Question about Dell Dimension 8400 PC Desktop
My hadr drives does not turn on or make any sound.
My Dell Dimension 3000 hard drives does not turn on or make any sound. The screen is blank and the key board does not function but both will when connected to another computer. Is there a fuse that can be repalced and how do you change the battery?
Greg
  • gcalller Apr 13, 2009
    Thanks Jon,
    I think it is a power supply issue then since these lights do not light up now.
    Greg
    Scholar:
  • 101 Answers
There are 4 small lights on the back of the PC and these will tell you what is wrong. You can find the code meanings here:
http://support.dell.com/support/edocs/systems/ws450/en/ug/advanced.htm
Let me know what you find - it sounds like a power supply issue.
Jon
Posted on Apr 13, 2009
I have a DELL imension 3000 that is showing a blank screen when booted up. I have ran an express diagnostic check and it has given me the following error: Error Code:0f00:136C IDE Device Failed: Blank...
1.If there's a cd or dvd in the cd/dvd drive, remove it and try booting again.
2.press DEL at the start up screen to go into BIOS. go into BIOS and change the boot sequence options, set it to boot from the hard drive.
May 22, 2011 | Dell Dimension 3000 PC Desktop
My dell dimension 3000 goes to blank screen after it shows windows xp logo and seems to stop there, how do I fix this?
Have you tried starting in safe mood and then ran a scan of the hard drive, it could possably correct any file errors that the start up files may have Hope this Works Steve
Oct 01, 2009 | Dell Dimension 3000 PC Desktop
Dell dimension 3000. Just Black Screen no Windows XP.
From your description, you were able to boot the machine properly in Safe Mode. While in Safe Mode, change the video resolution to the lowest possible (color depth does not matter at this point). You should also check that you are configured for single monitor operation if your video card supports multiple monitors. Reboot the machine normally. If all goes well, you can readjust your video settings for a higher resolution again.
Jul 06, 2009 | Dell Dimension 3000 PC Desktop
Won't load windows...
you video card is not working.... if you have onboard video use that until you have installed the driver for your add on video card
Apr 16, 2009 | Dell Dimension 3000 PC Desktop
Blank screen when computer is turned on
When you get the Dell splash screen press the F2 key to get into setup. Use the arrow keys to go down to Drive Configuration and press enter. Go down to Primary Master Drive and press enter. Is the Hard Drive listed there? If not, that is your problem. Press Escape then use arrows to go down to Memory Information and press Enter. Is all of your Memory listed? If not, that could be the problem. Press "esc" to get out of setup. If the Computer does not freeze while in setup I would suspect the Hard Drive is bad. Is the Pointer responding to Mouse movement or does it lock up? In your situation I would first try to Boot from the Windows CD. Write back and I can explain how to do this. If that does not work I would begin to test Hardware. Do you hear any Beeps when the unit is turned on? If you can, E-mail back with more Info.
Jan 16, 2009 | Dell Dimension 3000 PC Desktop
Dell dimension 3000 hard dirve what type do i need to install a sata pata or ide
Hi
Dell Dimension 3000 accepts IDE hard drive. Any modern IDE drive should be fine
Check out Dell Dimension 3000 Service Manual for spec and how to remove and install parts.
Mike
Aug 21, 2008 | Dell Dimension 3000® Pentium® 4...
Reinstalling windows on new hard drive
Place the windows cd in the drive and re-boot.You should be prompted to press any key to boot from the cd.After that,just follow the on-screen instructions.It's really pretty simple!Hope this helps!
Feb 20, 2008 | Dell Dimension 3000 PC Desktop
Won't turn on...
the fault is in the connector.do check it properly.else replace it
Feb 03, 2008 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 reformat trouble
please re partition the hard disk and install the operating system. if the same error continues then change the ram and try
Jan 28, 2008 | Dell Dimension 3000 PC Desktop
Used Dell Dimension 3000 drive issues
If you mean you need to install windows, you need to set your cdrom drive as first boot device in advanced bios settings or it will try to boot into a non-existent windows. Make sure your hdd is showing as the master drive, save settings and exit bios. Re-boot pc with windows disc in cd drive and hit enter when prompted to boot from cd.
Jan 26, 2007 | Dell Dimension 3000® Pentium® 4...
Dell Dimension 8400 PC Desktop Logo
mukhtar21 shaikh
mukhtar21 shaikh
