Question about Watts Up! Our Tesla Coil Generates Up to 50 000 Volts of Electricity!
How to make electricty - Watts Up! Our Tesla Coil Generates Up to 50 000 Volts of Electricity!
  • Rick Reichlein May 11, 2010
    Do you want to make electricity by yourself or use electricity generated by the atmosphere?
    Scholar:
  • 79 Answers
Use a generator to make the voltage.
Posted on May 09, 2009
When I press start the electricty trips ?
u HAVE A SHORT SOMEWHERE AND NEED TO CHECK UR WIRING FOR BURNED OR FRAYED AREAS.
Dec 16, 2014 | Beko Washing Machines
Why it want make electricty are load up?
Must be up to full running RPM to generate the right operating voltage. If it is running at full throttle and there is no power out, then the generator head needs to be repaired.
Feb 06, 2014 | Coleman Electrical Supplies
Circut board trips electricty board
Treadmills are machines with a considerable pull of electricity. Make sure you are operating on a dedicated circuit.
Most users have the machine plugged into a spare bedroom outlet ehich is either not dedicate (power source spread out to more then one outlet) or is a GFI outlet (Ground Fault Indicator).
These outlets are used so homeowners do not overload an outlet in an area where a resident will sleep and be in danger of a fore or death.
Usually in the first few pages of your owners manual it will give you the requirements for your machine.
You can run an extension cord to another room with a dedicated outlet, but the extension cord does not transmit all the power coming out of the outlet and will eventually lead to other issues, usually electrical issues within the machine.
You can use a multimeter to see what else could be the issue with your outlet, but will want to consider having an electrician put in a dedicated outlet.
Jan 05, 2013 | Proform 400 CT Treadmill - Treadmills
No power electricty is going into machine but it has locked completely.
if you have no power going into the machine check your electrical breaker box to see if one of the breakers has tripped if this is a front load machine usually if the door locks up you can remove the lower panel on the very front bottom of the machine and reach up along the right side or if your door lock is oppistie on the left there is a small cord that you can pull to open the door to get at your clothes assure first that you have power going from the plug into your machine and as always if you are not used to doing electrical testing I would ask you to call a technician. It is always better to be safe when dealing with electricty if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Mar 14, 2011 | Washing Machines
SHARP AE-A244J no cold air
Your possible problem could be something as simple as cleaning your coils. The outside coil could be possibly clogged with dirt or the worst is cottonwood if they exist in your area, this depends on how long the unit has been installed, be sure to unplug-shut down any & all electricty to the unit, spray coils with a good dirt solvent, 409 works good for this, hose the coil with as high a pressure as possible, let dry for at least 1 hour before connect electricty. Inside coils get clogged also, with running unit without filter, or using for a long period on time. Sometimes these are hard to get to, although you should be able to see them, if not call a pro. Another prob. could be low on freon, another job for a pro, this means you have a leak in the system.
Lee
Dec 16, 2009 | Heating & Cooling
Static electricty in the house is excessive
thats just the light switch contacts begin to go need a new one
Mar 14, 2009 | Electrical Supplies
My dimplex electric heater is tripping the electricty supply
it louds like a limit switch is tripping because something is getting overly hot,the limit switch is a safety device looks like a little black part with a push reset button in the middle
Nov 16, 2008 | Heating & Cooling
GE side by side frig: JSS22JEMC WW
sounds like defrost or fan problem let me know and I can help you
Apr 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Lights are gone
Well, If You've Had It For Four Years, It Definitely Sounds Like Your Router Has Died So To Speak. Most Routers Only Tend To Last A Few Years Of Being On Constantly. I Would Suggest Buying Another Router Because The Cost Of Repairing This One Really Isn't Worth it. Good Luck, Brodey
Sep 15, 2007 | Siemens SpeedStream 2624 (SS2624) Wireless...
Watts Up! Our Tesla Coil Generates Up to 50 000 Volts of Electricity! Logo
207 people viewed this question
Top Watts Electrical Supplies Experts
rlev_7
Level 1 Expert
Steve
Jim London
Jim London
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
