Question about Canon PIXMA iP3000 InkJet Photo Printer
Switch printer on,just get grinding noise on right hand
Error code 6aoo & 5700 appear
    President:
  • 2,306 Answers
The grinding noise is from the purge unit not turning properly, sometimes paper scraps caught inside but usually needs a new purge unit installed. Resetting the ink absorber counts won't solve anything on this problem...
Posted on Feb 08, 2010
  • 4,041 Answers
Try
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
C350 grinding noise does not power up
Open the right door and remove the fusing unit and turn ON the copier.If the copier turn ON and the error code displayed the problem in the fuser drive transmission mechanism(gears),if not working remove the rear cover and verify the main suplly unit and the main motor.
Mar 20, 2013 | Konica Minolta bizhub Office Equipment &...
Error 5700 impresora MX700
"Printer died after 1 1/2 years, error code 5700." on May 1, 2009 by danmc7777 (2 reviews)
Pros: This is a pretty decent product as far as ink jets go.
Nice to be able to use the feeder to scan multi-page documents and even cover two sides by running two passes and then the software interleaves the pages to make a seamless pdf file.
Cons: Ink jet technology. It worked very nicely for a year and then a few jets plugged up and wouldn't clear out even with cleaning.
Today the unit is dead, reporting error code 5700 and refusing to do anything after a paper jam.
Cartridges with chips.
Summary: I was pretty happy with this printer until one day it decided to grab about 30 sheets of paper at one time from the top feeder. This created a pretty major jam, and it reported the error code 5700. This jam must have stripped something in the gearing since now all it will do is report this error even after power cycling. Web search reveals that this is a serious fault that requires it to be sent in for repair. Yea, right. This unit is designed to be never disassembled since everything snaps together and opening it up is a major puzzle.
This is only reader review which i found in the web. this may tell you what is the error is all about..
Nov 10, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Canon MP830 Error Code 6AOO
The error seems to indicate a failed sheet feed, check the paper path to see for any stuck bits of paper, however I have heard that this can also be caused by a flaky sensor in the paper path.....
apparently the best way to deal with this is to turn it upside down and give it a shake.
hope this helps
Jul 21, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Error code 5700
5700 is a ASF cam error most likely. Here the Canon proceedure for fixing it!
DESCRIPTION: 5 Alternating Blinks (SFP) / ##356 (MFP) - ASF Cam Sensor Error
SOLUTION(S): Adjust the Screws & Main Case Unit
Movement (i.e. from shipping) may cause the plastic guide to move away from the chassis. When this
occurs, the gears cannot rotate properly causing a grinding noise and 5 alternating blinks (SFP) or ##356
(MFP) - ASF Cam Sensor Error.
Procedures
  1. Remove the Left and Right Covers and the Main Case Unit (main cover).
  2. Remove the 4 mounting screws from the Chassis.
  3. Remove the Main Unit from the Bottom Case.
  4. Turn the Main Unit over (upside down) and place on work surface.
  5. Inspect the ASF section of the Main Unit for a gap between the white plastic guide and the Chassis.
    Note: The size of the gap varies. Even if the gap is not visible, complete the steps
    below.
  6. Disconnect the appropriate cables and remove the Logic Board from the Chassis.
  7. Loosen (do not remove) the 4 mounting screws (the mounting screws can be found behind the
    logic board) on the Chassis.
  8. Re-seat the white plastic guide so it sits flush against the Chassis. The tip of the white plastic
    guide should sit slightly inside the
    mounting screw hole. When seated correctly, the gap will no longer be present.
  9. Tighten the 4 mounting screws without
    causing the plastic guide to shift.
  10. Reassemble the printer and retest.
Sep 25, 2009 | Canon Pixma iP4500 InkJet Printer
Cannon pixma ip 4600 error code 5700 - paper jam
The error code 5700 is the sensor error.Replace the sheet
feed unit and then adjust the timing of the paper feed gears.
Sep 02, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Error 6aoo can't clear it
Take off the side and top covers off to reveal the print head. There is a device that slides back and forth and acts like a window cleaners squeegie on the printhead. This mechanism might be stuck at its full extention rather than being back at its starting position. Turn on the printer and make sure that it moves if it doesn't push it a little bit not to hard. It may have been blocked from dry ink. Do not force any part of the covers. There are little arrows in the plastic indicating where the snap locks are, stick a flat head screw driver in to release. Trial and error will release the right ones first. Some are hidden under or on opening covers so keep looking. Use damp rag to clean. If you have no experience with this type of thing I would suggest going to a canon repair shop.
May 02, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Hp all-in-one printer, makes a grinding noise when turn on
My 928 printer makes a loud grinding noise when the ink moves accross to the right hand side, also the red coulor is not coming out onto the paper the cartrige is new
Jul 03, 2008 | Office Equipment & Supplies
Error code 6A00
TThere is a prblem with the carriage lift mechanism.
Probale causes
1.PR Lift shaft assembly
2.Sheet Feed Unit
3.Logic Board
Send the printer for repair ,
Apr 21, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Error code 5100 on my Pixma iP6600D.
I had the exact problem described and it was the following:
one of the ink cartidges had popped out of place "inside" the printer housing on the right hand side, and was catching as the printer tried to start up.
By using a thin object such as a ruler, I could press the ink cartridge back into place to allow the ink cartidges to come out from the printer side area. Once out I properly reseated the ink and all seems fine.
Apr 08, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
428 people viewed this question
old marine
old marine
