Question about Whirlpool GHW9300 Duet Washer
What are "F" and "G" codes?
I'm getting intermittent "F" and "G" codes on the electronic panel of my Whirlpool duet front-load washing machine. It WAS acculating water in the drum a few days ago, but stopped. Now, after 20 minutes in the wash cycle, I get these codes.
    President:
  • Whirlpool Master
  • 662 Answers
Http://www.fixya.com/support/t4890606-wont_finish_cycle_f_code
Posted on Jun 01, 2010
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
My whirlpool duet front load washer thre a code 28 and cant get the washer to finish cycle and can not get door open
Bottom front panel comes off is a release lever you can pull to open the door,inside that panel is also where they hide the manual. Sears repair told me the electronic brain box go/s after 2 years
May 25, 2015 | Whirlpool Washing Machines
On Whirlpool duet steam front loading DRYER...What does the error code F70 mean?Do you have to have a certified whirlpool appliance service professional to repair?
F70 code says...
Replace the machine control electronics. You should first unplug the machine and then remove and plug back in all connectors on the front panel model as well as the electronic control module.
If that doesn't take care of the problem then it may be time to consider replacing the rear board. The FSP # 8183259
The control board is part # 14 in the link below.
Sears parts direct /Whirlpool-Parts/Model-WFW9400VE01
Mar 13, 2015 | Whirlpool Washing Machines
My Whirlpool Duet washing machine's front panel lights quit working and now it will not run
Make sure you still have proper voltage at the plug. try plugging something else in. If voltage is good you most likely have a bad electronic control, or user interface board.
Mar 23, 2011 | Whirlpool Duet 3.8 cu. ft. Front Load...
How do i reset front panel on my whirlpool washer front load duet
Hi
Its a simple procedure to reset the Whirlpool Duet front load. Please press and hold the END OF CYCLE button for 15 seconds to reset. Please get back to me if you have any other questions.
Kevin
Nov 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front load washer has standing water inside
take off bottom panel of washer. unscrew front plug to drain pump. clean out
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Sounds like rocks in my front loading washing machine
did you try removingthe lower acess panel and checkin g the drain pump for possible obstruction??
Mar 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
On whirlpool duet ,am getting fault code f21 in wash cycle.
Foreign objects in the prepump
remove access panel in front remove round plastic plug clear objects have towels ready
Jan 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Drain
kathy..theres three screws at the bottom panel...remove them,,always unplug first...and you will see your pump claen your filter,,ok onthejob,,just screw it out
Jan 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
95 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
