Question about Frigidaire Gallery Series GLRT13TEB 30" 20.5 Cu. Ft. Top Mount Refrigerator w/ 2 Sliding Glass Shelv...
Frige is running but blowing warm air in freezer and frige running but not cooling. just blowing air like a regular fan. the air is not cold at all even after i left it running for a long time.
  • zamfira72 Apr 14, 2009
    he came by and said to change or clean the filter or add some freon. i can't afford the expense for a while and i was looking for a way to do it myself. any ideea?
  • pcmufc May 11, 2010
    This sounds like your fridge is short of gas or it could be a faulty compressor you would have to get an engineer to check this
    Problem Solver:
  • 14 Answers
Theres not really any solution if its short of gas you would need to buy the gas and gauges which would be a lot more expensive if you knew an engineer that would do it outside work hours you could get it done a lot cheaper which might keep you goin for a while but if its short of gas there is more than likely a leak somewhere and if its not fixed it will end up costing you more money in the long run
Posted on Apr 17, 2009
My frige & freezer do not cool,light & freezer fan run,compressor & coil fan do not run,air is blowing out of air vent in freezer,no cooling at all
If the compressor isn't running, the refrigerator or freezer won't cool - period. Hopefully, by now, you've had a repair technician come and troubleshoot the problem.
Aug 06, 2014 | Frigidaire Gallery GLHS66EJSB Stainless...
Frige freezer works fine but frige does not. 6 yr old kenmore 596.75509400 model
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 25, 2011 | Refrigerators
My frige is not cold, just cool, turn the T stat to coldest & no good. The freezer seems fine & I looked in the back & the fan is running. It doesn't seem to be blowing cold air or...
Two thoughts. If the fan is running... and you can here it in the freezer when it is on. Then the fan is fine and it is the mixer control. IF the fan is not working, then fix the fan.
The mixer control is in the top of the fridge where the air comes out on the wall between the fridge and freezer.
I think maytag calls this a cold control / damper.
Basically it controls the air flow rate between the fridge and freezer. When it is opens it allows air from the freezer into the fridge and cools it off.
Hope this helps.
Jun 17, 2010 | Maytag MSD2756G Side by Side Refrigerator
Not getting cold enough to freeze, How to check Freon
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 05, 2010 | Kenmore 53082 / 53084 Side by Side...
Freezer is cold, refrigerator is warm. sounds
check the fan from the freezer side if its not running /possible frozen or jammed will cause the refridge side to be warm the fan blows the freezer air into the fridge side to cool their is also a damper or duct control which can build up if no blockage or debris test fan for power if power than test fan it self if not running than repair or replace as necessary
Apr 09, 2010 | Amana BC21V1W Bottom Freezer Refrigerator
Frig not cooling , you can hear it running but not getting cold, freezer works.
SOUNDS LIKE THE FAN MOTOR IN FREEZER IS NOT WORKING . THAT WHAT BLOWS THE COLD AIR INTO THE FRIGE
Sep 21, 2009 | Refrigerators
Refrigerator compartment cools correctly for a few days then no longer receives cold air from freezer. The freezer continues to operate and gets much colder than it should.
does your fan blow? freezers have a fan that pushes cold air to the fridge side if fan is bad freezer will run extremely cold and fridge won't cool down and since frige won't cool down thermostat in fridge doesn't tell compressor to stop
Feb 26, 2009 | Refrigerators
Ive got a beko frost free frige freezer,the fridge is at the right temp but the freezer has all of a sudden started to warm up? the fan is going round and blowing out cool air but not cold enough to...
all working fine now, i took everything out of the freezer and turnerd it off for an hour then i cleaned it out and hoovered round the back and swiched it back on and straight away it was blowing freezing cold air, its still going now so i think its ok! thanks.
Jul 05, 2008 | Refrigerators
KENMORE SIDE BY SIDE NOT COOLING
You should hear a fan running inside the freezer. It also blows cold air into the refrigerator side.
Jun 09, 2008 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
