Question about Maytag MSD2756G Side by Side Refrigerator
Maytag side by side MSD2735GR
My ice maker won't make crushed ice. Everything else works fine. What might the problem be?
Well sometimes it clogs up , when i open the frig door sometimes the ice falls out since the actual cup in inside of frig is full of the crushed ice.
Posted on Feb 04, 2008
Maytag refrigerator model number MSD2735GR - Leaks from freezer. Ice build up around condensation drain hole. I have unthawed twice and unclogged ice from the condenate line. Keep having same problem.
I suggest you empty the freezer. Then use a hair dryer to copletely dry the entire inside of the freezer then make sure everything you put back in is dry. I had this same problem and this worked for me. Just had to much humidity in freezer.
Jan 01, 2012 | Maytag MSD2732GR Side by Side Refrigerator
Ice maker
check to see if you ice bin has full size ice cube in it... if there is then you dispense is stuck in the crush mode check to see if there is something keep the crushing wheels from releasing... other than that it could be the control on the door..hope this helps
Aug 26, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
Our side by side electrolux refrigerator will not disperse cubed ice, only crushed. everything else works fine. Model number PRLS267ZAB8
Pull the ice drawer out and look for the small, metal "arm" that sticks out of the back of the outside of the drawer. Empty all the ice out and make sure this arm swivels freely. Sometimes it can get stuck.
Aug 29, 2010 | Electrolux Icon Professional Ice Maker...
Ice maker on maytag side by side fridge will only make and dispense crushed ice no cubes.
Might be too many ice cubes in the bin. Try dumping it.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 12, 2010 | Maytag Refrigerators
Frigidaire ice maker always crushes the ice
Solenoid that switches blades from crushed to cubes is most likely not working and should be replaced
Sep 05, 2017 | Refrigerators
Ice maker dispenses crushed ice in the cube setting. Water and crushed ice are fine.
Typical of a switch failure / control module failure so it sticks on the crushed ice setting or the crushing mechanism is u/s and wont turn off. Call a service engineer asap.
Aug 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
ICE MAKER STOPED WORKING
IS THE METAL ARM IN THE DOWN POSITION?
Mar 30, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker stuck on ''crushed'' ice
i think it's simpler than that. there's a plastic gate that snaps UP for cubed and DOWN for crushed.
When you remove the tray, set it to CRUSHED, BEFORE putting the tray back in place.
Nov 16, 2008 | Frigidaire FRS3R5EMB Side by Side...
Ice maker
There is something called a crusher control rod located on your icemaker bin. If you pull the bin out, you'll see it protruding from the backside of the bin. That rod inserts into the solenoid, which looks like a hole usually when looking in the freezer with the ice bin removed, it's toward the left side behind the bin.
This solenoid and rod work together to give you either crushed or cubed ice. See if the solenoid is stuck or iced up. You should be able to remove the ice and push it up and down to break it free.
Mar 26, 2008 | Maytag MSD2454G Side by Side Refrigerator
Maytag MSD2756G Side by Side Refrigerator Logo
613 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
