Question about Hotpoint HSS25GFP Side by Side Refrigerator
FRIG AND FREEZER WON'T GET COLD AND FAN STAYS RUNNING WHEN DOORS ARE CLOSED
  • 3 Answers
Possibly low of freon, make sure coils are lent free and area around compressor is vacuumed clean, unplug it first before cleaning please.
Posted on Apr 16, 2009
I opened up my frig and the temp said the freezer was -13 and the frig is at 55 degrees. When I presed it down it changed to 2 in the freezer and 32 in the frig part. Put after about 3 to 4 seconds it...
the damper vent door between the freezer and fridge compartments is frozen shut or if motor operated it broken or the motor is bad or power to motor is missing to open and close this door to let cold air into fridge from freezer also there is an evaporator fan near here make sure it is operating or cold air wont be moved
May 22, 2011 | Refrigerators
Vegetable bin keep freezing food. Model # ED2CHOXKQ05
That can be the result of a couple things. Check to see if you hear the fan running in the freezer side? If not, since cold air falls, the cold air could be migrating from the freezer into the frig bottom section through the air duct hole in the back of the frig behind the crisper drawers. If the fan is running the check the air damper in the top left of the frig section. If the frig side is cold enough you should not feel air blowing through. Air flow is only very slight. You will have to remove some plastic cover or duct piece to see if it is closing. If the air damper seems to be working properly, you may have a refrigeration problem indicated by frost build up on the lower part of the freezer back wall. You may want to call in a pro at that point. Hope this helps point you in the right direction. Good Luck
Mar 12, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
My refrigerator isn't cold, but my freezer still works.
Put your unit on a 24 hr defrost the freezer coil is frozen and blocked with ice the fan cannot draw any chill from the freezer section.
May 17, 2010 | Maytag MFD2560HES Bottom Freezer French...
Frig side does not cool. freezer side cools
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Apr 16, 2010 | GE GSS25KGMBB / GSS25KGMWW / GSS25KGMCC...
The lower refrigerator section is not cold anymore
check to see if the fan motor in the freezer is running. all the cooling happens in the freezer and the fan is what circulates the cold air down to the refrigerator.. if the fan isnt running ,it could be a bad connection or a bad fan motor..on some models the doors need to be closed before the fan comes on so just push on the door switch to check .if the fan is running then a defrost problem may be the problem.. you mentioned you defrosted the unit. if the auto defrost isnt working, you would notice frost on the back of the freezer. there would be a lot more frost behind that panel that could block the airflow down to the frig. you would have to remove rear panel of freezer to clear all the frost and restore proper airflow..remember to unplug the frig before doing any work..
Mar 25, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Refrigerator will not cool It stays at 50 degrees Freezer works fine
Look for a blocked duct or a bad fan motor in the freezer. The cooling is done in the freezer and the cold air is circulated via ducts and a fan. No air flow= No cooling in frig. Long shot could be a light not going off when door is closed, seen that a few times in 20 years...
Eric
Nov 08, 2009 | Refrigerators
The freezer works but frig side isn't getting cold
sounds like fan motor between freezer and frig is bad,, you shoud hear it run when you open and close the door if this helps you in anyway be sure to rate me
thanks sawdust46
Jul 10, 2009 | GE Refrigerators
I have a Kenmore Cold Spot fridge, freezer on top. Fridge is warm, and freezer keeps freezing up on sides and bottom. I cleaned it all out, defrosted it, and it still freezes up and fridge still won't get...
Is this a self defrost model? Frost inside the freezer could be an air leak around the door gasket. Remove the back panel in the freezer and completely defrost the coils. Is the fan running in the freezer. That will make the frig not be cool. With the door closed peek in the gasket to make sure the light is shutting off, this will warm a frig also.
Eric
Jun 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer fan not running
Often times the defrost termination switch (which opens when it gets warm enough) will hold the fan off until it closes again when the freezer runs. It is possible that the switch is not closing, but be sure the freezer is getting cold enough for it to close.
You know the freezer is likely cold enough when you see frost covering the entire evaporator coil after a few hours of operation. A partial frost pattern could indicate low refrigerant, or a restriction of refrigerant.
May 29, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Freezer cold/Not Cold in Frig KITCHENAID Model KBLC36MHS01
I couldnt find a diagram of this frig.
Some of the evap. fans run thu the defrost thermost ..u could try by-passing thermost and see if fan comes on...  have you checked with volt meter if there was power at the fan motor?
Oct 31, 2007 | Refrigerators
Hotpoint HSS25GFP Side by Side Refrigerator Logo
155 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
