Question about HP Photosmart M425 Digital Camera
How do I replace my usb port on my camera? - HP Photosmart M425 Digital Camera
    Sergeant:
    Champion:
  • 304 Answers
May i know the model of the camera.?also please be more specific on your problem input more info.
Posted on Apr 13, 2009
Why won't my PC download my pictures from my camera?
A number of things may prohibiting your camera from downloading the pictures to your computer. Here are a few suggestions that should point you in the right direction:
  1. Ensure that all cables are properly secured from the computer to the camera.
  2. Ensure that the memory card has not been dislodged from the camera.
  3. Check the camera's memory socket and the memory card for debris. A can of 'compressed air' can work wonders (typically available at any computer store).
  4. Make certain that the port connecting the camera to the computer is not damaged. Look for any bent pins in the camera's memory slot. Try replacing the camera cable. If the camera uses a USB port, try another USB port. If you don't have another USB port available, try plugging in another USB device to verify that the USB port is working.
  5. Check the power source on the camera. If you're using batteries while attempting to transfer the pictures to the PC, try changing your batteries, recharge the batteries, or use an A/C adapter.
  6. Try reinstalling the digital camera software on your computer. In most cases, reinstalling over top of the existing software will resolve this issue.
  7. Take the media out of the digital camera and attempt to download it to another computer. If all else fails, try formatting the camera media. Most newer-generation digital cameras equipped with an LCD screen have a menu option that can format your media.
May 25, 2015 | Sony Cyber-shot Dsc-w560 14.1 Mp Digital...
USB cable does not plug into camera port.
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER
If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Apr 20, 2013 | Nikon COOLPIX P90 Digital Camera
My camera will not connect to my computer through my usb cable
the cause why your camera doesn't recognized by the pc, first if the usb cable is not compatible or if it was defective tried to replaced it. then secondly if your camera not plug and play which need the installer cd of the camera.lastly if the usb port of the pc doesn't work tried with other usb port or you can plug with other device just to ensure if the usb port of the pc is working good luck.
Dec 09, 2012 | Samsung St65 14.2mp Digital Still Camera...
"micro" usb port needs to be replaced
Consider NOT using the USB port.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Dec 31, 2010 | Nikon DSLR D90 Digital Camera
Bad USB Port in Camera
With that amount of non-accidental damage, a replacement is the best option financially
Mar 05, 2017 | HP E427 Digital Camera
I think you CAN--there's a lovely site with specific instructions,,,, Do It Yourself Camera Repair --- for fabulous step by step instructions WITH pictures & simple explanations that a novice can follow!!!
In short, all you need to do is find another USB port (even from a broken camera or other device) to replace yours. It seems that you'll need to solder it in -? - that's the step I'm trying to research right now--I'd like to just glue mine back in because I don't know how to solder--- but the tricky part is getting the camera apart, not touching the flash capacitator nor any of it's power-holding chips, and not damaging any of the other components.
(ACF0EB8F)
Aug 18, 2008 | Kodak EasyShare DX7440 Digital Camera
Where is port to connect USB cable?
I'm sorry you're having trouble with this. I have put together a picture that shows where the mini-USB plug is supposed to be attached to the camera. I hope it helps. This picture actually shows plugging the AV cable into the receptical, but right behind it is the mini-USB port. This is where you connect the USB cable. It looks like you have to lift the flap on the corner to reveal the plugs.
Nov 24, 2007 | Canon PowerShot SD1000 Digital Camera
Problem with Canon 800 IS
Is this the board the covers the USB port on the camera? I know the eBay store darntoothysam has a lot of camera parts, try checking his store out, or emailing him and see if he has a replacement.
Nov 12, 2007 | Canon PowerShot SD700 IS Digital ELPH /...
USB port with the PDC 640 camera?
The Polaroid PDC 640 digital camera connects to an available 9-pin serial port only -- it does not support the use of a USB/serial converter. However, you can use a SmartMedia Card Reader with the camera's reremovable memory to download the images via the USB port to your computer.
Sep 21, 2005 | Polaroid PhotoMax PDC 640 Digital Camera
No usb port found
If you can't find such on your machine, then it's either disabled, the BIOS is out of date, the OS doesn't support your USB (Examples abound!) or other. I cut my time loss by adding an USB PCI card.
Sep 06, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
HP Photosmart M425 Digital Camera Logo
26 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
