Question about Casio Parts Cash Register PC Desktop
Error 04 i try all solution with the key and i have FFFFFFFFFF, but the machin always make E04. Do you think i must change the battery ? and how can i change the battery ?
  • 737 Answers
Hi.
If you press SUBTOTAL when you have FFFFFFFFFF on the display, the machine should print out a receipt. Tell me what is written on the receipt.
Mark
Posted on Apr 13, 2009
What is error code E04 on hoover washer
E:04" on the washing machine. Check to ensure there is no water in the tub. This is a common error often associated with too many suds blocking the pump. It is caused by using the wrong laundry detergent which is not designed for high-efficiency washers. You can adjust your use of detergent and reset the machine to eliminate the error code.
Read more : http://www.ehow.com/how_10038363_reset-bosch-washing-machine-error-e04.html How to Reset Bosch Washing Machine With Error 04 eHow
Jun 21, 2015 | Hoover Washing Machines
What does fault code e04 mean
There are many brands of washers and the error codes are different.
What kind of washer do you have. Brand name and model number.
Open door and look around the frame for the model number.
Here is a link to e04 on a Bosch washer.
Repairing 04 Error on Bosch Washer
Sep 10, 2014 | Washing Machines
Panasonic DP-8035 Copier. Machine Error E04-02
Yep, you need to go into the service mode to reset this code. To enter the service mode press and hold the FUNCTION, ORIGINAL SIZE (LEDGER/A3), and 3 keys and F1 should appear on the screen. Go to F9 by pressing 9 on the keypad, press the down arrow key once on the touch screen, press 06 RAM Initialize on the screen, and choose 04 LBP Fuser Reset. This will clear the code.
Jan 28, 2011 | Office Equipment & Supplies
Hi. I have a Casio CE-3700 that is only used for a few weeks of the year. Once I month I try to turn on the machine and leave it powered up for around a day. I am now wanting to actually use the machine....
It sounds like the machine has lost some programming. What you were doing once per month is what I recommend if not used regularly, but the battery has probably now got to the stage where it is too old to even hold charge for a month. It is probably best to get the battery (internal vanadium type) replaced as it may have started leaking if it is too old. The dealer who replaces it can reset your decimal places at the same time. If you just want to get it running as is and take a chance, then do the flag clear (to get the FFFFFFFFFF on display then SUBTOTAL) on one of your WORKING machines, and tell me the big number that it prints out (this will not lose any data on your working machines, it just reads the settings)
Jul 26, 2010 | Casio Parts Cash Register PC Desktop
Casio tk-1200 stuck on error E-04
Firstly, try a flag clear. This will not lose any of your data:
Turn key to PROGRAM mode. Turn power off at wall. Hold RECEIPT FEED down - keep your finger on it. Turn power on at wall. Wait 5 seconds, then let go of RECEIPT FEED. You should see "FFFFFFFFFF" on display. Press SUBTOTAL.
Turn key back to REG mode and try it
Nov 30, 2009 | Casio Parts Cash Register PC Desktop
I'm getting an E04 ( error) when I try to record or play
Here is some information regarding the E04 error message from http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/:
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
This doesn't seem uncommon, and indicates a bad tape is loaded, or unfortunately, that the camcorder requires servicing.
May 22, 2009 | JVC GR-DVM50 Camcorder
Casio CE-3700 cash register MAC instructions
Hi. I would advise both of you to try a flag clear first to see if you have any program left.
Turn key to program. Power off at wall.
Hold RECEIPT FEED, and turn power on at wall.
Wait 10 seconds, then let go of RECEIPT FEED.
When you see 'FFFFFFFFF' press SUBTOTAL.
Turn key back to REG and try it.
If you still need help, let me know.
Mark
Apr 15, 2008 | Casio Parts Cash Register PC Desktop
Casio Parts Cash Register PC Desktop Logo
81 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
jackcity
jackcity
Level 1 Expert
tomferryman
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
