Question about Water Heaters
Have an electric Power Star tankless hot water heater, PS28T. Have had on-going problems with lack of continuous heat as well as having to replace elements regularly. The last replacement was 2 months ago. Now both the left and right element lights have gone off! I apparently do not have a local repair person who knows anything about them. I do have a plumber who has helped just by replacing the elements but he doesn't know why the elements keep going out. Most of the elements have had the metal coil in the element broken but some have not. There does not appear to be any buildup on the element. There is minimal hot water use in my house since I'm single and mostly wash clothes in cold water. I only run the dishwasher every five days or so but do take a bath daily. I'm really frustrated. Can you help!! Carole from Missouri
  • cmhayes Apr 18, 2009
    I have the instruction book and both my plumber and I have read it. Everything appears to be set correctly and it has worked properly previously. No "troubleshooting" comments appear to be applicable. Elements are new. The referral tohttp://home.howstuffworks.com/water-heat... only discussed "regular" hotwater heaters, not tankless ones.
  • 15,935 Answers
CLICK HERE for the Owners manual to your unit.
It is my experience that a unit with a high element failure rate is primarily due to the thermostat being improperly set... and the element heats up to maximumm ALL THE TIME.
To set the thermostat properly -
a) Flow enough hot water to activate unit. The indicator light on the black flow control board
should illuminate.
b) Further increase the hot water flow and the indicator light o n the clear thermostatic board
to the left of the black board should illuminate. Note: This light should pulse On and Off at
first and after about 20- 30 seconds it should stay fully on.
c) Further increase the hot water flow and the indicator light o n the next clear thermostatic
board (PS28T model only) should illuminate. Note: This light should pulse On and Off at
d) Set (PS19T) thermostat to achieve the desired outlet temperature.
Set both (PS28T) thermostats to the same position to achieve the desired outlet temp.
e) The thermostat is now set and the water temperature will alwa ys be the same when the
indicator light is pulsing.
f) Increasing water flow (above the flow rate at which the thermostatic control is no longer
effective) will reduce the water temperature.
If a lower temperature is required for the PS19T, turn the temperature adjustment screw
counter-clockwise about 1/8 of a turn (See pages 3 & 4 for adjustment location). Wait 15-20
seconds and check the temperature at the fixture. Repeat this process until the desired
temperature has been achieved.
For PS28T model try to adjust the 2 temperature adjustment screws by about the same
amount so that the lights pulse at the same rate. If you have reduced the temperature
considerably from the 140 F setting, you could now open up the o utlet ball valve slightly to achieve
a higher rate of flow.
When the indicator light is on continuously, the unit is emitting full power. When it is pulsing, the
unit is modulating the power to achieve the temperature set by means of the temperature
adjustment screw.
In order to obtain good control at “single lever” mixer type faucets (single spout) the cold water
supply to the faucet should be restricted to give approximately the same flow rate of cold water
to the faucet as the hot water coming from your Powerstar heater. The simplest method of
doing this is by partially closing the cold water valve under the sink.
Also - since the plumber does not have knowledge of tankless heaters - be sure that once elements are replaced - that the water is turned on for a few minutes BEFORE powering up the heater. Water pockets can develop around or inside the heating element tube and burn out the element prematurely. it must be surrounded FULLY by water at all times when heating.
You havent told the age of the heater - but there may also be sediment buildup around where the element is inserted that does not allow water to fully encompass the element as well.
Next time you have them out - make sure there isnt a pocket of lime where the element is.
Thanks for using FixYa !!
If you need further clarification about your question - please use the "continue with this expert" option so we are connected in the future.
Thank You!! :D
Posted on Apr 18, 2009
    Brigadier General:
  • 3,917 Answers
Hi Carole,
Please find the instruction manual for your type of heater in the bellow link:
http://www.electricwaterheaters.com/pdf/OldPowerstar.pdf
Keep this handy as it's instructions will help u from time to time.
Also please find a detailed troubleshooting of various parts of the heater ( primarily the elements) in the bellow mentioned links.
http://home.howstuffworks.com/water-heater1.htm
Thanks
Have a nice day.
