Question about Garden
I have a snapper rider (hydro), when it's started and u take foot off clutch/brake, it dies, push in clutch again and it catches...could it be the safety switch under the seat? Please help!!!
    President:
  • 1,902 Answers
This does sounds like your safety switch is bad. But you do need to make sure that your clutch it engaging properly also the adjustment could have been changed by vibration also
Posted on Apr 13, 2009
Replace friction wheel Snapper 3317523BVE (7800254) - Snapper 33" Rear-Engine Rider
Warren, Could not find your particular model, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
HowTo Replace Your Disc Drive Friction Disc Wheel
Riding Lawnmower doesn go foward Drive Disc Replacement
snapper clutch repair for beginers friction disc
Snapper Friction Drive Modification
May 13, 2016 | Snapper Garden
I have an LT series Snapper rider with 20 hp and 44" cut. The transmission seems to be slipping. I have not checked the oil. Replacing the belt looks like a big job.
Not as some John Deere mowers I worked on lately.
I am assuming your is the Hydro version with electric pto. First set the parking brake as this remove tension on the belt.
You will need to remove the pto clutch and attention to the keys are positioned as they are one way keys. When reinstalling the PTO clutch it torqued to 55 ft lbs. To do this you need to remove the engine shroud so can block the flywheel movement.
The rest of the belt removal and replacement is fairly straight forward.
May 06, 2015 | Snapper Garden
Why is CLUTCH BRAKE LOCKED and wont release what can I do ?
you should be able be able to loosen it if it wont move being that old hydro pump probably out need to replace and if brake worn out replace that
Sep 06, 2014 | Garden
Why will my Snapper riding mower not go into gear?
If it is a hydro-stat transmission, the bypass lever will have to be re-engaged for it to work.
Aug 23, 2014 | Garden
Snapper rear riding mower won't move while in gear
yes your looking at the problem easy to change close the vent on the fuel cap remove the battery and lift it up and stand it on the rear bumper tubes (thats what there there for) after replacing you might need to move the links for the cable up near the pedal
Jul 11, 2012 | Garden
I own a Snapper riding mower, hydrostat drive, 14.5 Hp, 38 cut. Reverse speed has suddenly been reduced to a crawl. Could it be the brakes need adjusting or is the engine/transmission shot?
could be a linkage came loose, or that the fluid level in trans is low, has nothing to do with engine but the hydros are prone to failure, also the hydro is driven by a vbelt which can stretch and mimic a trans problem
Sep 30, 2009 | Omega Rear Drive Wheel Snapper Mowers
Kawi/nomadf1 1500 clutch will not engage.
hi it is possible that your clutch plates have stuck tgether does the clutch allow you to push your bike in gear if not then a quik strip and clean should sort this out
hope this helps
Dec 04, 2008 | 2000 kawasaki VN 1500 Vulcan Classic...
Garden Logo
271 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
