Question about JVC AV-27D203 27" TV
How to switch from TV to CATV
My remote is busted. How do I switch from TV to CATV? I can't watch the cable channels in TV mode. I have a JVC TV. Thanks!
  • Anonymous Apr 14, 2009
    Hi!
    The Model number is AV-G21P. I use a universal remote control but it doesn't have a TV/CATV switch. I can access the menu from the universal remote but it only shows: set clock, on/off timer, channel guard, auto program, manual program and language. My TV has no front panel menu button. Thanks!
  • sstahley Apr 15, 2009
    I am having the same problem with a samsung tv. I can get to the menu but I do not know what to set the ant/catv to. Should it be ant/std/hrc/irc ???
    Scholar:
  • 56 Answers
Hi teejo,
What is the model number of your TV and does it have a front panel menu button?
Posted on Apr 13, 2009
I just need to know how to link up my Allegro DVD/VCR REMOTE CONTROL to my Phllips Magnavox Television.
TUNING This DVD+VCR is equipped with a frequency synthe- sized tuner capable of receiving up to 181 channels. These include VHF channels 2-13, UHF channels 14-69 and CATV channels 1-125. Auto Channel Programming 1. Choose the SOURCE SELECT option, then use b / B to select TUNER. Use b / B to switch among TUNER, LINE1, and LINE2. 2. Choose the AUTO CHANNEL SET option, then use b / B to find channels. • The tuner will automatically cycle through all available channels (TV/CATV) in the area and place them in the tuner's memory. •After the AUTO CHANNEL SET is complete, the TUNING menu will hide and return to the TV screen automatically. 3. Make sure the TUNING BAND is set appropriately (TV or CATV). • TV : If you are using a standard antenna to receive channels. •CATV : If you are using basic cable to receive channels.
Oct 15, 2010 | Allegro DVD/VCR ABV511
Have a symphonic tv model number wf24t5 and lost the remote... is there any way without the remote to turn it onto game mode
Yes go to menu with the buttons on your TV and go to CATV sometime u can press your channel button until your channels run out and if u keep pressing the channel button it will go into game mode or in other words switch to the RCA jacks in front of your TV
Aug 13, 2010 | Symphonic ST419E TV
Tv missing remote. bwant to watch cable tv
many of these require an original remote to program the catv and other functions---check ebay with your model number and see if you can get one.
Aug 06, 2009 | Televison & Video
I am trying to get channels above 13. I do not
Try bringing up the menu by holding both volume buttons down at the same time (or use menu button on remote if you have it). Go into CH SET using the channel and volume buttons on the front of set (or use the SET + and - and the ENTER buttons on remote). Go to the TV CATV line and move the arrow to CATV. Let menu time out. This will put tv into cable mode. Hope this helps.
Mar 12, 2009 | Durabrand DU1901 TV
I have a jvc tv model av27530. Disconnected cable box b/c going
You probably have to find your original remote to the set and go through setup in your menu. On most sets, there will be a menu item which will allow you to switch from Cable mode to Air mode. If you have no Cable connected, then you must set tuner in Air mode.
If you are using an external device to run on channel three, then try this:
Make sure device (rather it's a vcr or game console), is hooked up to your Antenna Input connector. Also, some of these devices will have a small hidden switch on back that says 3 and 4. Move the switch to 3 position. Turn on device. Go into TV menu and do a Channel scan. This should auto program any device hooked up to the TV antenna input jack to channel three.
Keep in mind that you may not receive anything by Feburary of this year without an HD converter box to tune in channels with and outdoor antenna.
Jan 09, 2009 | JVC AV-27530 27" TV
My Quasar VV8220
According to the manual, follow the steps below to program channels on your Quasar VV8220 TV:
1) Hold the CHANNEL MEMORY Button on your remote in and press the 1 key
(a box will come up where you can shift between TV & CATV --
you will want to be on CATV (for cable channels).
2) Press the 4 key which will change from TV to CATV -- make sure it is
on CATV or if it is already on CATV, press the 5 key.
3) Press the 4 key (the auto set guide will engage and go through the channels).
Hope this is helpful.
Aug 14, 2008 | Televison & Video
CATV access
you need to hit the input button on your remote to CATV and u will get the cable channels
Jul 16, 2008 | Emerson TC1351 13" TV
VCR/Cable TV Connection
I guess you are using the cable TV feed looped through the VCR to the TV set.
Make sure you did not confuse the in and out loop of the VCR.
In the VCR menu, or on the remote there is usually a button called TV/VCR (Video). Make sure it is in the TV mode to watch the cable. In the VCR (Video) mode, the TV must be on the VCR's designated channel to watch the VCR, and the VCR tuner is used to watch the cable channels.
Jerry G.
May 24, 2008 | Televison & Video
Switching from TV to CATV
it sounds like the tv is already in cable mode, and that it is a older tv. some older tv's will only tune in so many channels. yours going up only to channel 69. if you have the remote for this tv, try punching in channel 73. if it doesn't tune in, then the tv will not recieve channel 73.
good luck
wg
Feb 05, 2008 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Receiving tv programs
In the menu theres a channel set up mode. You want to switch from antenna to cable mode, then do an auto search. Then all your cable channels will come in. Your going to need the original remote to go into the correct menu. good Luck
Aug 25, 2006 | Audiovox FPE1078 7.8 in. TV/DVD Combo
JVC AV-27D203 27" TV Logo
360 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