Posted on Apr 13, 2009
I have a power star ae115 electric tankless water heater. It has performed flawlessly for approximately 5 years. A couple weeks ago it stopped producing HOT water but is still heating to Luke warm. The "...
5 years is about the lifespan for tankless.
You might have shorted element. That would explain cooler water and tripping reset.
Test element: power is off, disconnect wires from element; ohms = voltage squared divided by watt rating of element
http://waterheatertimer.org/How-to-test-water-heater-element.html
Call service technician./ Call Bosch
http://waterheatertimer.org/pdf/Bosch-AE115-AE125_manual.pdf
Gene
Oct 14, 2014 | Water Heaters
There is power to the system but when you turn water on elements do not come one and heat water. all phases have 238 volts to them. why will system not turn on and heat water
Do you have 3-phase water heater? Is this balanced or unbalanced 3-phase unit. Add comment and describe product in detail, including brand since i have some service resources for both types.
Or do you have ordinary residential split-phase 240Volt Bosch tankless computer that heats water, and has 2 or 3 separate elements, and a separate circuit breaker supplying power to each element? And testing across both hot leads coming from each breaker yields 238Volt?
Copy following link for Bosch tankless manuals, with brief troubleshoot section that does not provide detailed service procedures for repairing tankless computer:
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html#manual
If this is new water heater, then call installer. If you installed yourself, then remove tankless and return to seller for refund.
Tankless computers require certain amount of water flow to activate computer sensors. Turn on Hot tap and listen to pipe to hear if water if flowing through hot pipe. Check for crossover:
http://waterheatertimer.org/Crossover.html
Clean water filter usually located just above where cold water connects to unit.
Delime tankless ... and use water softener. Tankless cannot be exposed to more than 11 grains hardness in water, or parts will fail within 2-3 years. Simply deliming tankless heat exchanger each year will not maintain full efficiency... although for typical family of 4, tankless comper water heater costs $100 more to operate than tank-type heater according to manufacturer's promo literature and independent studies.
Call local technician who specializes in fixing tankless computers. For plumbing problems call local plumber. These are two different things.
If tankless computer is older, then cut losses, and buy tank-type electric water heater at Lowes for $285 and make quick changeover and have hot water same day. Sell old tankless on ebay and cheat next guy, or sell at scrapyard for $3 per 100.
Gene
h
Aug 05, 2013 | Bosch PowerStar AE125 AE125 Whole House...
I have a PowerStar tankless electric water heater, model #44-557710 and it was replaced about 3 months ago. This morning I had hot water and this afternoon I do not. When I call for hot water a red light...
Call Bosch. And exercise your 10 year parts warranty rights.
Copy following link for Bosch power star manuals:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html#Ariston
Check circuit breakers, fully off and then fully back on. Test if voltage is at least 80% rating plate on unit. Check that temperature dial is set correctly. Call for service again.
Don't install tankless computer that heats water. You cannot fix this computer yourself, and they are problematic for owners.
Go to Lowes right now, spend $285 and buy tank-type electric water heater, roll it into your house, and save money, since the electric tankless computer heater costs average $100 more per year to operate than tank-type heater for average family of 4.
Tank type heater can be repaired by homeowner same day for $25 using off-the-shelf parts from hardware store. And that empowers the regular guy, and gets you off the junk tankless treadmill.
Gene
Aug 03, 2013 | Powerstar Water Heaters
No hot water
10-22-12
Copy following links to help identify product and download possible troubleshoot resources:
Tank-type gas
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Tank-type electric:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Rheem tankless:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Other types of water heaters include boiler, tankless electric, indirect, solar-assisted, solar, hybrid electric, heat pump, wood-burning, gas hybrid, 3-phase commercial electric.
Oct 21, 2012 | Rheem Water Heaters
Rheem rte13 standby (green) light not on
You might have crossover problem caused by bad faucet cartridge.
The green standby light should come on when 240Volt power is applied. Page 6 manual.
Both red lights should come on when tankless is activated. Page 6 manual
RTE 13 requires 60 amp breaker and 6 gauge wire
http://waterheatertimer.org/pdf/Rheem-TanklessElectricUC_AP15447.pdf
Factory temperature setting is usually default 120 degrees.
