Question about Timeslips 2005 (tsw2005rt) for PC
Need a key and a ribbon for a latham time clock
We have had a latham time clock for several years and never have used it. The key has been lost and no one knows where it is. We woudl like to use it now that the company has grown. The ribbon is very light now so I guess the ribbon could or will need replacing soon. Any ideas where to get a replacement key from?? No model number on the clock that we can see either.
  • qcut Apr 14, 2009
    Thanks for the tip. Of course I looked on the top, bottom, front , back and sides for a model number. After talking to a distributer at: EmployeeTimeClocks.Com in Florida they told me that Lathem puts the model number for their manual time clocks inside. Why?? Who knows, I guess to make things interesting. They also sell keys and anything else you should need for time Clocks- ie : cards, racks & ribbon.
  • 718 Answers
The unit may have a model on the front or look on the bottom for a model number.
You can go to eBay and enter 'lathem time lock key' . Then pick a 'key' seller and contact for a key.
Posted on Apr 13, 2009
  • marionbagget Apr 14, 2009
    The only other solution is to compare your unit to online pictures sellers have. The key should match also.
How can I get my Model 7-4880A radio to work? The keypad doesn't respond. The clock has not been used for several years, and I don't have the instructions any longer.
These keyboard contacts deteriorate over time. Keep in mind this clock radio is over 30 years old. I have surgically fixed these by cutting small 1/8" x 3/4" strips of aluminum foil. You'll need one for each key that does not work. take a picture of the keys so you'll know where they go. Then take apart the radio remove the keyboard assembly from the base (leaving the keys behind) and place one of those aluminum strips under and around (wrap) each contact point. This will buy you another few years but it will have to be repeated as the foil will wear out over time.
Dec 27, 2014 | Audio Players & Recorders
How do I reset my date & time for Panasonic kxtga470
The KX-TGA470 handset works with several models of Panasonic cordless phone base units. Press Menu and then press #. Next press 1 0 1 . (Alternatively use the arrow keys to navigate to find Initial Settings and then Set date and time after pressing Menu.) If you need to change the date, type in the date as three sets of two digit numbers (month, day and year). Then press OK. Next type in the time. Press OK and then select AM/PM with the arrow keys if you are using 12-hour time. Finally chose Save followed by Off.
The manual for the base describes setting the date and time. See http://panasonic.ca/viewing/ALL/KX-TG4711C/OI/TG4711C_PNQX5094ZA/TG4711C_PNQX5094ZA.pdf on page 15.
I hope this helps.
Nov 03, 2014 | Lands Phones
My riviera radio clock light comes on and off wnen car is off
clean the contacts ribbon cables, use the alcohol isopropyl 100% for to clean it. 2) test the ribbon cables for open or faulty use the multimeter for continuity. However you can can go to www.autoelectronico.com translate the website with your browser and fix it. God bless you
Nov 30, 2013 | Buick Riviera Cars & Trucks
THE TIME IS NOT PRINTING RIGHT ON THE CARD. THERE IS A LINE MISSING
A line is through the print because a needle within the dot-matrix printer is broken or stuck within the printer. This will eventually get stuck on the ribbon and tear a hole in the ribbon...and eventually led to complete printer failure. This can be caused by the running a staple or paper clip through the printer, yanking the card out of the clock while it is still printing or after years of lint build up (they are suppose to be maintained at least once a year). Try www.gatewaytime.com for an afforable replacemnt Gateway Time Systems Time Clock Sales and Service Pittsburgh
Sep 26, 2013 | Amano Pix-55 Time Clock
Error code f7 and alarm beeping. Pushing CANCEL stops the beeping and allows the clock to return to the time. f7 and beeping re-occur after a minute or two.
Greetings,
did not say what brand, but most likely a board or key panel issue...the keys get stuck and resetting will only work for several minutes....most of the time its a key panel issue ,but seen control boards do this too...on most g/e (you did not say) its the control panel which does not have the board on it..its just the panel with the keypads...either way, you need a tech to do this repair or if your good with tools...turn off power and gain access to control area..you will see a ribbon that goes into the board from control panel..remove this and clean it at the end that goes into the board with a pencil, reinstall ribbon into board and give it a try..you can also cut a 2" x2" long piece of index card to fit under the ribbon to support it and secure it to the ribbon and then insert it being careful not to interfere with the end of ribbon connection and insert this into the board..it gives support to the ribbon....if all this fails to work will need new part
Bruce Denton
Nov 28, 2010 | Ovens
My keyless entry stopped working on my 2005 Jeep Liberty. Replaced the battery on the key and tried my backup key nothing happens.
YOU WILL PROBABLY NEED TO HAVE THE REMOTES REPROGRAMED TO YOUR JEEP IT SOUNDS LIKE THEY LOST THEIR PROGRAM,LOTS OF THINGS CAN CAUSR THAT TO HAPPEN ,LIKE HAVING THEM TO CLOSE TO A MAGNET LIKE LAYING YOUR KEYS ON THE HOME STEREO SPEAKER,OR CLOCK RADIO,DROPPING THEM SEVERAL TIMES, ETC,& ITS POSSIBLE THEY WILL NEED TO BE REDONE AFTER THE BATTERY REPLACEMENT.
Dec 05, 2009 | 2005 Jeep Liberty
GE Sensor Microwave model JES1456wf001 error code F3....how do we fix . Microwave comes on when plugged in and then reads to set clock and then it rings several times and we get an F3 code
F3 is a shorted key pad. To prove this, unplug the ribbon cable of the key pad from the control board and this symptom should go away when you plug the AC cord back into the wall. BE CAREFUL!!!
Sep 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Need to re-set time on Salter digital timer
If it's the same as ours (clock button top left, clear bottom left):
  1. press and hold clock until the clock starts to flash
  2. set time using h/m/s keys
  3. press clock again
Hope it works
Apr 02, 2009 | Hardware & Accessories
Canon P170-DH Calculator
CLOCK & CALENDAR FUNCTION
Look for the key with the cal/clock pic on it. Use to switch between calendar or clock mode. It is next to the feed key.
(12/24) Key used to switch between 12 or 24 hour at clock mode.
(Time Set) Key used to set the date and time in calendar & clock mode.
(AM/PM) Key used to switch between AM or PM at clock mode time setting.
(Format) Key used to select date format between "YYYY/MM/DD",
"DD/MM/YYYY" or "MM/DD/YYYY" at calendar mode.
Hope this helps, play with it I figured it out with instruction sheet.
Jan 10, 2009 | Canon P170-DH Calculator
Emerson SmartSet Dual Alarm Clock Radio Won't Stop "Flickering"
Problem was solved. When clock was plugged in after a few more days, it finally stopped flickering and reported an incorrect time and day. Low battery was now blinking! Checked calendar and found all memory was lost. Purchased and installed a new battery and this time when clock was plugged in it correctly set itself! Fixed.
Sep 27, 2008 | Emerson Audio Players & Recorders
Timeslips 2005 (tsw2005rt) for PC Logo
112 people viewed this question
Top Timeslips Computers & Internet Experts
Iqbal Husain
Iqbal Husain
Hjalmer Lamminen
Hjalmer Lamminen
Neal Marrison
Are you a Timeslips Computer and Internet Expert? Answer questions, earn points and help others
