Question about Maytag Neptune MDE5500AY Electric Dryer
Control Board burned up started electrical fire.
  • lola65 Apr 28, 2009
    Had a fire last night.  Burned a hole clear through the cabinet.  Even though it was on a different circuit, it caused the lights in the house to flicker, the TV to power off, and blew a couple of bulbs in the hallway outside the laundry room.  Scary Stuff!
    President:
  • 1,902 Answers
Electrical short. Call Maytag and see if there is a recall of the system first before you do anything else even repairing it to be on the safe side. If there is nothing as in a recall, then let the warranty repair it if you have a waqrranty and get it fixed by a professional to be safe
Posted on Apr 13, 2009
Can't read oven temp on control board.
Hello;
My name is Peter. I am a retire field service appliance technician.
The model numbers you provided are for wall space heaters.
Open the oven door the model number should be on a label on the face of the oven or on the side of the door.
Your control panel has red lights on it. Sometimes they burn out and you can not read the numbers.
Find the model number and go into the following website. Record the control panel part number. Search the web for this part number.
I recently, purchased a remanufactured oven control board for $45.00, when Sears wanted $256.00.
Make sure you ground yourself before you touch the control board, by touching something metal. Static electricity will knock out a control board.
Water Filters Lawn Garden Appliance Parts
Mae sure you turn the power off to your range before you start the work.
Feb 28, 2016 | Kenmore 95012 / 95014 Electric Kitchen...
My oven caused the fuze in my home to blow twice today. It is also emitting a electric burning smell. Any ideas?
Absolutely.
Do not use the oven again unit it has been replaced or repaired, as it may very well start your dwelling on fire.
The fuses are made to stop fires by blowing out.
I sounds like you may have some bare wires inside the oven, or a shorted out control.
Dec 01, 2015 | In Microwave Ovens
Electronic block is burn down
We are a bit unsure of what you mean, so could you explain yourself a bit more?
'Electronic Block'-- is this a connector Block?
or a circuit board?-- or a wire connection?
'is burned down'-- does this mean a fire from the electric wires -- or from an outside fire?
Tell us more-- Is this a top load washing machine?-- Make and type?
Mack B
Jan 15, 2011 | Washing Machines
Does thermal fuse burn out only because of temp.?
Possibly or the thermo fuse just went bad normally if the thermo-fuse blows its a venting problem warm moist air back builds into the dryer which in turn blows the thermo-fuse to save the dryer from further damage and also keeps from starting a fire in your home a big saftey feature that has saved many homes.
Jan 04, 2011 | Maytag HYE3657A Electric Dryer
Zanussi ZDT 6252 dishwasher will not work
Almost certainly the control board has gone faulty. The favorite is the transformer burns or the thyristor gets very hot and burns due to a bad solder joint. Quickest no noncense repair is to bite the bullet and install a new board.
Jun 05, 2010 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Kenmore elite gas dryer won't heat
Presuming that you checked the obvious gas flow. It is most likely 1 of 2 problems. Most likely the electric igniter is burn out or cracked. when the unit is turned on it will glow red hot and then tell the gas valve to start the gas flow and then you have fire. BUT 2) if the roll out limiter switch lies to the machine and tells it 'Hey the fire is out of control! Shut off the gas' it will never open the gas valve to start the fire.
IF the igniter is cracked you may not see it. It simply won't work. If the roll out limiter switch is broken you definitely will not see it broken.
Both problems are common. Neither have a way of testing with a multimeter if they are good.
The third and very, very rare is the control console is broken. I would check to see if the glow igniter is working first.
Mar 17, 2010 | Kenmore 62602 Electric Dryer
OVEN WILL NOT BAKE , IT WILL BROIL
I have the same problem, I took off the back panel and noticed that the EOC (electronic oven control) board is blackened and most likley need to be replaced. My wife was cooking a pizza and she smelled a burning plastic smell, she looked in the oven and saw the pizza on fire and smoke bellowing from the control panel area. So i unplugged the oven and saw the circuit board did start on fire and fortunatly it went out before serious damage. No matter what you set the oven on the display shows it as being correct, but only the top element comes on and it is on HIGH!!!! DO NOT BUY FRIDGIDAIRE!!!!
Dec 22, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Whirlpool 24" built-in GU1200XTLBO dishwasher electrical smell
This may be the smell of Varnish used in motor winding. When we turn on the machine it gets heated a little bit resulting in a burning electrical smell.
Mar 11, 2009 | Whirlpool GU1200XTLS Stainless Steel...
Maytag neptune dryer
This is an electrical problem associated with the control card. These cards are delicate and it does'nt take much too burn them out.
Another item associated with this is the door switch. If it is faulty then the control board will not allow the unit to start.
Dec 31, 2007 | Whirlpool LER5636P Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
137 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
