Question about Whirlpool MH7155XM Microwave Oven
Unit not getting power
The unit (Whirlpool Model MH2155XP) is not getting any power - circuit breaker is ok and there is power to the outlet. Light won't come on inside unit and range lite and fan will not operate. Is there a fuse somewhere inside the unit that could have blown? The unit is 3 years old.
    Brigadier General:
  • 4,088 Answers
These machines seem prone to having a bad magnetron. Look for a circuit breaker near the power cord entry point. If tripped, reset and try to heat a cup of water. If it makes a loud buzz and then pops the breaker again, the consensus view is a bad magnetron. This is one repair that is recommended to send out. (~$150). You need to evaluate the probable cost vs a new machine.
Posted on Nov 17, 2009
How do I fix a blown microwave fuse?
How to Fix a Microwave Oven - Simple Fuse Replacement ...
? 18:04
https://www.youtube.com/watch?v=IN0BqiVX5ds
May 21, 2013 - Uploaded by GuruBrew
How to Fix a Microwave Oven - Simple Fuse Replacement. GuruBrew .... I'm hoping it's just a blown fuse ...
Whirlpool Microwave Keeps Blowing Fuses - YouTube
? 2:35
https://www.youtube.com/watch?v=KGQgendKTR0
May 7, 2013 - Uploaded by AdamDIY
Whirlpool Microwave Keeps Blowing Fuses ... MicrowaveThermal Fuse Replacement - GE Microwave ...
Microwave Oven Repair 101 ' DoItYourself.com
Dec 06, 2015 | In Microwave Ovens
Need Glass that covers bulb lpool microwave
no plastic shield is required most of microwave oven comes with open light
Mar 29, 2014 | Whirlpool MH2155XP Microwave Oven
Tripping circuit breaker
That unit shows that it takes 15 or 20 AMPS to run. What is the breaker amperage on the circuit where it is plugged in? Is the breaker a GFCI? You can tell by looking for the two buttons on the circuit breaker or the outlet.
Jul 18, 2017 | KitchenAid KCMS1555RSS Stainless Steel...
Loss of power to Whirlpool over the stove AccuWave GH5184XPS-4. Checked circuit breaker and GFI -all OK. No other electrical problems known.
Remove unit and check trip/reset switch on unit. Double check GFCI receptacle with plug tester with GFCI test button.
Jan 12, 2010 | Whirlpool GH5184XPQ Microwave Oven
Does the rf375pxdw whirlpool range have a fuse or reset button? burners and oven does not work. there is power from the 220 plug into the range and the clock operates but not the 220. I checked circuit...
No reset buttons or fuses. Find the circuit breakers for the unit, it should be a double breaker with at least 40 Amp rating. Push it to the off position HARD (make sure not to pull the breaker out of the panel doing that). Turn it back on. Check voltage in the range power outlet. It should measure 220-250 Volts between the right and left connectors, and 110-125 Volts between the center and each side connectors. If not - problem is in the wiring or breaker. If you get those voltages and the range is still not working - problem is in the range itself. Check for shorted and loose wires.
Dec 18, 2009 | Microwave Ovens
My microwave just quit workin. It has absolutely no power.
Make sure breaker isnt tripped. If breaker isnt tripped just for the sake of knowing plug a fan or something you know that works in the outlet. If it works, you have probably blown fuses in the microwave you'll have to take microwave apart to get to them.
Aug 25, 2009 | Whirlpool MT4110SP 1100 Watts Microwave...
Microwave won't turn on. Seems like it is not getting power. I checked breaker. I am looking for a fuse. You know where one is? It is a GE Spacemaker(2 yrs old) model # JVM1440WH04
  • Make sure that the microwave is plugged into a grounded outlet. It must be a 3-prong outlet.
  • Make sure the clock is set.
  • Check to see if a programming sequence was entered. Sometimes improper programming or a program sequence such as delay start can cause the touch panel to be non-responsive. Unplug microwave or turn off house circuit breaker for 30 seconds. Plug back in, or reset circuit breaker, and try reprogramming unit.
  • Check the house circuit breaker or fuse box. If the microwave is DEAD and there is no display and nothing works- the problem could be a blown fuse or tripped breaker.
Jul 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
This oven does not operate any longer.
TAKE OFF THE CABINET AND LOOK FOR A FUSE THAT IS MORE LIKELY GREY AND MADE OF CERAMIC IT IS SHAPED LIKE THE OLD GLASS AUTO FUSES. NO VISUAL (GOOD OR BAD) MUST BE TESTED WITH OHMMETER FOR CONTINUITY
Apr 28, 2009 | Whirlpool MH2155XP Microwave Oven
Whirlpool over the Stove Microwave
This sounds like the unit is defective and if I were you I would return for replacment!
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool MH7155XM Microwave Oven Logo
176 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Jaime Hernandez
Gerry Harvey
Gerry Harvey
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
