Question about Tascam 2488mkii 24 Track Recording Workstation
How can I get reverb when I sing? Martin - Tascam 2488mkii 24 Track Recording Workstation
    Problem Solver:
UNDER THE LIT UP SCREEN, ABOUT 3 INCHES DIAGONALLY TO THE RIGHT, YOU WILL SEE FOUR DIFFERENT SMALL BUTTONS- FIRST BUTTON IS FOR (E.Q), THE 2ND BUTTON IS FOR (SEND). PUSH THE SEND BUTTON!!! THEN YOU WILL SEE A SCREEN THAT SAYS "EFFECT SEND", AT THE TOP WHERE IT SAYS LOOP POSITION LEVEL.. TURN YOUR KNOB UNTIL YOU HEAR THE REVERB SOUND..(THE BIG KNOB)
Posted on May 21, 2009
Marshall GU15 r cd park series reverb has no sound
To many possibilities. The reverb unit or the reverb preamp or the reverb output amp.
Jan 31, 2018 | Marshall Music
I'm having a bit of a problem with my RSQ NK-2000U. The voice is lagging when singing. In other words, I say something like, "Testing" and I hear it about half a second to a second afterwards. ...
The Karoke is usually se with a reverb that could make it sound that way. Check the vocal settings in the machine for correcting that and time delay setting.
Dec 25, 2014 | RSQ Neo Nk-2000 Dvd Karaoke Player Nk...
No reverb on my fender ps 160 Vocal amplifier
Here is a link to the schematic drawing
http://www.prowessamplifiers.com/schematics/fender/ps160.pdf
items to check are
1-the footswitch and plug
2-the reverb unit ,usually found at the bottom of the box
3-the reverb unit is plugged in to the amp
4-V6 a 7025 valve
5- the reverb switch is in the on position
Hope this helps
Len
Oct 14, 2014 | Music
Is there any way to use a heil talkbox with a fender '65 deluxe reverb reissue?
No - you use these with a microphone. Plug you guitar into the Heil, put the tube in your moth and sing into a mic while playing. You CAN plug the microphone into the fender amp, but a PA system is better
Oct 15, 2013 | Dunlop Ht1 Heil Talk Box
How to connect a vocal processor to a peavey6 mixer
Set the voice input level on the voicelive2 by following this guide from the live 2 manual... Step 4: Set Mic Level This step informs VoiceLive 2 how loud you plan to sing with your particular mic. We'll use VoiceLive 2's automatic MIC GAIN feature to quickly set the optimum level. 1. Press and hold the REVERB footswitch 2. If you need to activate phantom power for your condenser mic, adjust the onscreen PHANTOM parameter which will restart the level test 2. Sing for five seconds with peaks that are as loud as you plan to sing 3. Follow the prompts in the display to finalize mic level setting, cancel or redo the procedure During performance, if you see the CLIP indicator light in the HOME screen, you can return to the automatic
MIC GAIN feature to adjust the input level.
When input level is set on the voice live ;
on the mixer set
the gain control to 12 o'clock position and
individual channel volume level to 7 ....raise the master volume
slider to hear mic input at desired level and without feedback
Jan 15, 2012 | Peavey PV6 Mixer
I have a mackie cfx12 mixer with mackie powered speakers.At a gig tonight i set up as usual and had strange highly amplified sounds coming thru speakers from microphone when reverb was on-the effects had...
Make sure you are using BALANCED interconnection cables to the speakers, either XLR or TRS connections. ALSO make sure all interconnected equipment such as the speakers AND the mixer are powered from the SAME receptacle at the venue... yes you have to run extension cords... the pro's do it so they don't have hum and other noise and don't damage their equipment.
Aug 14, 2011 | Innovative Concepts Corporation Odyssey...
Long delay between singing into mic and hearing voice in speakers
Usually delay is associated with "reverb" not echo. If you are in a large room, the room acoustics can add reverb without the benefit of signal processing.
Reverb NORMALLY passes the inout signal as is and then adds in a delayed version on top.
The delay should be less than the room size delay.
Try turning off all effects as a start. There is some "transport" time if it goes through a digital signal processing.
Apr 30, 2010 | Vocopro Da1000pro Professional Digital...
Hot Rod Deville, reverb squeal...
Here is an article that might help:http://www.guitarplayer.com/article/reverb-troubleshooting/jun-09/97165 Here is the schematic:http://www.fender.com/support/amp_schematics/pdfs/Hot_Rod_DeVille_Schematic.pdf Check to see if someone hasn't reversed the input and output cables at the reverb tank. Then troubleshoot the reverb section .
Aug 28, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Crate gt 30 amp reverb wire loose. whrer does it connect?
If its the input reverb tank wire or output reverb tank wire just reconnect it (if the amp has a reverb tank).
Feb 27, 2009 | Crate Music
Tascam 2488mkii 24 Track Recording Workstation Logo
100 people viewed this question
Top Tascam Music Experts
Michial Gueffroy
Computer Links
drivealot
Are you a Tascam Music Expert? Answer questions, earn points and help others
