Question about HP Pavilion dv2120us Notebook
Power cord When I plug the power cord into the laptop it will not provide power unless I wiggle it around and get it in a certain spot. Then if I move it will loosen and stop powering again. Any solutions? Thanks.
  • evieg Sep 12, 2007
    No I don't know how but I am willing to try it
  • 3 Answers
Happened to me, I just bought A new cord
Posted on Dec 27, 2008
    Sergeant:
  • 457 Answers
Replace the socket I imagine you are talking of the one in the laptop.....its faulty needs to be replced. Do you know how to replace it?
Posted on Sep 11, 2007
  • Anonymous Sep 12, 2007
    You can repair it yourself but you need a soldering iron. You have to open the back up the offending socket sits on the motherboard. It may only need a re-solder you must be very careful not to join the connection wires the centre one which Im certain is the broken one.. if you can do that your problem is over TRUE. Go slow after all you have all the time in the world if you pull this one off safely you'll pat yourself on the back...and thank me. If you dont Ill be forever in your bad books for encouraging you to repairing it your self....hey good-luck
6ya staff
SOURCE:
I had to replace a old cable it had a short.! Got a new one nothing happen.!it not charging period.!
Please tell us the make and model number so we can help. Normally a charger does not have a replaceable cable to the laptop - only the AC cord to the power plug can be replaced. I've purchased replacement adapters and the AC power cord doesn't work correctly in the adapter unless I push it in very hard or wiggle it to make a connection. Some replacement adapter also have a plug to the laptop that is not sized like the original and also needs to be wiggled to make a connection. Please provide the information if you still are having problems.
Oct 06, 2014 | Computers & Internet
HP Pavillion dv6700 - won't power up
Hello.The most common reasons for power issues are the battery, power jack and power adapter/cord.Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.If you move/wiggle the hp pavilion dv6700 power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.If no change, the power adapter is probably faulty and needs replacement.Hope this helps.
Feb 16, 2013 | HP Pavilion Computers & Internet
Advent N270 netbook will not charge. Orange light comes on initially then goes off. Also when I wiggle the plug into the laptop the light flashes on and intermittently.
It sounds like either a bad connection on the motherboard or a broken wire in the adapter making intermittent connection.
1. With the power adapter disconnected, do you have a power light? This would indicate the adapter is good and the plug is questionable.
2. Check your power adapter output with a multi-meter.(be sure to wiggle the wires around) If the power fluctuates, replace the plug.
3. If the power is solid, replace the motherboard connector.
Nov 22, 2010 | Intel Computers & Internet
No connection with the DC Jack on Gateway 3550GZ
It's time to take the computer to a qualified technician, for proper trouble-shooting & repair, because there are very-few "user-repairable" parts inside a laptop/notebook computer.
Jan 20, 2010 | Gateway 3550GZ Notebook
Won't charge sometimes
I have that exact same model Laptop.
By the sound of your problem I am guessing that the socket for the charger could be worn and not making contact.
Try www.acer.com and ask them just to make sure.
Jan 15, 2010 | Acer Aspire 3680 Laptop
I get no dial tone unless I wiggle the handset cord at the handset. The speakerphone works as long as I do not move the handset cord.
Try replacing the telephone cord between your handset and phone base cradle or swap the plugs around between your handset and base.
Dec 24, 2009 | Innovage LCD Touch Panel Phone
My power cord is loose. It plugs in and charges,
Hello !
If I'm understanding you correctly, the wiggle is from the laptop. Sounds like a problem is about to happen. Your Presario has a loose power jack (connector inside the laptop). It is a part that can be replaced.
If you need further info, let us know.
Hope this helps.
Oct 23, 2009 | Compaq Presario CQ60-220US PC Laptop
Won't charge
The plug in terminal that is soldered to a board inside the laptop has a loose solder connection. This procedure require opening the laptop and some soldering iron, and some solder. If you are not confident in doing this don't try it cuz you can mess up your laptop forever.
Aug 15, 2009 | Compaq (480082-001)...
Inspiron E1505 - ac power not always on when plugged in outlet
I've had both the battery and the cord die in my old Dell laptop. Assuming it's like mine and the light is on while the battery's charging and turns off when the it's full....
Dell batteries don't last more than a year or two, so my first question would be how old is the battery you are currently using? When a battery is dying, it essentially isn't able to use its full capacity. So in addition to lasting less than an hour or so, it will try to charge for 6-12 hours trying to get a full charge even though it can't. So the light will stay on until it gives up. It will start charging again if you unplug it and plug it in again. If this is the case, you can either replace the battery ($100+ bucks) or ignore it and don't use the battery.
If the power cord is going, it will only work at certain angles. Play around with wiggling and bending the cord (not TOO far though!!) to see if you can get the battery light to shut off when you move the cord in a certain direction. A new power cord/adapter will cost you around $50 I think, if that's the problem. Let me know if your problem doesn't seem like either of these.
Hope this helps and best of luck!
Jun 18, 2009 | Dell Inspiron E1505 Notebook
Screen blackout when using AC cord
I think you're goin to have to replace your" dc-jack" as it's called. This is where your AC cord plugs into your laptop.DC-jack problems are very common in laptops.Over time they wiggle loose just enough to mess up the solder connection on the motherboard.Try gently wiggling your AC cord where it plugs into your computer ,if you screen returns to normal when you wiggle the plug a certain way,then you've most likely got a bad dc-jack.
Feb 12, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
42 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
