Question about Refrigerators
Model # FRT18PRH Serial # BA91502984 manufactured 04/99 burnt Relay/Overload was replaced any recall ? Thanks
5 Suggested Answers
  • 90 Answers
SOURCE: (Overload and relay switch)
hey Louie -- I had the same problem -- maytag is a waste of help unless it still is in warrant
you need to replace the overload relay --- the kit cost $26.00
go to appliancezone.com
part # 4387835
email me with any more questions
Posted on Dec 30, 2008
  • 68 Answers
SOURCE: Burnt out relay/overload assembly, compressor won't run.
it can be difficult to get the right one for it, however there are eletronic ones on the market that will do the job.
it could have been caused from the unit cycling off and on to quick, or the compressor drawing to much current
the windings should be tested with a multimeter to see if they are faulty or not
Posted on May 02, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: starter overload switch
Relay is bad just replace it it is a safety to keep the compressor ok in the event of power surges or failures
Posted on Jun 02, 2009
  • 1531 Answers
SOURCE: I have a kenmore refrigerator model 2537481240E.
the part you need or at least should work for you is 4387835.
Posted on Jan 22, 2010
I replaced the relay board because the relay on t relay on the far right was burnt and melted where the black wire connects. now my new relay board burnt and melted the same place. what can be the...
Hello. I looked up your model range and found many service bulletins associated with it. Among those was a RECALL due to burn/fire hazards from the burners not shutting off and the temperature setting can increase unexpectedly. The model years affected were from January 2006 to June 2010. I've attached a pic of the affected serial numbers. You can obtain a free in-home repair by contacting LG at (855) 400-4038, toll free. I hope this helps you!
Aug 15, 2014 | LG LRE30453ST (Electric) Stainless Steel...
I have a Whirlpool side by side 22 cubic foot Model ED2FTGXKT it was manufactured in 03 and purchased in 2004. Woke up Friday morning to a strong electrical burning smell. Could not find the culprit...
HI,seen this a couple times when i did apartment maintenance,check the box that is attatched to compressor.If it has burnt wires before the overload and relay you my have to replace them .If the overload and relay are loose from compressor you will need replace compressor but would be more cost effective to replace frig.
Mar 06, 2011 | Refrigerators
Not cooling clicking sound refrig compresso and
IT'S MOST LIKELY THE START RELAY/OVERLOAD PROTECTOR ON THE SIDE OF THE COMPRESSOR. UNPLUG UNIT AND PULL START RELAY OFF AND SHAKE. IF SOUNDS LIKE IT'S FULL OF GRAVEL IT'S BAD, OR GET VOLT /OHM METER AND CHECK CONTINUITY BETWEEN THE START AND RUN TERMINALS ON BACK SIDE OF RELAY, WHILE YOUR THERE CHECK CONTINUITY BETWEEN THE BACK SIDE OF OVERLOAD AND WHERE L1 WIRE COMES IN FROM THE HARNESS. IF ALL THAT CHECKS OUT THE COMPRESSOR MIGHT BE BAD OR DRAWING TOO MUCH CURRNET FOR THE FACTORY START DEVICE. YOU DIDN'T NOTE A SERIAL #, SOME OF THOSE MODELS WERE UNDER RECALL FOR THE RELAY/OVERLOAD PROBLEM.
Oct 06, 2010 | Maytag MSD2756G Side by Side Refrigerator
The recall on this Product Model No JCD2295HES Serial No 10121219EL Purchased at Sears Date of Purchase 8-2-2004
this recall had to with you overload and relay
they came out bad and have a problem of starting fires from overheating
call maytag they will tell you if your machine is affected,,,
they are the only ones with the list
Oct 09, 2009 | Jenn-Air 21.6 cu. ft. Side-By-Side...
Starter overload switch
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
May 02, 2009 | Refrigerators
Frig recall which model? Maytag refrigerator MTB2156GE* heard report of recall due to possible fire hazard
Name of product: Maytag®, Jenn-Air®, Amana®, Admiral®, Magic Chef®, Performa by Maytag® and Crosley® brand refrigerators
Units: About 1.6 million
Manufacturer: Maytag Corp., of Newton, Iowa
Hazard: An electrical failure in the relay, the component that turns on the refrigerator’s compressor, can cause overheating and pose a serious fire hazard.
Incidents/Injuries: Maytag has received 41 reports of refrigerator relay ignition, including 16 reports of property damage ranging from smoke damage to extensive kitchen damage.
Description: The recall includes certain Maytag®, Jenn-Air®, Amana®, Admiral®, Magic Chef®, Performa by Maytag® and Crosley® brand side by side and top freezer refrigerators. The affected refrigerators were manufactured in black, bisque, white and stainless steel. They have model and serial numbers printed on a label located on the top middle or left upper side of the refrigerator liner and have the following model and serial number combinations:
Serial Numbers ENDING with AND Model Numbers BEGINNING with Side by Side
Refrigerators AA, AC, AE, AG, AJ, AL, AN, AP, AR,
AT, AV, AX, CA, CC, CE, CG, CJ, CL,
ZB, ZD, ZF, ZH, ZK, ZM, ZQ, ZS, ZU,
ZW, ZY, ZZ ARS, CS, JC, JS, MS, MZ, PS Top Freezer
AT, AV, AX, ZK, ZM, ZQ, ZS, ZU, ZW,
ZY, ZZ AT, CT, MT, PT Refrigerators with freezers on the bottom are not included in this recall.
Sold at: Department and appliance stores and by homebuilders nationwide from January 2001 through January 2004 for between about $350 and $1600.
Manufactured in: United States
Remedy: Consumers should immediately contact Maytag to determine if their refrigerator is included in the recall and to schedule a free in-home repair. Consumers should not return the refrigerator to the retailer where it was purchased.
Consumer Contact: For more information, contact Maytag toll-free at (866) 533-9817 anytime,
Mar 10, 2009 | Maytag MTB2156GES Top Freezer Refrigerator
Kenmore model 525321 overheat problem
hi thanks for the question after your husband replaced relay & overload if the compressor started & kept on running but no cooling you have a bad compressor
Sep 13, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Relay and overload on the compressor
the relay will be burnt up inside, shake it and little pieces will come out if its burnt out. the overload usually is never the problem
Mar 12, 2008 | GE GSH25KGRWW Side by Side Refrigerator
Refrigerators Logo
158 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
