Freezers
Problem for Freezers
Generic problem for all Freezers
Hole in the bottom of freezer
By mabbz on Sep 11, 2007
i have made a small hole (about 8mm long in the bottom of my freezer and the gas came out of it. will it work if i find a way to seal the hole and do you have any suggestions of how to seal it. thanks
Comments:
Sep 12, 2007
- it is a fridge freezer unit (Hotpoint 8332)
Same Problem
Aug 06, 2008
-   If I made a hole in the bottom of the freezer but no gas has come out ( I dont think so anyway) can it be resealed? Hole is narrow, less than 1cm long. Cheers-   boabzombie
Best Solution
posted on Sep 12, 2007
Very Helpful)
fishers
Rank: Wiz
Rating: 85%, 108 votes
Short answer no. The only way to repair it would be to strip back to the pipe cut the broken section out and replace it. If the broken section is aluminium this is even harder to correct. The system would then need to be vacd and recharged. Bearing in mind the evaporator which you punctured is on the low side you have probably got oil contamination which could mean the compressor could fail in a relatively short space of time. All of which means you are probably looking at a new unit. You can get this confirmed by explaining the leak to a local fridge guy. In my opinion it would cost more to repair than to replace. Hope this is of some help. PS this happens a LOT and is normally a fatal wound.
Was this helpful?
Yes
No
Popular Solutions for Freezers
Questions and Unsolved Problems for Freezers
Answer
I'm looking for an upright frost free freezer in white with between 16 and 20 cu ft and temperature... (More)
Answer
Hello I have a Westinghouse Freestyle Freezer - we bought it secondhand 2 weeks ago. The alarm light... (More)
Answer
the internal light keeps flashing
Answer
The freezer has stopped freezing. With the power on, the indicator lights at the bottom of freezer... (More)
Describe your Freezers problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Freezer Experts
Top Refrigerator Repairmen
in , MN
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(650) 616-9292
Refrigeration Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
