Question about Dryers
My amana dryer, model# LEM447W, will not spin. set timer, push to start and all i get was a ginding noise then dryer cuts off.
    President:
  • 1,902 Answers
Check the bottom of the until and make sure that your bearings are working properly and that they are not stuck. This could also be a brake issue holding the tumbler from working correctly remove the back panel and look for any damage and wear on the machine
Posted on Apr 13, 2009
What could possibly the reason my amana dryer wont tumble and just buzzes when you push the start button
Could be a broken belt spin the tumbler by hand it if it spins real easy the belt is off or broke another thing to try if you have resistance when turning the drum have a helper for this one open the door and hold the door switch in set timer to a cycle and press start while holding switch and buzzing spin drum and see if it will continue to rotate while holding switch if so motor going bad
Feb 17, 2015 | Amana Dryers
Dryer has power to timer, but won't start...I have an Amana electric dryer that allows me to set the timer and I can hear it running, but when I push in the the timer knob to start the dryer (drum
The fuse is mounted on the heater element. When it blows nothing in the heater or motor circuit works but the power to the timer is not interrupted therefore you can hear. Service manual
Feb 11, 2013 | Amana Dryers
Hello, I have Amana LG4309W heavy duty gas dryer.
sounds like one of the supply fuses at the house panel,these 240 volt dryers are wired so the timer is on one phase(120)volt and the motor is on the opposite phase(120)volt and the heating element is on both phases for a combined 240 volts,if you lose one phase you either wont get motor operation or timer operation,and for sure no heat and you have the timer so you have 120volts
Jan 08, 2011 | Amana Dryers
Timer making noise, but not moving
If timer motor is in operation but the dial not forwarding, yes the timer is faulty. plastic gears in the timer eventually ware..
Jun 09, 2010 | Amana LEA11 Dryer
I have an Amana model NDG7800AW. A few weeks ago
The roller to the belt tensioner is binding causing to make the warbling noise.The bearing needs to be replaced which comes with the roller. A new belt is advisable as well when replacing. The stalling problem could be also from the belt being stretched or the timer relay is weak
May 01, 2010 | Amana NDG7800AW Gas Dryer
My 1987 GE Dryer, Model # DDE5300GALWH,will not run all the time.
sounds like you need a new timer you can actually take the timer apart to check for a burnt connection
Jan 07, 2010 | GE Dryers
When I push the timer button to start the dryer it just buzzes.
verify connections on motor. sounds like the start relay has gone out on the motor. if it was your push to start button it wouldn't make any noise.
Jun 24, 2009 | Amana LEA11 Dryer
Dryer won't run. Stops after 30secs
Sounds like the timer is going bad and it needs to be replaced. The time is located behind the knobs.
IF my answer has satisfied you please rate. Thank you
Feb 11, 2009 | Amana ALG331RAW Gas Dryer
Dryers Logo
50 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
