Question about Acer Aspire 5500 5570-2609 Laptop
Will not turn on, power supply/charger good. no lights on.
Can not turn on any more. Power supply is good. What should I do to get it to turn on?
3 Suggested Answers
SOURCE: Acer AL1714 17" LCD Monitor Good Power supply no power on monitor
Hello, I have to same problem. I returned my monitor to Acer but got it back unrepaired, they could not see the malfunction. But I kept on sending it back, until I got a new model. Now after 2 years I get the same thing with this monitor. But there's no warranty anymore, so I looked into the problem myself. I found out that inside the powercircuit board is connected to the mainboard through a 10pin connector. The 5 pins that are on the lowest row, show a trace of white powder, I suppose occidation. I sprayed a little of contactspray in it. I must say the problem is not gone, but much better. The problem shows not so frequent anymore and lasts not so long. At first the screen switched of for 3 to 5 minutes and came back on. Now the screen is gone for perhaps 1 second and returns. So I'm almost convinced the problem has something to do with the connection of the powercircuitboard inside and the mainboard inside, when the monitor heats up a bad connection occurs due to occidation of the 10 pin connector. If you find a solution that fixes the problem 100% let me know, please. Mario.
Posted on Apr 29, 2007
  • 5 Answers
SOURCE: Acer veriton M460 will not boot up
The acer veriton m460 has three faulty capacitors. Check and see if you have bulgy capacitors. I have ten of these computers and all have three blown capacitors.
Posted on Apr 03, 2011
This acer is completly deaa.getting a lot of answers but pc needs to be on it is dead no charger no on light nothing.
take out the battery and try it with just power supply ONLY connectetd to it no printer, nothing. If it still does not come on AFTER you hit the power button and NO lights test the power supply. If the power supply is good then the DC jack might be damaged. AT this point have it serviced or time to replace laptop. Good Luck.
Nov 06, 2015 | Acer Computers & Internet
I have a HP/Compaq 6510b laptop computer and it will not turn on...I have the charger plugged in and the only thing happening is the green light periodically flashes...Is the battery bad?
IF the battery is bad the charge lndicator on the laptop will flash (But not periodically) it will be a constant on-off-on-off..... Best check would be to remove the battery completely and use the adapter/charger power supply only. If it still does not turn on then you either have a bad power jack connection or a more serious motherboard problem. Also is the green light flashing on the adapter/charger or is it the charge/battery indicator on the laptop?
Feb 17, 2011 | HP Original HP COMPAQ 6510b 6515b 6710b AC...
Laptop wont start at all. plug in to power supply and battery charging light comes on.still wont start up...
try diconnecting the charger and holding down the power up button for longer, then try plugging in charger- turn on charger at wall then hold down power on button till power button on key lights up, i hope this helps you out ;)
Feb 07, 2011 | Computers & Internet
My laptop hangs everytime i use the power supply (adp-75sb ab) provided for this unit (toshiba satellite a205-s6808) but when i start my laptop with the battery, everything works out fine. it only hangs...
Check the voltage output from the charger and see if it is within the range that is stamped on the charger body (eg: 20 volts) If it is below or above this, then the charger is faulty. If the green light is flashing on the charger, it means that power is "not being accepted" by the laptop and this indicates a faulty charging port / circuit.
Jan 18, 2011 | Toshiba Computers & Internet
I have a Jazzy 14 xl when plugged in the charger shows full charge and every thing lights up but when u unplug the charger it has no power
same thing as the other fellows problem Batteries!! the charger is supplying the power to light up the joystick but when not plugged in the batteries are so low they can't turn your chair on. Replace both batteries good luck Hope this helps
Oct 30, 2010 | Pride Mobility Products Used Jazzy...
LAPTOP WILL NOT TURN ON . GATEWAY 8738. NO LEDS LIGHT ON FRONT. DOES NOTHING BATTERY IN BATTERY OUT. WILL NOT TURN ON. I SUSPECT MOTHER BOARD
You could well be correct but just to make sure.
You need to beg, borrow or steal another known good power supply/charger unit and see if that works. You see if yours in faulty, its not charging the battery or supplying power to the laptop.
If nothing glows after that it could be the charger circuit on *********** board or just the power connector on the motherboard .
May 11, 2010 | Gateway MX8738 Notebook
Charger was plugged in and working fine, went into
OK unplug power supply from back of laptop, remove battery, insert power supply, if NO light, on laptop, power supply is broken..Replace. IF it is OK, hold power button ON for a while, or until, the PC starts, if/when it starts, shutdown, with power ON key, and then take out power supply, replace battery, replace power supply, turn laptop on, now should be OK.
Mar 01, 2010 | Toshiba Satellite A70-S249 Notebook
Fried something?
A half volt will not make any difference. Sounds like the power supply is malfunctioning. Start by trying a different one. Keep in mind that you may have fried the new motherboard by using a faulty power supply. Popping sounds indicate a short or loose/exposed wires, and are never good with any electrical device, especially a laptop since they are sensitive to power fluctuations to begin with.
May 14, 2008 | HP Compaq Evo Notebook N600c
Acer Aspire 5500 5570-2609 Laptop Logo
46 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