Adjust temps page 11 manual
Thermostat calibration is always approximate.
120 degrees is not hot enough to burn the skin.
Exceptionally cold incoming water temperature can cause tankless not to heat enough hot water: install tempering tank to preheat water to room temperature.
Tankless cannot be exposed to more than 11 grains hardness in water. Delime tankless yearly, clean water filter monthly, do not install low-flow restrictions or conserve water since the flow rate must remain high for tankless to activate.
Rheem does not post service manuals for their tankless water heaters.
Call Rheem 800 432-8373
Aug 05, 2012 | Rheem Tankless Hot Water Heater...
My Rheem tankless water heater has been flashing a C8 and 76 code. I can turn off the heater using the power button on the unit, but my hot water will only last for a shower or so. Any suggestions? ...
Before calling service technician, open following link for troubleshoot resources including Rheem chat and contact, possible manual, error codes, etc.:
C8 76 is generally bad PC board. Call 800-432-8373
Just like a motherboard on your computer, the tankless PC board is operational center of tankless water heater.
Various sensors gather information from water pipes, gas line, vent pipe, and air supply to determine when to activate burner.
Most people understand that when their computer motherboard needs replacement, that computer will probably not work reliably again.
Tankless is basically connecting a complex computer to your plumbing and electrical lines and to a gas burner with a vent pipe to outdoors, despite knowing that plumbing lines, vent pipes, gas burners, and household electrical systems have plenty of problems on their own.
Age factor: When tankless is new and everything operates perfectly, the tankless works correctly.
And each tankless manual recommends yearly and monthly maintenance, just to maintain operation, the cost of which can exceed the expected 1-8$ monthly savings. And who wants to clean the water filter each month and delime the exchanger every year?
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
Don't buy a tankless water heater because the only folks promising unlimited hot water and effortless water heating experience while saving money with a tankless are the tankless promotors.
Solve most tankless problems yourself, same day, any brand for about $350.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Sep 22, 2011 | Rheem Tankless Water Heater Main Remote...
Powerstar 115 tankless tripping reset ontop of #2 heat chamber #1 does not get overly warm mainly because of incoming water temp. but #2 seems to be heating after water flow stops to hot to touch and...
I don't have specific suggestion for tankless tripping breaker or if that is a circuit breaker problem or a tankless problem.
1) Move wires to another same-size breaker and see if problem persists.
2) Compare amp draw on tankless label with wire size and breaker size amp rating.
For example 30 amp breaker using 10ga wire is rated for 80% of listed amps or 24 amps.
3) If you are drawing full 30 amps, then 30 amp breaker is getting hot. Breaker trips with heat. Older breakers can trip more easily.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
4) Before calling service technician, open following link for Bosch troubleshooting steps.
5) Be sure to read manual for yearly maintenance requirements.
6) Add a tempering tank for incoming cold water problem.
http://waterheatertimer.org/Tempering-tank.html
7) All gas tankless brands can be repaired by homeowner for $330.
Apr 22, 2011 | Bosch PowerStar AE115 Tankless Water...
Code 73 on a noritz tankless propane water heater
73 code is a circuit board error. It typically occurs if you connect or disconnect anything in the heater with power on. Try disconnecting electricity for 20 seconds to reset the unit. If the problem continues, you may need to replace your circuit board.
Apr 08, 2011 | Noritz 7.1 Gpm Propane Lp Gas Tankless Hot...
No hot water can't even take a shower
If there is only cold water coming out from the water heater, there is no doubt that your RTO water heater
is defective.
1. Shut the power supply going to your heater off.
2. You can check on it, by opening it up.
3. Trace the wires coming from the power supply.
Using a multitester, check the continuity of each
line. Set the tester to Ohms 1 x 10. Put the multi
tester probe to each end of the electrical line, one
line at a time. The pointer must point to zero.
Otherwise, it must be replaced.
4. Test the heater coil for continuity. One of the multi
tester probe must be placed at the common termi-
nal. Put the other probe to the other terminals. The
pointer must be at zero, otherwise, you can
replace the heater unit, since this is already
busted.
Nov 24, 2009 | RTO American Heat Tankless Electric Water...
Water Heaters Logo
129 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
