Samsung window air conditioner
We've had this unit for several years without a single proble and now, suddenly, it only blows warm air. I figure it needs Freon but have no idea how to do that and can't get any appliance repair person to even take a look at it.
  • vmaiocco Sep 24, 2007
    The Unit is only a few years old. I haven't checked (not a plumber or an electrician) but I'm fairly sure it's the newer gas style unit, just because of its age. I appreciate all your info but I really just want to get someone to check it out. Samsung's Help Desk is useless. They sent requests to two contractors in their active files: one doesn't work on window units and the other one never even got in touch with me. Anyway, thanx again.
  • Anonymous Mar 14, 2009
    Just blowing warm air.
How do i recharge a window unit
Posted on Jun 30, 2010
Shad roof leaked water on my unit The window air condisner will not work there was water in the plug in and I am not sure if the water is in the front section of condition Please help with this problem would changing the plug be the answer I am looking for?
sconnie454@peoplepc.com
Posted on Jul 03, 2008
  • 363 Answers
Freon or R13 is no longer allowed to be used in air conditioners because it attacks the ozone layer when it escapes. There are heavy fines for intentional release into the atmosphere. If an engineer was to replace the gas with a legal refrigerant then he would want to collect and flush any remaining gas for safe disposal and change the rubber seals in the pump etc. Apparently the new gas will attack the old type seals. I was going to get the aircon recharged in my Mazda RX7 but it would have cost about £300 because it had the old gas but then we had a rubbish summer so I didn't bother. It all seems like a money making excercise especially considering the huge amounts released before 'Green Fever' swept the world. There is however a 'drop in replacement gas' which is compatible with the old seals and remaining nasty gas. It usually contains a leak stopper and flourescent dye to help find where any leaks remain. Try typing DROP IN REPLACEMENT FOR R12 REFRIGERANT in a search engine or a popular internet auction site. You can then recharge your own aircon for a fraction of the price after a bit of study. Good luck.
Posted on Sep 22, 2007
  • Martin B
    Martin B Sep 23, 2007
    Ok so the rating for my solution is 'almost there'
    I am assuming that all you need is a recharge of Freon like you said.
    I'll try a little harder.
    You should be able to find two valves on the refrigerant pipework that look like car tyre valves (in fact they are the same size and are called Schraeder valves)
    If these are not like car tyre valves but more like a bayonet fitting then you have the current legitimate gas and you can ignore the following.
    Remove the dust caps and place a tyre pressure gauge on one of them as you would a car tyre. the gauge might go off scale or read 60 psi or nothing.
    You can be sure that if the reading is nothing then you have a really bad leak in the AC. This should make you think about scrapping the AC.
    If there is still a bit of pressure there then the leak is minor and a recharge may last a season or a few years. Just as important
    no moisture will have ingressed into the pipework.
    Now if you make subtle enquiries around small garages in person, you may find there are mechanics and owners that cant wait to get rid of their black market stockpile of R13 and will gladly regass your home AC for beer money.
    Eventually you will need to get a new AC or have the conversion.
    Hopefully the solution is apparent now?
I have a Crosley 220 volt 18,500 btu window unit air conditioner with a heat pump. The cool air works fine when set on cold, but when set on heat, it doesn't blow warm air. What should I check first?
18000 BTU Air Conditioner ' The Air Conditioner Guide
www.theairconditionerguide.com > BTUs
An 18000 BTU air conditioner is your best bet if you are looking to cool a room ... 2) Frigidaire 18,500 BTU Window-Mounted Median Air Conditioner with ...Troubleshooting Guide. Lost your Everstar air conditioner manual? Fix it tips are here!
Nov 26, 2015 | Crosley CAHE18ER Air Conditioner
The unit is several years old and throws out warm air. I shut it off for a few days and when I started it back up the air continues to blow warm. I also cleaned the filter and drained it. Where can I get...
The best way to find a repair center area you is to call Delonghi Customer Service 800-322-3848. Ironically, their USA operation is also located in NJ.
Hope this helped you and thanks for choosing FixYa.
Aug 22, 2011 | DeLonghi PACA110 Portable Air Conditioner
I've been running my portable ac unit for the past 3 years and now the unit just blows warm air...
If the compressor is running check the thermostat, check the possibility that the gas is present and has not leaked out.
If so the pumping must be checked of the compressor , the pressure switch also must be checked.
Jun 29, 2011 | Amcor PLM-14000E Portable Air Conditioner
Goodman air conditioner is sometimes blowing out warm air. We've had this unit for 2 and 1/2 years. When we first moved in we had a problem with it not blowing out warm air in the winter. We had someone...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Aug 30, 2010 | Heating & Cooling
Warm air
could be several things...if all is working/blowing and its clean inside & outside with a clean filter then more then likely it's low on gas/freon......if you continoue to run it it'll pobly ice up/freeze......also make sure you hear the compressor running as well as the fan blowing. sometimes this can be tough listen for that deep rumble/humming sound thats the compressor.
Jul 08, 2010 | Frigidaire FAC126P1 wall/window Air...
How do i figure out why it's blowing cool but not cold
It sounds like the compressor is not coming on. It may be the thermostat. Take the metal wire with the fat end, make sure not to kink the wire, this is the sensing bulb Warm it in your hand. If you hear a click it works and you need a new window unit. They cost as much to get fixed as a new one. If the thermostat does not click then that is the problem.
Apr 19, 2010 | Fedders AEQ07FBG Air Conditioner
Can you please give me 5 problems and 5 solutions on condenser for a samsung air conditioner
Most of the problems that arise with a window A.C. unit are from the "front", and "rear" coils ,or the filter at front are dirty. When the unit is on,the air is sucked in at both coils,and should be cleaned yearly. The front coil,and the filter are easy to clean,but the rear coil can be difficult.After checking the front, with the on cool, go outside and put your hand at the rear coil and feel if there is warm air blowing out.If not, your rear coil is probably clogged.Note:Do Not use high pressure hose to clean the coils,please.
Feb 17, 2010 | Samsung AW0603B Air Conditioner
Window air cond unit, several years old, doesn't blow as cold
The problem with window units and any service tech will tell you it cost more to repair than you can buy at Walmart or home depot. Unless you know someone who can charge it for you. Window units are a sore subject. A 200 dollar window unit might cost 200 dollars to charge system. SORRy rusty
Jun 13, 2009 | Maytag M6X06F2A Air Conditioner
Will not cool properly.
You have either a faulty thermostat, dirty condenser and evaporator or a faulty run capacitor. Need to service soon before the compressor is damaged. Sea Breeze
Jul 31, 2008 | Kenmore 75101 Wall/Window Air Conditioner
Heating & Cooling Logo
1,273 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
