Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Doors open but will not close
When i try to close the doors it keeps on trying to open them I have a similar problem and have not been able to resolve it. When I close the door, it goes down all the way then a second or two later it goes back up again. There are no obstructions underneath the door to cause this. Any solutions?
  • Anonymous Apr 13, 2009
    Question for jgwhomeequip: how do you know whether or not the safety lasers for the garage opener are properly aligned - is there a blinking light or other way of telling?
    President:
  • 1,902 Answers
Check the laser. Make sure that the safety lasers are properly alligned, If the bottom sensors next to the floor on the door rails sounds like it has been moved and just needs to be realigned. Pretty simple work to take care of the problem unless the sensor is broken
Posted on Apr 13, 2009
I HAVE A SAMSUNG PRINTER SCX-4623 THE MESSAGE KEEPS ON SAYING DOOR OPEN CLOSE DOOR , TRIED EVERYTHING BUT NOTHING WORKS
Dear
The front door right side there is a lever found when it is opened the lever should close the micro switch inside and the door is locked with another short lock (near the long lever). If door lock broken then the micro switch push the lever and door not closed.
the basic problem with the micro switch and related mechanical alignment.
Thanks.
Feb 26, 2015 | Samsung SCX 4623F - Multifunction fax /...
I NEED THE MANUAL FOR MY STANLEY 8500.51 GARAGE DOOR IT WON'T CLOSE
Try searching around here to find similar or hopefully exact opener. Stanley no longer is in the garage door business, and the company that bought them out went bankrupt.
Good Luck
http://www.teknuw.com/garage-door-opener-installation-manual/stanley/
Feb 23, 2015 | Building Materials
How to take door panel off hyundai driver door.?
if you can't get the door open then i'm afraid you will have to cut it away and get a new one( the panel ) , have you tried removing the exterior weather strip from along top edge so you might get a bent coat hanger or similar to pull the latch to open door , worth trying because the alternative is a nightmare
Oct 11, 2014 | Cars & Trucks
Unlock locks on side of the door that keeps the door from closing
Not entirely sure what you're asking but I'll try. If the door does not close, the latch may have accidentally been knocked into the closed position. Unlock the door, have somebody pull the handle like they are trying to open the door and hold the handle out. Then place a screwdriver, or something similar, about 3/4" into the latch at the end of the door. Now push the screwdriver toward the vehicle, replicating the action of the striker as if the door was being opened normally. This should release the latch and the door will then close. If your problem is something else, add some more details and I'll try again.
Nov 22, 2010 | 2002 Cadillac Deville
We are having a difficult time getting the door back on the oven. Can you give us a tip on how to keep the hinges from snapping back when we are trying to hook the himges back onto the rods?
Passing on the solution. Some other blogger helped me, so I hope this will help you. Mine is a Kenmore Gas range, but the hinges might be similar. They are fixed on the door, not on the range. Get a couple sturdy nails or similar items and keep them in your hand. Use your foot to push the hinge all the way down, as if the door were fully open. You should see a hole in the hinge, in which to insert the nail to hold the hinge open. Repeat on the other hinge. Carefully lift the door in place and set the hinges so they hook onto the latches properly. You should be able to open the door a bit to take the tension off the nails. remove the nails, and that should be it. Even if your hinges aren't the same as mine, the principle seems to apply. My problem (maybe yours) was that I couldn't open the hinges and keep them open when trying to replace the door. They just would snap closed. Very frustrating.
Jan 23, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
1993 Dodge Grand Caravan: after sliding side door was opened, latch at rear edge of door returned to closed position and will not move when door is closed, even when door handle is pulled. Door therefore...
Try putting a screwdriver in to act as catch on door frame & try pulling each handle & getting it to let go. Make sure you spray it, as well as behind it & around it with WD-40 or similar to get things loosened up in case their just partially seized. The keep working it with screwdriver until freed up.
Jun 07, 2009 | 2002 Dodge Grand Caravan
The safety beams (mounted on the track near the floor) are out of alignment and the LED light should be blinking. The garage door opener will not let the door close if the beams are misaligned. Realign them and the LEDs on the beam or on the operator will stay on. you can close the door now
Apr 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
The door opens then when it goes to close it keeps it opens again
have you tried cleaning the contacts on the door
Mar 03, 2009 | 2001 Ford Windstar
Won't unlock
I've had a similar issue occasionally;
First, try turning it off and on again.
Then push the door closed with your knee as you pull the release handle.
My door seems to close tighter at the bottom than the top, so I have to push the bottom of the door in fully sometimes to get it to open. I guess some kind of sensor is getting tripped, and keeping the door locked..
I hope this helps!
Will
Nov 07, 2008 | LG WD-12126RD Front Load Washer / Dryer
Craftsman 1/2 hp door opener
replace the logic board
http://www.chamberlain-garage-door-openers.com/circuitboardcompatibilitychart.htm
Dec 16, 2007 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
112 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
