Question about Toto UltraMax One Piece Toilet, 1.6 GPF - CST854S-11 - Colonial White
Have to flush 3-4 times. water level in bowl is very low after the first flush, and then gradually gets higher.
  • 146 Answers
Check the float it might to high the lower the float the higher the water.
Posted on Jun 24, 2009
Where can a get a Part for a Pagasus Toilet .
You can adjust the water level so more water comes in so it fills higher to flush
Jan 25, 2018 | Home
How do i get more water in the toilet bowl?
On some toilets the float level is adjustable inside the tank. If there is an arm with a large ball attached then bend the arm up slightly. If it has a small plastic float then some of these can be screwed up or down on the tube supporting the float. The higher the float the more water that will transfer to the bowl. If your house is built in the 1980's or newer then you should have all plastic pipe and I would switch out to a low flush toilet. If your house is old (pre 1960) then you have cast iron or clay pipe and you may want to keep your 3 gallon flush as long as you can. If you are in the between zone then you need to check and see what kind of pipe was used. A smooth wall pipe requires less water to flush. If you go with a new toilet go for a mid grade one. The cheep ones have poor castings on the inside and it causes friction that results in a miss flush more often. I like the Delta with 3 bolts on the tank in the $150 to $200 price range. If all else fails a new flush valve will come with instructions and they do go bad after a while so now may be a good time to replace it. Flowmaster has been pretty good to me and you can pick one up for about $20. There are ones that are supposed to shut the water off if the flapper sticks but they take a bit more experience to figure out how to set them and you will find yourself flushing the toilet and nothing is happening because the float switch has the water shut off.
Oct 22, 2014 | Home
Water level in bowl low
Turn knob on top of float ball to increase ball height which will increase water column. Up to 1" of overflow tube.
Nov 08, 2012 | American Standard Cadet 3 Right Height...
Water level in bowl is too low so it's a problem keeping it clean. How can I raise the water level?
All toilet bowls have a preset water level determined buy the design of the internal s-trap and can not be change. However if the water level in the tank is not as high as it should be this will affect the water put into the bowel as the bowel in refilled by the flush valve and if it is set to stop before it get filled to the proper setting the bowl water level may be low.
A quick test is to see if the water level in the tank is up to the line in the tank most all toilet tanks have a line either stenciled or marked with a indentation in the porcelain. Another way is to mark the level in the bowel with tape or a marker then pour water slowly into the bowel not fast enough to flush it wait to see if it stays higher then the mark you made or settles back to that level.
Feb 04, 2011 | Duravit 111335001 Geberit In Wall Carrier...
After flushing, water level in bowl fills and then slowly drops.
Check to be sure small tube is flowing inside the ovefow tube. This is the water that flushes the rim holes, and refills the bowl. If you don't have flow clean or replace the float valve.
Jul 19, 2010 | American Standard Cadet 3 FloWise...
Low water level in bowl after flushing
The small black tube that goes into the overflow is used to fill the bowl after flushing. Would check to make sure that water is coming out of that tube at full force or if its coming out at all.
May 11, 2010 | Eljer & Elongated Toilet Bowl
Can't adjust flush time for complete flush, low bowl water level
flush time depends on how much water is in it,
the water level flote has an adjuster on it, but i cant rember were it is,,, sorry
Oct 24, 2009 | Kohler K-11470-0 White Wellworth Complete...
Cadet 3 round bowl toilet not flushing all from bowl
You are probably correct, the water level needs to be raised. There are many different toilet tank systems, but all have some way to control the water level in the tank. Let me know if you need help figuring it out...
P.S. You'll have to take the lid off the tank, first...pardon me if that is too obvious
May 08, 2009 | American Standard Cadet 3 Right Height...
Raising water level in the toilet bowl. Crane toilet. Don't see where any adjustments can be made. Water level in reservoir tank is up to the inlet tube. How do i get the water level in the bowl to be...
The water level in the bowl is limited by the height of the internal trap down stream from the bowl. There is no adjustment possible. If the problem is odors, you can either flush more often, turn on the exhaust fan, or buy a different brand or model of toilet.
Feb 28, 2009 | Crane Plumbing 3755 Toilet-To-Go Metro...
Toto UltraMax One Piece Toilet, 1.6 GPF - CST854S-11 - Colonial White Logo
162 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
