Question about Dryers
Maytag LDG5914AAE Gas Dryer gas shuts off after 15 seconds or so
Took off front panel of Dryer and igintor working, gas flame runs for about 15 seconds and than shuts off. Dryer continues to run, just no heat. I've done some research and looks like there are 2 coils that can be replaced to fix??
    President:
  • 1,902 Answers
The coils can be replaced, also I would check your dryer vent and make sure that the vent is clear and ffree from any blockage
Posted on Apr 13, 2009
Maytag gas dryer will not ignite
me id say there is either no gas or hi temp switch has went out
Mar 10, 2016 | Maytag Dryers
Maytag Dryer runs for 8-10 seconds then shuts off accompanied by burning smell
When you say it runs for 8 - 10 seconds, do you mean it spins for that long or the flame is lit for that long?
Dec 01, 2012 | Maytag Neptune MDG9700A Gas Dryer
I have a older Maytag gas dryer DG612. The igniter comes on the gas lights, runs for about 5 seconds then shuts off. The process repets its self over and over again. It is trying to start but shuts off the...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 16, 2010 | Maytag MDG7600AW Gas Dryer
Have a Maytag gas dryer, model#:LDG7314AAE, flame wont stay lit.
Clean/repair your dryer vent. The flame when it exits the funnel should not touch or just barely touch the funnel end. This indicates good airflow. A good test for the clogged/damaged vent is to disconnect the vent hose from the dryer and run it as is. If the flame stays - clean vent. If not - clean air path inside the dryer
Nov 17, 2009 | Refrigerators
I have a Neptune Gas Dryer MDG300AW and the flame goes out.
Well, first of all, the flame is not supposed to be continuous... it cycles on and off during the dry cycle because it staying on would incinerate your clothing. However, there are magnetic coils that do often go bad and cause the valve to stop opening after the beginning of the cycle... so you get a flame in the beginning, but if you were to sit there for 5 minutes with the dryer running, you would find that the flame stopped lighting completely.
They are pretty easy to replace... you will have to unscrew the little plastic pieces from the inside edge of the door, and unscrew the hinges and remove the door, then pull the front panel off (pull at the top).
Of course... UNPLUG before opening any appliance.
here's a picture of what you are looking for... they are completely outside the gas line, so changing them is very simple and doesn't require any handling of the gas. they are held on with a small metal plate.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg5500-%3d%3dd563888i3479&PartID=3479
Jul 26, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer does not dry clothes. Flame does not stay on
run dryer for 10 minutes then remove vent hose see if start working mean flame on for while, if it is then you need to clean your vent system.
May 01, 2017 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag gas dryer fires, then shuts down
may be the coils on the gas valve. there are 2. usually they need replacing when the ignitor glows but no flame
Nov 20, 2008 | Maytag Dryers
KENMORE gas dryer
Hi .No The Solenoids Are Turning The Gas On . I would Check The Venting . Remove The Venting Clean All Venting. Thanks The Appliance Doc
Oct 03, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
228 people viewed this question
Top Dryers Experts
