assignment
  • 618--- MWL For Other Ext (-3+)
  • 620--- Live Call Screening Mode Assignment (-2+)
  • 700-702--- Doorphone Ringing Assignment D/N/L
  • 703-705--- Door Opener Assignment D/N/L
  • 706--- Doorphone Ringing/Tone Pattern D/N/L
  • 707--- Doorphone Access Tone Selection
  • 708--- Doorphone Ringing Time
  • 709--- Door Opener Time
  • 710--- Doorphone Ring/Chime Selection (-3 Y591B+)
  • 711--- Doorphone Chime Assignment (-3 Y591B+)
  • 712--- Doorphone Chime Pattern Selection (-3 Y591B+)
  • 800--- SMDR RS-232C Communication Parameters
  • 801--- SMDR Parameter
  • 802--- Incoming/Outgoing Call Selection For Printing
  • 803--- Secret Speed Dialing/One-Touch Dialing Printing
  • 804--- System Data Dump
  • 805--- SMDR Account Code Selection
  • 900--- Caller ID Assignment
  • 901--- Caller ID Area Code Assignment
  • 902--- Caller ID Modification for Local Calls
  • 903--- Caller ID Modification for Long Distance Calls
  • 904--- Caller ID Log Priority Selection
  • 906--- Caller ID SMDR Format
  • 907--- Caller ID SMDR Printout Selection (-3+)
  • 908--- CID Call Waiting Time (-3+)
  • 909--- Common Area Call Log Check Assignment (-3+)
  • 968--- Kx-T77xx Incoming lamp control (-4+)
  • 963--- Call Forwarding Selection (-1+)
  • 998--- ROM Version
  • 999--- System Data Clear
  • Nate Stansfield
    Nate Stansfield Apr 14, 2009
    Move switch in cabinet to PROGRAM. Use station 11
    phone to program
    Code
    Description
    00
    Time/Date
    01
    System Speed Dial 00 to 99
    02
    CO Connection Assignment Connect/No Connect
    03
    Dial Mode Tone/Pulse
    System Switching Mode Automatic/Manual
    05
    System Switching Time
    06
    Outward Dialing Day
    07
    Outward Dialing Night
    08
    Ringing, Day
    09
    Ringing, Night
    10
    Toll Restriction Class Assignment
    11
    Toll Restriction, Area Code selection
    12
    Programmable Operator Call
    13
    14
    Automatic Answering Automatic/Manual
    Preferred Line Assignment
  • Nate Stansfield
    If you want to download the entire manual for panasonic Vb5211, you can get it here at this site:
    http://www.retrevo.com
Selecting dialing mode
The directions for changing the dialing mode from tone to pulse can be found in the owner's manual for the main base unit.
Press the [MENU] button then choose "Set tel line". Then choose "Set dial mode", then choose Pulse or Tone and press [OK].
Additional details can be found in the below link.
http://service.us.panasonic.com/OPERMANPDF/KXTG1031.PDF#page=14
Jun 28, 2014 | Panasonic KX-TGA101S Cordless Handset
Changing from pulse to tone panasonic phone
Touch the following keys: Menu 0 5 1 and then select 1 (tone, the factory default) or 2. Then Save (a softkey with the label in the LCD screen) and Off (opposite Talk on the keypad).
The manual for the Panasonic KX-TG5664 is available from Panasonic here: http://service.us.panasonic.com/OPERMANPDF/KXTG5664.PDF . See page 17 for setting the Dialing mode.
I hope this helps.
Apr 06, 2013 | Panasonic Lands Phones
There is no "magic switch" on the back of this
The magic switch is in the SYSTEM. By default Panasonic systems are Tone dialing. You can change it or if you press # it turns off tone to pulse conversion.
Carl
Jan 31, 2011 | Panasonic KX-T7730 Corded Phone
How do i change from tone to pulse on panasonic kx- tg6511 cordless phone
Try this.....Press menu....enter (# 1 2 0). Now select up or down key to get tone or pulse. Then select Save then off.
Nov 10, 2010 | Panasonic KX TG6511 Cordless Phone
Both phones have no dial tone and don't work - could it be because they don't support digital?
Hi, Welcome to FixYa.
The cordless phones supports pulse dialing than tone now a days.
If your provider supports pulse dialing & tone you can just change the tone to pulse to use cordless phone. Otherwise you have to request for pulse dialing from your provider.
We appreciate your feedback; it will help us improve this Web site.
Please select 'YES' if satisfied.
Jul 08, 2009 | Panasonic KX-TG2352 Cordless Phone
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Change pulse into tone
Nov 22, 2008 | Panasonic KX-TG2631 Cordless Phone
TC1200 TONES/PULSES
There is usually a switch to change it from dial pulse to touch tone.If there is no switch check your user manual to see if there is a screen option.
tk46
Jun 19, 2008 | Panasonic KX-TG1033S Cordless Phone
Changing from Pulse dial to Tone
Go to Menu > Set tel line > Set dial mode > Tone. That should solve it.
May 26, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic VB-43223 Corded Phone Logo
1,102 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
