Dispenser drawer and tub
Where the dispenser drawer slides in, a portion of it is cracker and a hole in it. It will not dispense bleach or fabric softner. The tub in washer seems loose and bangs loudly when washing.
Softner dispenser has pushed down into the dasher. How to take off top of dasher to replace the small softner dispenser cup that was pushed down.
Posted on Apr 17, 2010
How do I get the bleach dispenser to drain?
Hello Denise C - There are several things that could cause the bleach to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is bleach? If it is pure bleach, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the bleach dispenser with water. The bleach dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the bleach solenoid is energized and water flows into the bleach dispenser cup. When the cup is full the water siphons out and bleach and water flow into the tub.
If the liquid in the bleach dispenser is pure bleach you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the bleach solenoid and a volt meter is required.
If the liquid in the bleach dispenser is water you probably need to clean the dispenser cup. Scum will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the bleach and overflow the dispenser cup and run into the tub.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the bleach compartment. When the water level goes above the maximum line stop pouring. The water should all drain out. You may also test the fabric softener compartment the same way.
I do hope this information proves to be helpful.
Jan 01, 2013 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
My Frigidaire front load washer will not dispense the fabric softner during cycle.
Clean the dispenser drawer if water is introduced into the fabric softener cavity but does not dispense. Pull the dispenser drawer out until it stops and push down the release tab marked "PUSH" and then pull the dispenser out completely.
Lift the dispenser drawer cover and clean the tubes both in the dispenser drawer and the cover.
Turn the drawer over then release the conveyor from the tabs and lift it off. Clean the conveyor and the drawer thoroughly.
Snap the conveyor into the tabs back into position and then reinstall the dispenser cover making sure the tubes are properly seated.
Slide the dispenser drawer back into the drawer opening while pushing down the part marked "PUSH".
Let us know if the fabric softener dispenser still does not dispense while both the detergent and bleach dispensers dispense.
Mar 10, 2010 | Frigidaire ATF6000ES Front Load Washer
How to clean fabric softner dispenser sear 70 series cc3815443
hi friend,
step 1
Pull the dispenser drawer out until it stops.
  • Step 2 Reach into back right corner of the drawer opening and press the lock tab to release the drawer. Pull the drawer fully out of the washer.
  • Step 3 Lift the fabric softener dispenser cup out of the drawer.
  • Step 4 Run the fabric softener dispenser cup under warm water while rubbing it with a soft cloth or sponge.
  • Step 5 Place the cup back in the drawer and slide it back into the washer.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • You can also remove and clean the prewash, detergent and bleach detergent cups by following Steps 1 through 5.
    hope this helps u
    please rate me.....................
    thank u for using fixya
    regards
    sivaranjini
    Nov 30, 2009 | Washing Machines
    Fabric softener/bleach dispenser full of water
    You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
    Pull the dispenser drawer completely out.
    There is a tab that needs to be depressed to release the drawer and remove it.
    Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
    Reach down into this opening to see if an item is inside the hose.
    This is the normal issue that will cause water to leak out of the dispenser housing.
    http://media.fotki.com/1_p,wbwdbgswgksbgfwxgtqsskgwtqkq,vi/ktfgsrbbdxwtwtqtfwk/1/1303472/5961857/image45924img-or.jpg
    Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Sep 08, 2009 | Kenmore 46462 Front Load Washer
    Bleach & Softener not emptying
    Feb 26, 2009 | Kenmore 46462 Front Load Washer
    Bleach and fabric softner despenser liquids not being used.
    Feb 25, 2009 | Kenmore HE2 Plus Front Load Washer
    MAH8700AWW - No Fabric Softener
    Not sure if you've ever resolved this issue, but I'm dealing with it myself. I have come across this service manual that gives a very detailed illustration of the systems, how it works and how to test it.
    Focus on pages 15 thru 25. Hope this helps you.
    http://www.servicematters.com/maytag_library/docs/16026126.pdf
    Jan 26, 2009 | Maytag MAH6500 Neptune Front Loading...
    Washer
    remove dispenser drawer with rag and bleach water mix wash as good as you can the top of dispenser housing aroud holes to remove build up ..if problem is still there entire assembly will need to be removed and flushed thoroughly build up is blocking the holes over the dispenser cups
    Jun 01, 2008 | Kenmore 43042 Front Load Washer
    Fabric Softener Won't Dispense
    The fabric softener dispenser is notorious for clogging. Liquid fabric softener is essentially a liquid form of wax. After a period of time it begins to gunk up the inside of the fabric softener dispenser. If you remove the dispenser drawer and look into the cavity, there should be a series of holes in the upper part of the compartment where water sprays into all the dispenser trays. These holes get gunked up and clogged and water will not dispense properly. As a result, the washer goes through a complete cycle, but the dispenser stays full. If this is the case, you can take some cotton swabs and/or toothpicks and clean these holes real good. It may be a bit meticulous, but it should take care of the problem. Post back and let me know if this helps.
    Feb 11, 2008 | Maytag Neptune MAH6700A Front Load Washer
    Washing Machines Logo
    102 people viewed this question
    Top Washing Machines Experts
